April 27, 20196 yr I drove her off full boost like the cops just showed up and found out my xt has a front posi! F uck to the yea!
April 27, 20196 yr changed oil/filter, inspected around for issues, tightened a few clamps, topped-off coolant and PS fluid (not sure why but it was a little low), tightened stupid RH rearview mirror that is always loose, polished the headlight lenses - will probably re-do the R side - shouldn't have tried to put another coat of the mequiar's UV stuff on it, sorta hazed/orange peeled it. So, made sure not to do that on the LS. I used the turtle wax kit first, #3 and #4 pads, then the rubbing compound. Good kit and certainly seems to have a long shelf-life. I bought it a VERY long time ago. Wife's OBW has been garaged much of its life so, lenses weren't 'horrible'. Examples in limks attached, hope those work. Probably need to change the wiper blades. Still have a misbehaing RS windshield washer nozzle. the car does have some groaning/squeaking noises when maneuvering around, but nothing severe. maybe old bushings somewhere? everything else seemed fine. (Tomorrow, need to tackle some maintenance/repairs on the WRX)https://photos.google.com/photo/AF1Q...w8gqBuBG6rdvSDhttps://photos.google.com/photo/AF1Q...B72l9PGoKA8R7i Edited April 27, 20196 yr by 1 Lucky Texan
April 27, 20196 yr On 4/23/2019 at 10:01 AM, jdmleggy97 said: Picked up and installed 87 XT seats in my 91 RS.. the stock seats had to go and I'm trying to get to as close to an XT6 as I can, just trying to re live my high school days lol. An xt6 in high school? Panty dropper! I had the 77 camaro and 53 bel air. I was all chevy in high school nearly 2 decades ago! Lol! Panty droppers! I packed the bel air full of cheerleaders
April 27, 20196 yr 5 hours ago, sparkyboy said: ^^ link no worky hmmmm....how can I get a link from google photos that will work? I'm gonna try some different approach I guess.
April 27, 20196 yr Today, I changed oil/filter on the WRX, changed gear oil in the 5spd, replaced the lower half of the intake filter box (the slots for the top's 'tabs' have been busted-out for some time, I had zipties holding it together), replaced both radiator/coolant caps. still need to work on clearing the headlight lenses and the a/c system needs o-rings probably and re-charging. Edited April 27, 20196 yr by 1 Lucky Texan
April 28, 20196 yr I drove Ruby Scoo from the busy road of our last rental to the new, much quieter location that has off street parking for her Once we're settled in and things are unboxed/in order there will be some Subaru work coming up on the brumby and Ruby Scoo. Cheers Bennie
September 22, 20214 yr Never worked on cars until my Impreza's CVT valve body needed to be replaced. Couldn't afford to have the shop fix it, so...researched and got up the nerve to replace it myself. Since then, I've changed all manner of fluids, replaced all the different brake parts, troubleshot and fixed a couple of different wiring issues (gotta love mice), and replaced wheel hub assemblies. One thing on my list to never do again is the rear wheel hub. Only one rear hub needed to be replaced but I don't think my slide hammer arm will ever recover. Michigan corrosion is no joke. Luckily the front ones were much easier. I am definitely grateful for all the helpful things on forums such as this, YouTube, and AllData. I would be without a car if it weren't for that information.
September 22, 20214 yr 1 hour ago, aturtlestep@gmail.com said: Never worked on cars until my Impreza's CVT valve body needed to be replaced. Couldn't afford to have the shop fix it, so...researched and got up the nerve to replace it myself. Since then, I've changed all manner of fluids, replaced all the different brake parts, troubleshot and fixed a couple of different wiring issues (gotta love mice), and replaced wheel hub assemblies. One thing on my list to never do again is the rear wheel hub. Only one rear hub needed to be replaced but I don't think my slide hammer arm will ever recover. Michigan corrosion is no joke. Luckily the front ones were much easier. I am definitely grateful for all the helpful things on forums such as this, YouTube, and AllData. I would be without a car if it weren't for that information. Nothing like doing it oneself. Get so much satisfaction with getting it done too.
September 23, 20214 yr WRX got some attention, replaced discharge hose on the A/C. Best to pull out the overflow tank but everything else was easy. Used a vacuum pump, hoping to pull a little moisture out but, disappointed it wouldn't get below about 18-20. So, I may be wrong about the hose being bad (previous use of UV dye sorta hinted at it.) I'll know in a few weeks if that was it - took about 5=6 weeks to leak out last time. Maybe something with my manifold rig was leaking a little under vacuum. Need to do an oil change and install outside temp sensor (at last). want to drive to CoSpgs. The car needs other attention but, nothing that probably can't wait. Edited September 23, 20214 yr by 1 Lucky Texan
October 21, 20214 yr My 83 Brat sat for a while because reverse gear went out right when life got busy. I have a spare transmission and I finally had the time to swap it out when I crawled under the car to start and saw that the nut on the bolt I had replaced the linkage expansion pin with had come off and the linkage was super sloppy. I put a new nut on and it is shifting as well as it ever had since I got it. I'm going to spend some time coming up with a better rig job (maybe involving making a couple bushings and some locktite) and see if I can make it even better. After that I finally have the time and money to start restoring it to be a daily driver! FYI: I sold my house last year, moved into an RV, and plan on pulling my Brat behind the RV after working on it a bit.
