MilesFox Posted June 9, 2011 Share Posted June 9, 2011 Is that painted, or just cleaned up well? I can appreciate the effort to paint by removing EVERYTHING to do so Quote Link to comment Share on other sites More sharing options...
987687 Posted June 9, 2011 Share Posted June 9, 2011 Did the first drain and fill in my 4eat. WOW what a difference. It shifts almost perfect, and the torque bind is totally gone. Quote Link to comment Share on other sites More sharing options...
jboymechanic Posted June 9, 2011 Share Posted June 9, 2011 Ball joints. 'Nuff said. I swear, next time I buy a car, it's coming from out west. I've had enough of this rust. You're lucky the bolts actually came out. On both of my Subarus the bolts we already snapped off by somebody else. Had to carefully drill the bolts out and used longer bolts with a nut and lock washer on the end. Quote Link to comment Share on other sites More sharing options...
classicchic Posted June 9, 2011 Share Posted June 9, 2011 Had a tie rod break on me! The socket popped out on a low speed corner after about 2 mins of creaking noises as a warning. Replaced both and the lil' subes turning lighter, faster, sharper. Looked like the PO had tapped it back in and covered it with glue/sealant or something. $25 a tie rod new compared to $7 from the JY. Ball joints probably next thing to get changed. ^ Quote Link to comment Share on other sites More sharing options...
AK_Kev_007 Posted June 10, 2011 Share Posted June 10, 2011 Got rid of my old couches. Rolled the Odometer to 150K Quote Link to comment Share on other sites More sharing options...
mudduck Posted June 10, 2011 Share Posted June 10, 2011 Broke a front axle in my 89 at Uwharrie a couple of weeks ago. Replaced both front axles, put 2 new tires on the rear and some good tires on the front, washed it(first time since owning the car), waxed it, drove it on down to the Outer Banks and half way there the exhaust let loose and broke at the flange right after the cat, so i cut the pipe in half with a hacksaw in a parking lot. Went riding the beaches and and got asked dozens of times if it was a 4wd. Quote Link to comment Share on other sites More sharing options...
mudduck Posted June 10, 2011 Share Posted June 10, 2011 in my 89 I broke a front axle at uwharrie, replaced both front axles, had to cut my exhauts out from under the car when it broke off at the flange on the way out to the Outer Banks, put 2 new tires on the rear and some good tires on the front, washed it, and waxed it. Took it out on the beaches down at the Outer Banks. did about 1000 miles in 3 days with no problems other than the exhaust breaking. Quote Link to comment Share on other sites More sharing options...
987687 Posted June 10, 2011 Share Posted June 10, 2011 Looked out the window this morning and noticed how clean it is. Yay torrential rain last night. Quote Link to comment Share on other sites More sharing options...
Aurie Posted June 11, 2011 Share Posted June 11, 2011 new spark plugs, air filter, and oil change.. w00t! Next month.. DEQ! (emissions) Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted June 11, 2011 Share Posted June 11, 2011 Nice! How'd you do that? Right now my engine is covered in mud. It could use a cleaning. Is that painted, or just cleaned up well? I can appreciate the effort to paint by removing EVERYTHING to do so I repainted it. I didn't remove everything, but I had the heads off so I figured I would flop the harness over the fender, and remove everything I could, and went at it with toreador red. The hood is still the original brown color on the bottom, but due to rust it wasn't worth repainting.... Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 11, 2011 Share Posted June 11, 2011 Installed my magnaflow muffler Quote Link to comment Share on other sites More sharing options...
bigjimd Posted June 11, 2011 Share Posted June 11, 2011 Broke off an intake manifold bolt on Fizgig. Been soaking that blasted thing for 2 weeks with Kano Kroil. Oh well. Heli coil time. Quote Link to comment Share on other sites More sharing options...
