Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Favorite tools and other "must haves"
#1
Posted 11 December 2003 - 06:44 PM
I am on my 4th Subaru (93 Loyal wagon 4x4 EA82 SPFI 105K).
Due to econmic restraints (read: poor with lots of kids), I am finding that I need to fix things myself, rather than pay to have
the car fixed at the shop....I am fairly mechanically inclined, and
USMB has been immensely helpful, but I am falling short on tools.
I have sockets and combo wrenches from 8mm to 17mm, and the usual assortment of regular tools. My question is: What tools
can't you live with out if you are going to do your own work on
a Subaru (i.e. specific larger wrenches and sockets, and specialty
tools). Thanks in advance for your advice and ideas.
Cheers,
Chris
#2
Posted 11 December 2003 - 06:51 PM
Duct Tape......
Vice grips.......
Hack saw.......
I didn't think there were any other specialty tools:cornfuzz:
Glenn,
82 Hatch, well it started out as one........
01 Forester, still looks like one.........
#3
Posted 11 December 2003 - 07:11 PM
8mm, 10mm, 12mm, 14mm, 17mm, and 19mm
Helps to have a ratchet with a socket in each size as well as a wrench in each size. Sometimes one works better than the other, and sometimes you need to use both to work a nut and bolt.
If you plan to change axles, a 36mm axle nut socket and a 3/16" pin punch are essential.
Hammers come in a lot more useful than you think.
Gotta have a decent set of screwdrivers too.
One of the best tools I have is kind of unexpected- it's a 2 foot long steel pipe. I always keep it in the car. Works great for putting on the handle of a ratchet/lug wrench to bust tough bolts loose, and it's also good for prying. Also could be used as a weapon- I feel better having it in the backseat when I'm driving around late at night. It's one of the most useful tools I've ever gotten.
Let's see... what else...
Vice grips and pliers of various sizes are great.
A floor jack and jackstands are essential for working with the car raised.
Damn... I got carried away there. That's $300 worth of tools at least.
Start witha GOOD socket/wrench set and a floor jack, and build your collection from there. That's how I started 3 years ago, now I have enough to totally fill the trunk of an XT.
#4
Posted 11 December 2003 - 08:03 PM
the basics tools
14, 12, 10, 8mm wrench
1/2 drive socket19mm,17mm
3/8dr socket17, 14, 12, 10mm
1/4dr socket 12, 10, 8mm
have a 7/8 offset box-end wrench for the crank pulley when doing toming belts/timing
i had a homemeade axle tool
or use 1/2 drive breaker bar with 36mm, or 1 1/8"(i think)
flat screwdriver #2 phillips screwdriver
pliers
combination 12 qnd 14mm offset wrench proves quite versatile
#5
Posted 11 December 2003 - 08:19 PM
Another guy that is in the Navy was in the shop. He went to his truck and got this can of spray. I dont know what it was, but had seriously heavy fumes. I was 5 ft from the car when he sprayed it on the front struts and I still winced and my eyes watered. It was almost instant. The rust just melted away. Forget about soaking it in liquid wrench or using a wire brush. This stuff was amazing. He gave me the can. It was "military issue" so I used it sparingly.
If you can get your hands on any of that stuff, by all means do so.
-Jack
#6
Posted 11 December 2003 - 08:24 PM
22mm socket and big breaker bar for crank pulley.
sping hook for roll down window cranks
punch for axle pins....better have a hammer too
I keep handy a 2 or 3lb drilling hammer-like a small sledge hammer
screw starters for straight and Philips heads
"six way tool" which is a painter's tool,like a putty knife only with other funtions.
Cold chisel-goes well with drilling hammer
penetrating oil for rusty bolts-PB Blaster seems to be the best(and I'm a former Liquid Wrench addict)
Wheel chocks!!!! Could save your life
same for Jack Stands!!!! nothing like being alive to tell about your ordeal.
32mm socket if you have a 4wd
other items that are in my box that have been used:
duck bill pliers
regular pliers
channel lock pliers
needle nose pliers
Vice Grips
allen wrenches-but mostly you need the large one(10mm??) for the drain plug(heads) should you ever do that
I'm sure there's a couple more oddball items too that I'm not thinking of right now.
Other helpful items:
heat-as in torch,for those really PIA bolts
air tools and compressor
test meter
thread saver-I use Permatex's silvery stuff
2 jacks
light source for under car,etc.
gloves-especially when dealing with used oil!!!!!
and once in a great while:
Sawzall
10lb. sledge hammer
beer
#7
Posted 11 December 2003 - 09:01 PM
I think the best miltary issue "spray" I've ever run across was an OD green can of "wasp and hornet killer" I swear this stuff was leathal to any form of life we could find. Probably would kill you too, but it will just take a few years...