October 21, 20214 yr made it Colorado. got some help from user lmdew with a gummy hood latch. Seems better now. I think a cool morning here was enough to make it not re-latch.
November 6, 20214 yr I had to shampoo the complete interior of my 95 Legacy ( the beater POS daily driver) because one of my dogs thought it would be cool to poo inside it while I was inside the bank...then he made sure he spread it ALL over.:-\ I mean I call it a POS all the time but that doesnt mean its ok to do THAT inside it! Teatv hello dear Edited November 11, 20214 yr by bezossjeff90
November 6, 20214 yr 4 hours ago, bezossjeff90 said: I had to shampoo the complete interior of my 95 Legacy ( the beater POS daily driver) because one of my dogs thought it would be cool to poo inside it while I was inside the bank...then he made sure he spread it ALL over.:-\ I mean I call it a POS all the time but that doesnt mean its ok to do THAT inside it! Oh man, that's awful! I haven't had the fortune of having that happen...yet.
November 22, 20214 yr On 11/6/2021 at 8:11 AM, franbev said: Parked it for the winter. Does your brat have the center high beam?
November 22, 20214 yr 1 hour ago, oczuk32 said: Does your brat have the center high beam? No, that was '82 only for the Brats. They have single headlights instead of quads
November 23, 20214 yr I actually have a third eye assembly but when I found out I would have to cut up my grill I decided not to.
November 23, 20214 yr 1 hour ago, franbev said: I actually have a third eye assembly but when I found out I would have to cut up my grill I decided not to. Plus they look funny with the quad lights vs the singles... IDK I'm a purist on that sort of thing
November 26, 20214 yr I reckon these are way better than the third light setup... They work really well too, I win many high beam wars with dipshits that don’t dip their lights to oncoming traffic! I love a good set of driving lights Cheers Bennie
November 27, 20214 yr done that "leave my high beam on to dissipate the oncoming forgetfuls" bright lights twice now, only to find it was a marked police car - learning a lesson and taking said lesson on board
November 29, 20214 yr On 11/27/2021 at 6:30 PM, Step-a-toe said: done that "leave my high beam on to dissipate the oncoming forgetfuls" bright lights twice now, only to find it was a marked police car - learning a lesson and taking said lesson on board I always dip my lights then give the oncoming driver about three generous seconds to reciprocate, then my big lights go back on until they decide to dip their lights. I’m not out to just blind ppl, they need a fair chance! I’ve had one or two occasions where the oncoming vehicle has dazzling LED light bars that are that shite even (for them) for their driver that they simply don’t see the lights of the oncoming driver until they’re basically already passed! Very frustrating! And yes, I hate the cool white of the LED lights - try driving in fog with that crap! No thanks. I’ll stick with my power hungry halogen lights Cheers Bennie
December 2, 20214 yr On 11/29/2021 at 8:40 PM, el_freddo said: I always dip my lights then give the oncoming driver about three generous seconds to reciprocate, then my big lights go back on until they decide to dip their lights. I’m not out to just blind ppl, they need a fair chance! I’ve had one or two occasions where the oncoming vehicle has dazzling LED light bars that are that shite even (for them) for their driver that they simply don’t see the lights of the oncoming driver until they’re basically already passed! Very frustrating! And yes, I hate the cool white of the LED lights - try driving in fog with that crap! No thanks. I’ll stick with my power hungry halogen lights Cheers Bennie that bright, cool white of LED makes life harder trying to read numbers stamped into engine blocks, reflecting too much white light back to the retina. I found a simple $5 bendy USB plug in light at IKEA that gives off a yellowish light. Plug it into a power pack of choice and you have a light that you cannot get in today's torches. I also dip as required first, maybe not count to three, just rely on my vision threshold before the brights go back
December 2, 20214 yr 4 minutes ago, Step-a-toe said: that bright, cool white of LED makes life harder trying to read numbers stamped into engine blocks, reflecting too much white light back to the retina. I found a simple $5 bendy USB plug in light at IKEA that gives off a yellowish light. Plug it into a power pack of choice and you have a light that you cannot get in today's torches. I also dip as required first, maybe not count to three, just rely on my vision threshold before the brights go back