jboymechanic Posted June 12, 2011 Share Posted June 12, 2011 Added a tachometer and cruise control (almost done) to the '96 Brighton. Fixed the lights in the climate control and installed rear tail gate lift shocks as well. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 12, 2011 Share Posted June 12, 2011 Added a tachometer and cruise control (almost done) to the '96 Brighton. Fixed the lights in the climate control and installed rear tail gate lift shocks as well. I gotta do my liftgate supports too where did you get yours from? they don't look hard to do at all? I just hate having to remember to push it up enough so I wont bang my head. Quote Link to comment Share on other sites More sharing options...
jboymechanic Posted June 12, 2011 Share Posted June 12, 2011 Took my off the same Outback in the junk yard that I got the cruise control from. Rockauto has them new for about $12 to $18 each under the "body - exterior" section. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 12, 2011 Share Posted June 12, 2011 Took my off the same Outback in the junk yard that I got the cruise control from. Rockauto has them new for about $12 to $18 each under the "body - exterior" section. Ah good to know they have them no big rush, man I'm nearing $1,000 spent at rockauto Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 12, 2011 Share Posted June 12, 2011 Ah good to know they have them no big rush, man I'm nearing $1,000 spent at rockauto You can also get a set pr Armstrongs from Ebay for like $25 total or something. Quote Link to comment Share on other sites More sharing options...
SubaruJawn Posted June 12, 2011 Share Posted June 12, 2011 Changed the Exhaust (made him quiet ) fixed TPS Again Changed Muffler to a 2.5" 28" Glasspack (not much Louder ) O2 Sensor Connected after so many years Lots more Work to be Done. so Little Time so Little Money :-\ Quote Link to comment Share on other sites More sharing options...
Turbone Posted June 12, 2011 Share Posted June 12, 2011 Needs more boost. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 13, 2011 Share Posted June 13, 2011 Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted June 13, 2011 Share Posted June 13, 2011 ^ you left the door open and passed out on the dashboard? Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 13, 2011 Share Posted June 13, 2011 ^ you left the door open and passed out on the dashboard? I rubbed my Outback and out popped a twin. Quote Link to comment Share on other sites More sharing options...
Quidam Posted June 13, 2011 Share Posted June 13, 2011 (edited) "Needs more boost." OK:) I've been working on an EA-82TT. I need to tack the drivers side up pipe in a couple places, then test fit in a car. The up pipe needs to clear the steering joint and shaft. I have a small power brake booster if I need it. Doug Edit: Drilled the drivers side head for oil return fitting, just like the other side. Metal tubing for coolant supply, in drivers side head. TT inspired by the EJ-20 and Twitch:) Edited June 13, 2011 by Quidam Quote Link to comment Share on other sites More sharing options...
subynut Posted June 13, 2011 Share Posted June 13, 2011 (edited) "Needs more boost." OK:) I've been working on an EA-82TT. I need to tack the drivers side up pipe in a couple places, then test fit in a car. The up pipe needs to clear the steering joint and shaft. I have a small power brake booster if I need it. Doug Edit: Drilled the drivers side head for oil return fitting, just like the other side. Metal tubing for coolant supply, in drivers side head. TT inspired by the EJ-20 and Twitch:) This should be interesting.... I see the driver's cam carrier is missing something, no? And just to stay on topic, what I did to my Suby lately: Drove it, of course! To check out the Chiricahua Mountain fire: http://www.flickr.com/photos/44982071@N04/sets/72157626823266515/with/5826367825/ ***Cough*** Smokey! Edited June 13, 2011 by subynut Put head instead of cam carrier Quote Link to comment Share on other sites More sharing options...
987687 Posted June 13, 2011 Share Posted June 13, 2011 "Needs more boost." OK:) I've been working on an EA-82TT. I need to tack the drivers side up pipe in a couple places, then test fit in a car. The up pipe needs to clear the steering joint and shaft. I have a small power brake booster if I need it. Doug Edit: Drilled the drivers side head for oil return fitting, just like the other side. Metal tubing for coolant supply, in drivers side head. TT inspired by the EJ-20 and Twitch:) do you have a build thread for this? Quote Link to comment Share on other sites More sharing options...
