30
Everything posted by Turbone
You can read about my EJ22T swap. http://www.ultimatesubaru.org/forum/showthread.php?t=110912
has anyone fit a V8 into an ea82 body.
Turbone replied to roostema4328's topic in Subaru Retrofitting
I would rather stuff a SB V8 in it than a SVX 3.3 The weight savings wont be that much and you'll get more HP. I've pulled a EG33 and its a beast. Having problems finding pics of Lumpcams project, but he swapped a V6 into a unHatched. http://www.ultimatesubaru.org/forum/showthread.php?p=146137#post146137 -
Not on my RX, but you can try it
Air conditioning condenser removal
Turbone replied to 81EA81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You need to use a breaker bar and pipe on the crank bolt. Rest it against the drivers side fender and bump the starter, with the coil wire disconnected of course. -
Dirt Cheap Rally - A NEW Way To Thrash On $500 Race Cars
Turbone replied to Dirt Cheap Rall's topic in Rally/Racing
Did you go to their website and look? And over here on the west side theres plenty of old Subaru's to bash up. But I dont plan on racing in a event where it costs more than the car -
EA82 non-interference
Turbone replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm going to lock this before it turns into a big mess. -
It's PVC, cut it with a saw or whatever. I cut 5in out of the center and used the remnant to brace it underneath, then I epoxied it. I used a filler on the seam, but it flexes and ends up cracking. I have it vinyl wrapped now, so its not as noticeable. There is a smaller scoop on ebay that doesnt need to be cut, I used it for a while. This one will work, but it will be right at the edges of the hood crease. http://cgi.ebay.com/ebaymotors/TURBO-RACING-STYLE-HOOD-SCOOP-VENT-BLACK-CAMARO-CHARGER-/350490522058?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&hash=item519adcf1ca#ht_6865wt_1161
You should post up a email or phone number so people can get a hold of you promptly.
New S.O.S. steel subaru wheels 4x140x15
Turbone replied to sos fab's topic in Products for your Subaru
I suggest you guys either call or email him, he's pretty busy. I talked to him at WCSS13 and he told me what he was doing and the tools he purchased to make a better product(s). You will be getting your moneys worth if you buy from him. -
Look on ebay, theres a few that will fit. Or you could do what I did and modify a WRX hood scoop.
Yes, those are pretty worn. I've been meaning to try this on my RX, have yet to get the parts. http://www.subaru-svx.net/forum/showthread.php?t=27738&highlight=%2415+mod
This is where I think you are wrong (misinformation). Not all HID's come in projector lamps, they are also in reflector type lamps (specifically designed for HID's). http://en.wikipedia.org/wiki/Automotive_lamp_types The point you are trying to make is this... This info is from the wiki article. http://en.wikipedia.org/wiki/Headlamp#Reflector_lamps
Projectors are quite different than plain HID's. Show me a standard cutoff from a car that comes from the factory with HID's. They wont look like the pics of the projector lights. Loyale 2.7 turbo lives in a rural area in S. America. Dont think his lights are going to be a problem. The others need need to adjust their lights accordingly. Check out my write up on projectors in GL buckets. http://www.ultimatesubaru.org/forum/showthread.php?t=125187
If its a MT there wont be a problem with towing. You can even drive it with those tires, just dont drive it in 4WD.
Glad to hear you made it home ok and didnt have to much to deal with when you got there. And you are welcome in my campsite or home anytime. Oh, and get some better walking shoes :-p
Do you have HID's in your car now? If so, post pics please. Theres going to be lots of diffusing in a EA82 headlight housing.
Rally Armor Mudflaps
Prepare yourself for sticker shock, unless you buy used. -
Post your pics folks. I didnt take a lot, this year I spent more time chatting and visiting. Great to see old faces and meet some new ones. Even tho we didnt have the mudpit, the go carts were a hit (Hope we get the mudpit back for next year AND the go carts). Camp set up on Fri. Thats Donald next to me. The view... Not sure who this is... The vendor display and announcement building.
I'm bringing a EA82 bra, hows that for unique?
Cant wait to see/hear it!
No compression after head gasket install??
Turbone replied to notliving's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You might have had a faulty reading on that cylinder. How many times did you check it? -
Check and see if a valve isnt sticking open on that cylinder. Loose rocker arm, etc. -
Late 90's EJ seats into L series - anyone done before?
Turbone replied to el_freddo's topic in Subaru Retrofitting
When I have swapped early Legacy seats, I had to drill out the rivets then make a tab front and rear to bring the (L series) rail in. I think its about 1in narrower (L series). Problem is the tabs need to be thick (for support) if you arent welding them. Use Loctite if you use bolts to attach them as they will loosen after a while and the seat will move around. I made the inside rail stationary and brought the outer rail in. -
If he's not removing the axle completely, no need to take off the axle nut.
The EA AT is the same as the MT for axle removal.
