Turbone
Administrator
Everything posted by Turbone
  1. My FSM, sections 2&3, that came with my 86 T-Wagon are in the same condition. Pages are like new but they are falling out. I was thinking if taking them to a printer and having them re-bind it, but after all this talk of scanning and such, I might reconsider
  2. Hey Tex, how bout some more info on the charity show this Sun? I would love to cruise up in the T-Coupe, just to let them know thier roots. Oh, I'm sorry Will. Forgot to say that I'm behind you 100%. Well, maybe in front
  3. And it really is ok to start a new thread to ask questions :cool:
  4. Could you be a little more specific on what parts you need?
  5. The Turbo digidashes are actually hard to find. I've swapped out a couple of non-turbo's in my T-Coupe, and they have worked fine. Its just the turbo light in them that makes them different. Anything over 14v is not good for any system. Keep it there for long enough and serious problems will occur. The whistle from your dash is supposed to be a warning of bad juju from the alt. If you have nothing on your dash and its still whistling Dixie, its gone. But there is hope! I have a aircraft electronics tech working on repairing bad dashes, hopefully soon there will be some available for everyone. They will be upgraded also, so that instead of burning up internals, it will just trip a breaker or fuse. If you get this JY dash, make sure you can return it if its bad. If not, shoot it my way and it will be put on the repair bench. I just bought one a few months ago, but for the life of me, I cant remember what I paid for it It was cheaper than $50 tho.
  6. Well dont feel to bad, or all alone. Went to install a head I picked up recently and just now discovered a broken intake bolt. It had 1/2in sticking out, I thought, ok no prob. Gave it a couple of raps with the hammer and vienerslickum, put the vice grips on and commenced to move it back and forth. After about 10 min with no movement, I gave it a little more pressure and it snapped. Ok, now I drill it and put in my easy out. Same procedure, lube and turn very carefully. SNAP! !@#$%^&*(BEOTCH! Not even enough there to get a grip on to remove. So I get a real small bit and drill alongside it. Got one hole drilled and went to drill another. Got halfway and it snapped. Ok, now its time to quit until I can decide on what to do next. The head is just got 2 bolts holding it to the block, so it can be taken somewhere to be fixed. But I sure didnt need this to slow me down, I'm working as slow as I dare now. I only have 3 weeks before the show, darnit.
  7. Ahem...Qman, the only times I see you in it, is when your trying to find out whats wrong with it But seriously, for a Honda its pretty quick. And loud. I find it hard to believe that your Turbo Legacy cant keep up with it :-\ But back to topic. When $ flow gets better for me, I will be doing a few things to "Sid" to make it a tad more quicker. Will, better get on the ball. You too Caleb.
  8. Thats because it was disconnected and you got it hooked up now. If you have more questions about Turbo's, I would suggest this web site for some good reading. How Stuff Works
  9. It means the turbo is putting out boost, you ninny
  10. I wouldnt paint it, thats pretty permanent. At the least it will take some harsh chems to get it off. I use the Dot Matrix Static Cling stuff on my back and side windows of my Mazda truck. Its stayed on for years and does ok blocking the sun. They also make the solid type stuff also.
  11. Jeez, that brings new meaning to the term "jet lag". Hope things go better on the way home Ed. Whats winter like down there?
  12. Thanks Gabe for the info. Heres a link to a site that sells the covers. And they are not cheap GTS Light Covers
  13. It doesnt sound like you are in the USA, so any prices we give might be irrelevent to you. I would suggest looking for a donor car, I think a 85 - 89 wagon would even work for you. You can use the front fenders for direct replacment, but you will need to cut out sections from the rear quarter panels to replace the old rusted ones.
  14. Looking sharp, now we know why you havent been around for a while. One question tho, where did the headlight covers come from? Only got one?
  15. Ah yes, the ghetto anti-theft device. Lift hood, pull coil wire, close hood But realistically, a ignition interrupt switch is easy to install. Preferably a high amp switch, hidden under the dash is best.
  16. You may have had it right the first time. When the passenger side cam mark is straight up, there will be 3 small lines showing on the flywheel. These are not the timing marks, those are about 90deg to the right. Once you have this belt on and lined up you need to rotate the crank so the pass cam is pointed down. Now with the drivers cam mark pointed up, put on the belt. After your all done, time it with a timing light.
  17. Naw, no need to rub your nose in it. Just looking at what you did to your 1st car in less than a month is punishment enough
  18. Kinda glad you didnt buy my 84 coupe now :-\ You'll learn, its only money
  19. The jiggle pin is a small loose piece of brass that sits on the flat part of the Tstat. It allows air in the system to escape.
  20. The only times it got warm on me was when I was in town and sitting at the lights. You have to turn on the fans when in traffic. The back battery runs the fans, and has a inline fuse close to the battery. That sucks about the caliper, I guess thats from a few years of offroading abuse. It sounds like you might have a HG problem, due to the clogged rad fins. Hard lesson learned You really need to rinse it off when it gets stuffed with mud and junk. Will you have it fixed for the HP weekend?
  21. Yup, the rest of it is on the underside of the XT hood. Altho I did see something like it on Corky's 2dr WRX.
  22. Eh, when they work its great. I guess I'm lazy The one on my 86 T-Wagon hasnt worked since I got it and I still try to make it work. Did I say I was lazy? When the clutch gets worn out, the HH will be a bear to adjust right. Most people disconnect them and then dont reconnect when they put the new clutch in.
  23. Well, I'm going to be hard pressed to get the kids and wife up and at em by 6am, let alone me. I just might take an extra day off (Thurs) so I can get to bed early. Yea right, like I'm gonna sleep
