All Activity
This stream auto-updates
  1. Yesterday
  2. Clutch is now much easier to disengage than the hydraulic one in my Chevy S10! After fixing this array, my right front axle went out, had to drive homr in 4wd. Yet another project. Thank you all for you kind suggestions and wishing you the best.
  3. www.partsouq.com Works with many manufacturers, and can lookup by VIN. I'm a dealership parts guy by trade, and I use it all the time. Sometimes has some good aftermarket interchange info, too. www.amayama.com has some, too. It's been a long time since I've used opposed forces.
  4. Hia Havent needed much in terms of original parts of late, but now i do and the old trusty opposedforces parts fiche site is gone forever.... Other alternatives? tried to use catcar.info but looks like its not the complete set of diagrams tnxs!
  5. Last week
  6. Recycled 11 car batteries; received $5 each for regular car batteries at Battery X-Change in Beaverton and received $91.44 for 8 T-105 6V batteries or ~$11.43 per battery at Far West Recycling in Tualitan.
  7. Wish I could be helpful but do you have a part number for that solenoid you’re looking for?
  8. Awesome trip Tod! Not knowing the area at all, I can only imagine the distance and terrain covered. I love the comments from those that saw you up the top where ppl with jeeps wouldn’t consider going. Nothing unusual with that, it’s the same over here - more prissy 4wd owners than those that use them for what they’re designed to do. Cheers Bennie
  9. So awesome. I love exploring that area! The time required to get my Outback or 4Runner into a condition to confidently do that is just not on my priority list right now. So I'm living vicariously through you!
  10. I've had pretty poor luck with aftermarket ones leaking in less than a year. 25240KA041 genuine Subaru number, MSRP is $24.57. Every dealer has a pile of them (I have 15 at the moment). I used a Subaru switch on my Toyota Celica because I was tired of the aftermarket ones leaking and the Toyota one has an MSRP of $71
  11. Solved. Added some 134a and now blowing cold all around.
  12. Odd, it should not kick off from charging at all for these models. There's no ecu control if it's 2 wire so no way to tell it to power off. Do you think there's a corroded wire in the harness causing intermittent charging? If you have a spare connector, dash lightbulb, and a switch, you could make a dongle from the alternator to the battery + and manually force the alternator on to test.
  13. So my 2013 Crosstrek XV has developed a problem I've never encountered before. When using the air conditioning, I get normal cold air out of the dash vents on the right side, but warm (not hot) air coming out of the left side. Anyone have a clue on this problem? Thanks. Keith
  14. Hi everybody- This is my second post on this forum. last time was 2008!! Hunting a duty solenoid for my "New Car" back then. It's a 1989 Justy 4WD RS. I love it!! Best car I ever had. But it's broken right now, and I'm trying hard to save her. She's rusty and ugly, but fast and capable. Here's the problem: The computer has died and because I'm basically a Ludite at heart, I don't want to/can't afford to spend the money on that route, so i have an alternative plan, which is something like this: 1. Replace the distributor with a 1987 or 1988 dizzy with vacuum advance, because the 1989 has no advance controls. But there are a couple of questions re the proposed new dizzy. One ,the most important question, will it bolt up to my engine? It certainly looks like it will. Secondly, since the reluctor is different ( has only 3 teeth on it, compared to my 1989 with 3X3 teeth.) , I am wondering how the pickup coil signal might be different between those two? From what I've read, the pickup coils are the same part number, and fit a lot of other older subys as well. IE it's "common", Perhaps, considering my plan ( see) it would be a better/simpler reluctor for my purpose. 2. I am planning to connect the output of the dizzy to a GM HEI ignition module. Probably a 4 or 5 pin ( which allows retard by grounding the 5th pin. The module will then control the coil. Am I thinking right? The grounding 5th pin retards to base timing if needed, and the vacuum advance dizzy can exert its effect in either advanced( provided by the HEI module ) or the grounded base state? Most of my mileage is highway. I don't mind if I have to 'baby' the motor, just don't want to hurt it. Anybody got any opinions or advice or parts to help me move this along. I'd love to talk about it with you. Please help me save the old Justy? Any opinion re the Sorenson EL102 ignition module? Thanks, Old guy Henry
  15. OK, I was able to match up the L "light" and S "Sense" wires from the 3 wire plug to the 2 wire plug. I temporarily attached female spade connectors to the wires and hooked them up to the alternator and it was charging at 13.8- 14.0 volts, right where I wanted. Having a built in voltmeter is new to me, and I noticed on some occasions it would go down to around 12.7 volts for a few seconds, then back up to upper 13's- I assume there's no issue there, as the Duralast alternator I was running temporarily was doing something similar.
  16. I went ahead and ordered the older style 2 pin connector for my Subaru refurbished older tyle alternator. I just want to make sure I wire it in correctly. Based on this diagram- which pin on the 3 pin connector correlate to which pin on the 2 pin connector. I found this diagram of the rear of the alternator and the 2 pin connector.
