mudduck Posted December 30, 2011 Share Posted December 30, 2011 Mounted up a set of practically new yokohamas on my 89. Man, that car rides and drives a whole lot nicer than it did with 4 mismatched tires! Fired up my old 91 and ran it around the nieghborhood. First time being fired up in around 3 months. Quote Link to comment Share on other sites More sharing options...
man on the moon Posted December 31, 2011 Share Posted December 31, 2011 I laid in the mud and ice at the junkyard today, but it was worth it. I went to puzzle out how the running lights are wired, and work out a solution to put blinker bulbs in there. I came home with that AND...a new shifter! The d/r swap into my Loyale resulted in a brown shift handle/console in a blue interior. Today I found a blue set/console so I grabbed it Totally worth the 30 minutes of cursing the ice under the car, and the headwhack and the wrench-knuckle. Funny note: the wrench knuckle came not from a wrench, but from wrestling the drive train off the transmission, I whacked it up against the bottom of the body. Oops. I'm still going to try to swap the pushbutton handle into the d/r tranny, but I can now put the blue 4wd handle in, too! And if the pushbutton thing doesn't work, I have the proper blue handle to match AND the entire related console. Quote Link to comment Share on other sites More sharing options...
xman Posted December 31, 2011 Share Posted December 31, 2011 Went from this: To this in the Brat: No fancy dyno and laptop needed to tune this baby!!! Quote Link to comment Share on other sites More sharing options...
kayoteq Posted December 31, 2011 Share Posted December 31, 2011 Set up an appointment with the windshield folks. The brat has a leak in an upper corner, only spills at speed. Long-term, that's not good. Have to replace half the body pan on my Beetle due to *internal* rot from its formerly leaking windscreen. Any nasty surprises I should be planning for? They're ordering in the specific gasket, even the windshield, if they break mine. (hopefully not) I may try to sneak some dash tweaking while the windshield is out. just reattach the loose parts somehow.. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted December 31, 2011 Share Posted December 31, 2011 Set up an appointment with the windshield folks. The brat has a leak in an upper corner, only spills at speed. Long-term, that's not good. Have to replace half the body pan on my Beetle due to *internal* rot from its formerly leaking windscreen. Any nasty surprises I should be planning for? They're ordering in the specific gasket, even the windshield, if they break mine. (hopefully not) I may try to sneak some dash tweaking while the windshield is out. just reattach the loose parts somehow.. where they getting the gasket from? didn't think they were available, would like to know if they get one or not? Quote Link to comment Share on other sites More sharing options...
PadreScout Posted December 31, 2011 Share Posted December 31, 2011 (edited) I ran engine codes on my GL today, the prognosis is bleak. The good news is after another ... 600 dollars worth of parts to get the engine running correctly then all I will need to do is completely rebuild my suspension, interior and replace some stuff on the outside of the car. GOOD PROJECT! Edited December 31, 2011 by PadreScout yes Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted December 31, 2011 Share Posted December 31, 2011 To this in the Brat: No fancy dyno and laptop needed to tune this baby!!! Your valve cover breather hoses are not hooked up right. And neither is the PCV. hope you get that fixed before you blow it up. Quote Link to comment Share on other sites More sharing options...
kayoteq Posted January 1, 2012 Share Posted January 1, 2012 where they getting the gasket from?didn't think they were available, would like to know if they get one or not? I will find out. He seemed to be nonplussed about it, I think it was about $40 plus installation. Closer examination of the gasket today indicates it needs a swappin'. He was even ordering in the glass in case they break mine. oh boy. This is a Safelite franchise, been around for years. Their warehouse might be well stocked for Subies regionallly. We shall see. Quote Link to comment Share on other sites More sharing options...
newsoobdude Posted January 1, 2012 Share Posted January 1, 2012 Finally got my Firestik antenna mounted securely in the stock Outback Limited location and also got my new Cobra 29WXNWST mounted up in the Outback. Played around with my 86 BRAT and replaced the shorty open headers on it with a replacement Y pipe (sounds killer) and took some pics of it with my 82. Got a new thermostat and gasket for the 82 as well. Want to get it all nicely tuned before I go get her SMOGed them putting on a Weber when I get to it. Pics- Quote Link to comment Share on other sites More sharing options...
zukiru Posted January 2, 2012 Share Posted January 2, 2012 "I kissed a BRAT and I liked it?" Quote Link to comment Share on other sites More sharing options...
