1993 Legacy - Rear sway bar questions - doesn't appear the car has a rear sway bar?
If the car spent a lot of time on the trails, maybe a previous owner removed the bar(s) for more articulation?
2019 OB Software download fails
this is among the reasons I am fixing my wrx. Wihle it is in no way ever going to be as reliable/practical as a NA car, it's the devil I know and I still like driving it. My wife wanted me to get a new car with some inheritance money. I'm like. why if it doesn't get driven much and has to sit outside in the weather. She has her new CR-V and we hardly drive it.
AC Not Working 2002 Impreza
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck rock auto - or, if you are near a larger city, radiator shops often can fix/make a hose for you.
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had to replace the high pressure hose once on my WRX, twice on our old Outback. The Outback also got a new low-side hose. They don't last forever.
Goodbuy R160 Hello R180
12 year old thread......
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmost every time I've followed a thread where a system was overcharged, there has been a 'hooting' noise reported. Sometimes when the car/system is turned off.
Subaru Frustrated
it's well known and legit. I have experienced it in our 03 H6 OBW
- Adding Oil additives like Lucas Stop Leak or similar to a Subaru
1 Lucky Texan replied to Fuji's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould just be coincidence. As soobs age, the seal between the core and the plastic tanks can leak..... but, a pressure testing kit 'loaned' from a parts store may help to pin-down exactly where the leak is.- 1992 Subaru loyale Alternator is getting hot
- Transmission case crack Outback 2014
1 Lucky Texan replied to Suby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I knew no one other than a dealership had serviced it, I think I would contact SOA and meet with a Regional Representative at the dealership.- Parking brake light
1 Lucky Texan replied to Berit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLikely the diagnostic system has stored the DTCs. A psrts store or a mechanic can read them. post them here. sometimes, a failing battery or problems with a charging system can cause spurious codes. Even something like a loose or failing seal on a gas cap could do this.- Compressor Replacement '14 Forester
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf he gets a new compressor, will it come with a little oil in it, or should he add some?- Help New 06 Impreza Sport Wagon Owner Diagnose Problem
that engine is notorious for blown HGs. They almost all (99%) leak combustion chamber to cooling jacket. Unlikely to see chocolate 'mousse' in the oil. BUT, sending coolant and maybe oil samples to Blackstone 'may' be a good idea. However, not knowing how often or severely any past overheats were, you run the risk that repairing the gaskets on this engine, may buy you a few weeks or months until a rod bearing fails. I think, to do this reliably; a used engine from a wreck, that you equip properly with new MLS headgasts, and, a proper timing belt system service, are required.- Compressor Replacement '14 Forester
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEven though I have worked on my 2 soobs' a/c. really, if you can find a good shop, or even a good auto a/c shop, for the money and hassle of trying to both diagnose and repair the car, I strongly suggest getting it fixed by a pro. I kinda regret buying gauges and adapters, and having to 'loan-out' a vacuum pump from the parts store, having hoses made or buying them and waiting for arrival, getting an assortment of 'blue' o-rings (that were cr@p), getting a different asst. of o-rings..... that said, the refrigerant volume is likely listed on a label near the compressor - maybe on the radiator top support or under the hood.- Return of the charging/starting issue to my 91 loyale
not all, but many, cars are made this way - others can give more details I'm sure; http://www.pirate4x4.com/tech/billavista/Wiring/Part2/images/Alternator-block_diagram-2.jpg- Sohc Ej22 timing off 1 tooth
do you have bubbles coming out of the coolant when it is overheating? If so, then yeah, I suspect you're right that the gaskets may be done. The bubbles are from a combustion chamber. But, there are other things that can cause 'simple' overheating. A clogged heater core can also cause overheating because of the weird coolant circuit down at the t'stat's housing.- Return of the charging/starting issue to my 91 loyale
when the car is acting normally, and you turn the ignition on, and the instrument lights get 'tested', does the batt light com on? I think if it ever burns-out, you won't get field current to the alternator.- Sohc Ej22 timing off 1 tooth
GD's toothcount suggestion is dead on. Search online for t'count for that engine. You guys are in the middle of summer....but still doubt a tooth off is gonna cause overheating... make sure it has an OEM style thermostat with the large wax capsule, make sure there's no debris build-up between the radiator and the a/c condenser, 'burp' the cooling system well, etc.- '03 Impreza with problems. AT Oil Temp light
1 Lucky Texan replied to Terpodion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand sometimes the leak is above the fuel tank and fluid could pool there, then blow or drip down almost anywhere around it.- Heater/blower fan stopped working
1 Lucky Texan replied to destey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes it blow on High?- Hard to find coolant leak, used dry ice to find it
cool- Adding Oil additives like Lucas Stop Leak or similar to a Subaru
1 Lucky Texan replied to Fuji's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh yeah, it may not save money - dunno. But, you're not just buying a (likely) leak-free engine, you may be buying one with much lower mileage too.- 1988 GL 10
maybe try ebay motors?- Adding Oil additives like Lucas Stop Leak or similar to a Subaru
1 Lucky Texan replied to Fuji's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwould a JDM engine swap be worthwhile here? - Adding Oil additives like Lucas Stop Leak or similar to a Subaru
