All Activity
- Past hour
Subasaurus changed their profile photo
- Today
88 gl waggon spfi no spark or fuel
Issac replied to Issac's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Update found 2 burn resistors and soldered them in and it fires right up -
If (and until someone tests a pair, that's a big if) the renault ones are indeed a good fit, coilovers for that vehicle would also fit, like https://www.apmotorsport.co.uk/product-page/megane-2-rs-ast-5100-1-way . But they're waaaay out of my budget, so I haven't been looking at anything similar. If searching, be warned most seem designed to lower the vehicle, because non-subaru owners are weird.
- Yesterday
Closing the loop on this. Resetting the ECU (disconnect battery and step on the brake pedal) seemed to clear up the issue, IIRC.
1985 Brat Exhaust Manifold Gasket Size
88SubGL replied to globochem's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just a guess, but you probably need to look at ones for, perhaps ‘82-‘84, to make sure you get gaskets for an ea81. -
I got a set of 44022GA330 exhaust manifold gaskets, which supposedly is a fit for the 1985 Subaru Brat, but the ring on the inside of the gasket is a bit wider than the pipe and the engine. It's also wider than the old gasket that I pulled off of the exhaust. The bolt holes line up but the ring size isn't an exact match of the pipe size. Does this sound right? I see that there is also a 44022GA340 that is also a fit for the '85 Brat, what's the difference? The listings I'm looking at say that both are a fit for the 1.8L H4 - Gas engine.
I have a SpeedyEFI kit that I haven't installed yet, but it's basically the same thing. There are people using these over at "NA/T Subarus" on FB: https://www.facebook.com/groups/491238001237421 I hate directing you over to FB, but those are the people who've been using these on Subies. Hopefully FB will die and people will come back to the forums...
'79 Brat EJ22 Retrofit Build Thread
mka replied to mka's topic in Historic Subaru Forum: 50's thru 70's
Yeah, the initial plan is to chop and shorten the stock Impreza CVs to get things rolling . If need be later down the line I'll get some custom built but I'm a decent DIY-er in my own right so I'm hoping to get lucky and not need to outsource. - Last week
I really should be in bed. lol. But my car also needs struts, and I keep looking them up... I found what may be an exact-ish replacement: Front struts for a new Renault Megane II. Wtf, really? lol. 44.5mm diameter, 545mm/21.46in extended length, 357mm/14.06in compressed length. According to https://www.ultimatesubaru.org/forum/topic/157099-front-struts/?do=findComment&comment=1313458 , a 4wd strut is "Extended Length 21.25" Collapsed Length 14.00"". Spring diameter looks similar, bottom lock bracket is... different, of course, but may be able to be bent to the right place. Haven't seen specs on the top nut. Fairly cheap, but not available in the US, due to said Renault vehicle never being sold in the US. Some part numbers: BILSTEIN 22-132390 KYB 333718 KYB 633718 MONROE G16387, though the monroe comes up as 2" shorter than the others. The KYB 633718 seems like it might be the premium version, and the 333718 the maybe better excel-g version, not sure what's really different... you'd be installing them with all the subaru top hardware, of course - spring perch, bearing, mount. Want to buy a pair and let me know how they work? lol And now bed. really.
@bushytailsIf I get complete assemblies from Gorilla, they offer three different spring rates. So I could get firmer springs. My primary concern outside of them bolting up, is travel. I'm pretty sure sambar coilovers don't have as much travel as a BRAT. I'd love to get some used sambar struts just to see if they'll bolt up, but I have no idea where to find some. I did email Gorilla for further specs, but have yet to hear back.
bushytails replied to mka's topic in Historic Subaru Forum: 50's thru 70's
Do you have a plan for shorter CVs? The diffs are indeed essentially the same. One's probably a 5-bolt R160 and the other a 1-bolt R160. -
Drain coolant, pull a heater hose, plug off one end, hook the other end to compressed air with a valve, slowly let some in, listen for where it's hissing. If it's hissing at the carb, or out a spark plug hole...