We have been issued some really nasty bug repellant too - very greasy, and don't smell nice.... didn't work either, which sorta pissed us off.
#8
Posted 11 December 2003 - 10:22 PM
torque wrench, beam type
socket adapters
pry bars
self drilling sheat metal screws
gear wrenches
extensions
spark plugs, socket
repair manual
something to dissolve sticky green or white battery
growth -- beer or cola, quality doesn't matter
crc 5-56 best lube-penetrant found-- spra-loos at $1 stores
tow strap
duck tape
sealing foam in the can
spray silicone lube
jumper cables
fuses
wire
multi-meter
air hammer
impact wrench
spotlight
flashlight
trouble light
power inverter
air tank
adjustable wrenches
chop saw
cutting torch
welder
portapower
rivet gun
drillpress
clamps
spraypaint
angle grinder
press
pullers
battery charger
battery booster
you can also read the VW survival list @
http://www.cyberus.c...w/checklist.txt
also http://usmb.ultimate...&highlight=list
Jack and other on-board tool/part recommendations
#9
Posted 11 December 2003 - 10:26 PM
#10
Posted 11 December 2003 - 10:41 PM
I have:
Sockets set - metric and SAE, shallow and deep.
3/8" ratchet, 1/4" ratchet
1/2" breaker bar
Open end wrenches.
The most valuable tool you can have is Factory Service Manual. For all my cars but Subaru, I have every manual they ever made. FSM, Chiltons, Haynes, etc. It is a must-have.
#11
Posted 12 December 2003 - 03:56 AM
Corrosion Preventative Compound. Strong stuff. HAd a MSDS list of some scary side effects too! But eyes watering from it? hmmmmm, don't remember that. Maybe it was something else then. hmm.
Originally posted by Jack
I had a friend that did a lot of work on my old sube. I told him that I wanted to take advantage of the adjustable ride height (you can crank up the torsion bar and the struts). He pointed out that they were rusted solid.
-Jack
#12
Posted 12 December 2003 - 04:03 AM
1. sense of humour
2. (over)active imagination
3. brain that is operational
4. access to friends, USMB, and other like sources
of course a #5. would be some patience but that with a hammer is optional too... so I hear.
#13
Posted 12 December 2003 - 07:43 AM
#14
Posted 12 December 2003 - 10:29 AM
3/8 socket set
1/4 socket set
1/2 socket set
flat head, phillips head drivers
a nice piece of pipe to use as a breaker
mag light
pliers
test light
box/open end wrenches 8mm - 18mm
your looking at about $100 worth of tools at home depot...
#15
Posted 12 December 2003 - 11:04 AM
#16
Posted 12 December 2003 - 04:24 PM
[i] He gave me the can. It was "military issue" so I used it sparingly.
-Jack [/B]
jack -
check the can and send me all the info off the can. i'll see if i can get it from supply! i'll need a part #, serial no., and any other info you can give me. and i'll see if i can get it in.
#17
Posted 12 December 2003 - 04:59 PM
#18
Posted 12 December 2003 - 05:13 PM
#19
Posted 12 December 2003 - 06:26 PM
#20
Posted 12 December 2003 - 06:48 PM
This is great stuff
Cheers,
Chris
#21
Posted 12 December 2003 - 11:08 PM
have also used cold, fresh beer, hot old beer, and fresh cola, all have worked
it's a matter of what's available and convenient
the ea81 car was washed once a week
#22
Posted 13 December 2003 - 11:41 AM
I would just like to add
a good quality DVOM.
cooling system pressure tester.
compression tester.
timing light.
inspection mirror and flashlight.
magnetic pick up tool to find lost nuts and sockets.
just a few important things of the trouble shooting/ tuning nature.
#23
Posted 17 December 2003 - 01:32 PM
#24
Posted 17 December 2003 - 04:04 PM
That special brake tool is available as a universal one (looks like about a 1/2 or 3/4 inch square cube with different points on each side for different manufacturer's brakes). It's a 3/8" drive tool and sells for between 5 and 10 bucks at Pep Boys and other auto stores.
I second (third, fourth, etc.) the endorsement of PB Blaster. That stuff is awesome. A can of brake clean spray is good also for cleaning the grease, mud, etc. off your brake parts after an emergency repair.
Finally, in case nobody mentioned it, a supply of cotter pins because you know you're going to break or lose them when you're dismantling the axles.
#25
Posted 19 December 2003 - 12:00 AM