AKghandi Posted January 2, 2012 Share Posted January 2, 2012 87gl-10 wagon finnally fixed my power windows! and in celebration a car wash and tune up for my baby fyi if the wires in the door jam arent the problem its a small blue connector with 5 red wires under the carpet on the pass side foot well mine was smashed and corroded to the point it looked like 5 red wires being connected with jolly rancher crumbs..2 pieces of wire and 3 wire nuts later and they work again! Quote Link to comment Share on other sites More sharing options...
MaddCelt Posted January 2, 2012 Share Posted January 2, 2012 Pulled and tested the coil and got 1.9 on the primary resistance test (.73 +/- 10% is norm), tested all the plug wires, changed the battery trying to resolve my 1&2 cylinder misfires. Installed interesting magnetic stem caps. Quote Link to comment Share on other sites More sharing options...
trucking45 Posted January 3, 2012 Share Posted January 3, 2012 Put a car alarm in my 81 brat today now my car is all alarmed Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted January 3, 2012 Share Posted January 3, 2012 Replaced the cup holder with another that does not rattle from a '97 Outback. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 3, 2012 Share Posted January 3, 2012 Got around to changing the T-stat housing. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted January 3, 2012 Share Posted January 3, 2012 Got around to changing the T-stat housing. Please tell me you swapped on an Alloy one from an EJ25 like I did. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 3, 2012 Share Posted January 3, 2012 Please tell me you swapped on an Alloy one from an EJ25 like I did. Nope? I got the part from the dealer Quote Link to comment Share on other sites More sharing options...
l75eya Posted January 3, 2012 Share Posted January 3, 2012 Got those cup holders that hang in the door for the loyale! Gotta find some for my GL now Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted January 3, 2012 Share Posted January 3, 2012 Nope? I got the part from the dealer Ugh, that blows. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 3, 2012 Share Posted January 3, 2012 Ugh, that blows. i've never seen a metal one before Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted January 3, 2012 Share Posted January 3, 2012 i've never seen a metal one before Really! A lost of the first gen Foresters had them, and some Outbacks. Its a hit and miss type of thing but they are kinda cool. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 3, 2012 Share Posted January 3, 2012 Really! A lost of the first gen Foresters had them, and some Outbacks. Its a hit and miss type of thing but they are kinda cool. hmm never knew that! Quote Link to comment Share on other sites More sharing options...
xman Posted January 3, 2012 Share Posted January 3, 2012 Your valve cover breather hoses are not hooked up right. And neither is the PCV. hope you get that fixed before you blow it up. Thanks, I did. That picture was taken at a stopping point before I got the straight connector I needed to lengthen the passenger side hose. I found that SharkBite brand 3/4" PEX connectors in the plumbing aisle at Home Depot are a great, cheap option for this. Quote Link to comment Share on other sites More sharing options...
kayoteq Posted January 5, 2012 Share Posted January 5, 2012 Me and the Brat consulted on the proper ratio of gearing to highway speed to mountain road incline... Did I do alright? I passed a Baja. ..while in North Carolina picking up a camper top for cheap (minus the gas) but will require a bit of re-fabrication to get it fitted. (upside down, backwards with the tailgate down and tied securely, for those wondering) He threw in a wheel as part of the deal. Now I have something to start refinishing the OEM white wheels one at a time without lacking a spare. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted January 6, 2012 Share Posted January 6, 2012 I put a honda part on mine today :hide: But it is one of the best upgrades I've done, I can see out my rear hatch for the fist time in bad weather! The arm and blade are both off from a honda pilot, I have the part numbers if anyone is interested. another pic Quote Link to comment Share on other sites More sharing options...
