Turbone
Administrator
    30
Everything posted by Turbone
  1. I put a early Legacy MC on my RX, running mid 90's Imp calipers on the front. Suberdave is correct. I've noticed less pressure pushing the brakes but it takes more force to stop. I have a set of 2 pot WRX calipers that need rebuilding then they are going on, along with bigger rotors.
  2. Almost any car can be turned into a track monster, just takes money. Most of the Subaru owners in the PNW know what a GL is :-p
  3. Your problem is the NAPA axle. Its a rebuilt, right? 99% of them are not up to standards and this is why its clicking. And yes, the lower ball joint can be bought separately.
  4. My kit came with sealant, hopefully yours does also. The buckets are installed, little hard to get a pic now. I'm working on another set and I might be able to get a pic, but theres nothing special about it. I hope you have 2 sets, so you can be working on one while you drive the car.
  5. Stock isnt to bad. There are some typical susp upgrades you can do that improve it so it will corner like its on rails.
  6. I believe it was Felpro, I think rockauto carries them. http://www.rockauto.com/catalog/moreinfo.php?pk=122485
  7. This was my last SVX, a 92 Ebony. I still miss it Handles like a big caddy. Power is on the upper end, floor it while cruising at 60mph and your hitting 100mph in nothing flat The nice part (maybe, this could get you in trouble) is that you dont even know it, its that smooth.
  8. I believe most auto parts stores have it. I'll try and get a brand name etc.
  9. I never had one leak or go out once I started using the gold spray on sealer. I just popped ring lands after that
  10. The OEM lens sits out from the base about 1.5in, so if you use flat glass you will need to find a shorter projector. The initial grinding started with 60grit discs and I worked my way up. Used lots of water also to keep it cool, if you dont the glass will crack from the heat.
  11. This is the skinny from Tirerack.com http://www.tirerack.com/wheels/tech/techpage.jsp?techid=107
  12. Everyone (In the PNW) should have great pics tomorrow!
  13. The only thing I could find on the paper work was hidlighting.com. The ones in your link look pretty nice, but personally, I wouldnt spend that much money on a kit. The main factor you need to look for in fitting is the length of the projector. It has to be the right length to fit inside and not hit the glass. Easiest way to measure is take a light assembly, remove the bulb and stick a tape measure in thru the hole. Measure from the glass to the inside of the base. This will give you the length of the lens needed. Most of the manufacturers give dimensions of the projectors.
  14. Made in China! I cant get to the box right now, I'll check soon.
  15. I need to get a pic of my RX and another Gen 3 side by side at night. That would give a perfect example of the difference.
  16. You should bring it over again, this time I can take a look at it.
  17. All true, I had a Imp clutch disk in my EJ swapped RX using a XT6 PP and flywheel. But it didnt hold up all that well to the increased torque from my upgrades......EJ22T with TD04, etc. :-p
  18. May have a bad ground back at the fuel pump. Add another ground at the plug to the body and see if that works.
