***No discussion,sizes only of A/C air conditioning compressor oring o-ring sizes conditioner
1 Lucky Texan replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2003 3.0 H6 OBW (stock OEM compressor) top-rear Compressor: 17.8mm x 2.5mm left ('high') side Compressor: 10.8mm x 2.4mm used the blue/green w'ever 'variety pack' o-rings from O'reilly's used some wire to hold the throttle and CC cables 'up-and-back'. i also pulled the electrical connection and tucked it under out of the way. Used a rag/paper towels to clean up around the areas. I pulled the top-rear fitting and used a toothpick to get the old o-ring off. It was much less flexible than the replacements and deformed/flattened. The large o-ring mentioned was a good fit. I lubed it with a little oil that was sitting inside the compressor. Then I did the same on the left-side fitting (high side). The o-ring was a little more difficult to remove. It was also stiff and deformed/flattened. I think the 10.8mm x 2.4mm is the best fit here.
Legacy ABS code 46
1 Lucky Texan replied to dollinn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXABS is sensitive to system voltage too - maybe give the charging system a thorough check.
2005 baja rally ready?
your car shares a lot with the Outback. Most suspension, skid plates, lighting, wheels, brake parts, etc will work. you might also dig around at; subaruoutback.org
subaru liberty/ legacy 2001
1 Lucky Texan replied to switzman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXperhaps a tire threw weight off - you could have that inspected, maybe move front to rear and rear pair to front - monitor for any change. using an infrared thermometer to measure the hubs after a run might find an excessively hot wheel, if so check brakes and bearings. some people have found bad driveshaft components making vibration. I've read of people discovering loose lugnuts allowing the wheel to move around.
1995, imprenza, trouble starting after sitting overnight
1 Lucky Texan replied to JRose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe someone from maryland here could suggest a different mechanic to take a fresh look at your car. some computer controls began in the early 70s. Quite common by mid/late 80s. read here; http://en.wikipedia.org/wiki/On_Board_Diagnostics Though some cars were OBDII compliant in 95 (possibly yours, might be on a label in the engine bay, or underside of the hood), it was mandated in 96.
1 Lucky Texan replied to switzman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, it may be the VC in the 5-spd. They occasionally go bad. And, any mis-match of final drive ratios will definitely cause torque bind. But it would have been immediately apparent after the parts were installed. Did you just recently get this car? Are all your tires the same brand/size? They need to be extremely close to the same circumference. Even a new tire mixed with old ones can cause 'torque bind'. If you turn slow tight circles on flat dry pavement, is there any bucking/jerking felt in the car? Try it cold and after a highway run.
CV longevity
I've seen some generic-fit silicone boots for sale at Amazon, but the few reviews were negative. Have they been durable for you? got any part numbers or sources? thanx
2001 lego overheating issue
1 Lucky Texan replied to luko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, the symptoms sorta mirror typical failed rad fan symptoms. But, soobs exhibit odd symptoms with bad head gaskets and after market t'stats. If the t'stat BRAND/STYLE was the problem, I'd think you'd have had problems immediately - not 60K later. check the fan operation first and watch for collapsing hoses - cros your fingers that the rad cap was bad but, seems unlikely. hope it isn't HGs again.
1 Lucky Texan replied to JRose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXinteresting seems like there could have been more than one problem, wondering about the wiring issue. Kinda wondering why the fuel pump was changed too. On 'cold' starts, the computer only knows to add fuel (choke) by getting a temperature reading from a sensor. If that information is good, it chokes the car allowing it to start more easily. Then, as the engine temp goes up, it reverts to a more efficient/leaner fuel map. So, the Engine Temp Sensor (not the temp gauge sender for the gauge on the dash) and it's wiring is important. But, if you had a leaking injector , you could have TOO MUCH fuel and, holding the gas pedal on the floor causes a 'clear flood' setting to be used. That's when the computer shuts fuel off. If you want to do more testing, checking fuel pressure after sitting overnight or pulling plugs to look for one wet with fuel might be a good idea. maybe someone else will have some ideas.
Leone crash test
probably no worse than other cars form the mid 80s.
Leone crash test
ouch - that steering wheel probably broke his nose!
My check engine light came on and this was the code
1 Lucky Texan replied to ibroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso many things can cause that code. definitely get every maintenance/tune-up issue taken care of - make sure the plugs/wires are good, etc. seafoam treatment is a good suggestion. clear the code and see how quickly/if it returns. DO NOT change the cat. converters.
heartless & madkow's 98 Forester
could that be kilometers?
1997 outback TPS and bogging down while turning
1 Lucky Texan replied to 3timeowner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcool could you link to the test you used or outline it for us?
- Super Weird 1990 Subaru Legacy Fuel Issue
2001 Forester alarm issues
1 Lucky Texan replied to sterlingre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe you can find a brand/model of the remote start system and locate a manual for it on-line? It may be OK if it was professionally installed, but many people have problems with them and it's usually worse if some DIYer did it.
99 DOHC 2.5 cam sprocket hash mark question.
1 Lucky Texan replied to darsdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXholy zombie jesus, is that all the endwrench articles? cool!
CV longevity
what kind of bands do the Subaru boots come with? where are you getting them?
1999 Forester 2.5 overheating
1 Lucky Texan replied to Giovara's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan't speak to everything but you definitely do not want a typical after market t'stat.
99 OBW engine bogs down
1 Lucky Texan replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthrottle body cleaning might be helpful.
Vibration at different speeds.
1 Lucky Texan replied to Robepktt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlthough soob bearings can fail in odd ways, both the bad ones I've had would 'rock' up-down (12 oclock to 6 oclock) when lifted off the ground. One of them was very noisy , the other one silent. they both only moved a coupla mm.
I think I killed my EJ25...
1 Lucky Texan replied to Speedwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI read of a guy that misrouted the breather hoses and the PCV vacuum hose on his STI. Had low oil pressure and even heard gurgling in the dipstick tube!
Emissions Questions
1 Lucky Texan replied to su-version's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmany systems (not just cars) are built with 'normally closed'-type logic. That way, a connection problem will also show itself.
1 Lucky Texan replied to Robepktt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXswap front and rear tire pairs and monitor for any changes. also, some folks have had a dragging caliper cause similar issues. maybe use a remote infrared thermometer and compare hub/brake temps side-to-side after a highway run.
ok this just gets weirder and weirder, throwing codes seems random
http://txtup.co/iVJPd ALSO there is a device under the intake on the right hand, rear side that has a vac hose and some wires running to it, but its not hooked up to a vac hose, and IO don't recall unhooking it, nor is there a port to hook it up to sounds like the Purge valve - could be your Evap code problem (some older soobs have that in the back, some under the hood - I dunno which years so, I might be wrong) Hose should go to the intake IF it's the purge valve - not sure if it's routed to near the throttle body or exactly where.....maybe dig around at opposedforces.com for a diagram for your car. DOH - didn't see the next page before replying
