30
Everything posted by Turbone
BIG NORTHWEST SUBARU MEET... whos going?
Turbone replied to Mr. Brat's topic in Meet n' Greet. Your USMB Welcome Center
Look for me (and my RX) at the Outback Auto vendor booth. Ummm what? -
I'm going by what Suberdave did on his coilover install on his wagon. They are completely adjustable, so theres no issue about riding level. Part of the point of coilovers is being able to adjust ride height. I had to use 02 WRX coils up front and 05+ Legacy in the rear. The rear mounts need to be cut in order to fit the tophat of the coilover. The WRX tophats are bigger and the strut tower needs modification also. Its not a bolt in application.
Using the stock top mounts, they need to be trimmed some. When I do the install I'll take pics and notes.
Ordered thru my work from BC. They are in Taiwan.
Yup, for the same reason I've been a member at Nasioc since 02.
Glad you decided to keep dealing with it, you have earned the tag "Die hard SVX owner". And I seem to see Nate in that position a lot :-p
I bet he figured out the problem too.......7yrs ago!
Big Northwest Subaru Show
Turbone replied to Turbone's topic in Meet n' Greet. Your USMB Welcome Center
Hmmm, where did you hear its going to be in Oregon next year? -
The Awesome Vehicle Picture Thread
Turbone replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
A newer gen Ford Focus that came into our shop to get the fenders rolled. A great little sleeper. Not sure if I saw a 69 Firebird TA yet. NSX Spyker Alfa Olds -
Dynolicious results 93 Loyale FWD
Turbone replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That wtq is waaaay wrong. I'll have a dyno run done after I get my exhaust and before WCSS14 -
Its the fiancee's. She finally found the one she wanted.
No, not this one. Bringing the RX and the 05 Outback.
Quattro San lives! (Updated as of 11/2/2004)
Turbone replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Black enough for me. -
OMG this is sooooo tempting. I would love to own a piece of this history :-p -
If it wasnt black, I would have passed on it :-p
Yeah, only the bottom pulley was roughed up. I'll be replacing all of it tho, just to be safe.
I pulled of the broken timing belt covers and charged the battery to make sure the car ran. I wasnt going to do to much work before I knew if it was a runner or not. Even with the intake removed and no radiator etc, it fired right up. So besides the timingbelt and pulleys (that I will replace) the power steering pulley was bent, but thats it engine wise. I bought 24in of 2x4 steel box end and had it cut in half. The plan was to use them as sleeves and so far they are doing the job. Once things were removed from the parts car (with lots of careful and repeated measuring) I was able to see how it was going to fit on the front. It was looking good at first then I noticed the passenger frame rail was bent out by 1.5in. So I shoved my steel sleeves into the ends and hooked up a come-along to each end and cinched it as much as I could. I then heated the frame rail where it had a small buckle and beat on the rail to get it to move. I got it within 1/4in after a fews days of letting it sit so the metal would re-memorize its shape. I had to trim the sleeves for length and then set the front on, I threw a few bolts on the fenders to front clip to hold it while I checked it all out. Heres a few pics of the frame rail joints with the sleeves in them. I'll weld everything once I make sure its all in line and straight. Heres the core support on for fitting. And with the fenders attached and hood down. I had to use the hood from the parts car also.
So the first thing to do was get the front radiator core support removed. Thankfully the airbags didnt deploy, but I was sure being careful when I had to mess with the sensor on the corner. It was actually stuck between bent metal, I can believe it didnt activate the airbags.
Picked up my newest Subaru yet, a 02 Forester that had the right front crunched. 167k on it with the cold weather package. Interior is in good shape, the engine still runs good. Paid $1k for it And to top it off, one of the regulars that hangs at Outback Auto where I work had a wrecked 98 Foz with a good front end. He's using the engine/driveline for a swap into a early Leggy and he gave me the parts I needed for the front clip. Score again! Heres what it looked like before I started work on it (nice to have it at work where I have all the tools).
I replaced the windshield in one of mine for $300. They dont come with the seal, so make sure whoever replaces it removes the old one carefully and reuses it. Depending on your location and the part you need, its not that hard to find the parts (if you have to, buy one thats cheap and part it out.....but dont mention that on the SVX forum). I replaced the engine and trans in my last one by myself, and I'm old :-p Wouldnt want to do it again tho I have yet to replace a wheel bearing in one, I guess I'm lucky there. But I dont see that as something to keep me from buying one. They do have a tendency for gremlins that are hard to diagnose. They also have a tendency of being money pits. Being up to 20yrs old now, they need lots of maintenance. Usually depending on how the previous owner treated them. My last one had 101k on it, but looking at it you would have thought 201k Having just sold one, I will be looking for another one again in a few years. Or if I see a deal I cant pass up, sooner.
Totally different event, even the dates are different. Get your buddys together and caravan up.