  17. Earlier
  18. I think just a hell of a lot of back n forth, up n down, heat, penetrant, prayers, voodoo dolls, whatever you’ve got. Going back to the intake manifold bolts and their holes I would not hesitate to check the threads and run a tap down them, bottoming tap if possible. You’re in territory we’ve left long ago. But our memories aren’t so faded. Those intake bolts and their holes get a lot of corrosion no matter where you live and they are notoriously difficult. Given you’ve got yours out comfortably maybe you’ll get lucky and they’ll seat with enough torque again. But I would not place good odds on that happening. For sure you should use some Loctite. What I’ve done and others is use an insert, not a heli-coil. The Brand I use is TimeSerts and they’re a little more but you’ll be able to remove your bolts with ease and send them back in again. Your choice and I don’t blame you if you just use Loctite and call it a day. Just be aware those are old and we’ve been there. I would not count on any old sealant that’s been cured for ages resetting itself at this point. I thought those were just pressed in.
  19. It should work. Only models I know need all 3 pins on the alternator were the sti and XT models with the 32bit ecu, electronic throttle. If yours is cable throttle, it's the old style and only uses 2 of the 3 pins.
  20. Update- I sourced a used OEM alternator off eBay and it worked for about 2 minutes then stopped charging. Back to the drawing board. Thr only alternator they had worked all thr time is the POS Duralast unit. Just wondering if I should get an old style plug, and wire it in and use the unused ‘98 alternator or might that cause issues with the electrical system?
  21. I've been having a related issue with my intake manifold ('89 GL SPFI) I've been cleaning up. I had some seized bolts (not intake manifold mounting bolts, rather bolts that threaded into the manifold to mount misc accessories) so I soaked the manifold in evaporust. I got the bolts removed, but my heater hose pipe (p/n 14070AA011) is stuck and I cannot remove it. I worry that the evaporust may have partially penetrated the sealant. As such I'd like to remove the heater hose pipe and reapply sealant to prevent the risk of a coolant leak. Does anyone have any tips or tricks? I thought of bending an induction heater coil around the heater hose pipe near where it meets the intake manifold and use that to heat the sealant and soften it. I'd imagine a blow torch would work too, but an induction heater should produce more localized heat. Thanks :] P.S. I'm talking about the metal pipe that sockets into the bottom of the intake manifold. The larger diameter pipe, not the smaller one.
  22. Last line in my post above. Lol I might have one still. I don’t have EA82 items in general but I can picture one in a plastic multi drawer thingamajig. Don’t hold your breath though. Otherwise I would hope one of us has one or find a yard with one sitting around. Good luck and please post back with your results.
  23. Hey everyone, I’m the guy coming back a few years later to ask if they held up alright. So, how’s it goin’?
  24. A friend of ours from Houston drove up to my house a couple weeks ago and we headed up to the UP. Once we got there we stopped for pasties and ate them at a park along Lake Michigan on the edge of town. A younger guy stopped on his motorcycle and asked about the Impreza, we talked Subarus for a bit. He had just imported a 99 STI from Japan. It's funny to me, ever since I got this Impreza I've gotten a lot more questions and had a lot more people taking pictures of the car than with the other Subarus. Not sure how much of that is people's love of first gen Imprezas and how much is the fact that you don't see many turn of the century Subarus driving around anymore. We drove up to the campground along the reservoir in the southern UP. M and B showed up later. Friday we went to the rapids and then hit the mini banked oval. There was a snapping turtle at the edge of the oval. Then we wandered up to the Baraga pipeline grade. We were all entertained as usual. Hit some of the sandy stunt areas nearby and a few of the side trails. Before we got to Houghton we were on a trail in the woods where we decided to turn around. I could not get the Forester out of the ruts so we eventually put a bunch of branches and sticks in the ruts and I was eventually able to get out. Then going back down the trail I was crabbing the Forester sideways for hundreds of feet before I finally got straightened out. Headed north to Houghton and then to Gay beach. M declared it the mother of all stunt areas. Drove much farther south than we had before after crossing a narrow spit of tailings along the lake. Did some side by side uphill jumps and then decided maybe we should leave while we still could. Checked out the mine building ruins, some good post apocalyptic flavor there. Temps were solid while driving on Gay beach which is a good test of high duty cycle and low speeds. Then they crept up in the woods and we discovered one of the fan fuses was blown. The passenger side fan would turn most of the way pretty easily but there was one spot in the rotation it would get stuck. We eventually figured out there was a tiny pebble(?) stuck to the outer ring of the fan blades. We were eventually able to get it off and replaced the fuse. Later we noticed it had a slight coolant leak. We tracked this down to the small welds on the underhood heater core that attach the mounting flange to the end tanks. Rerouted the heater hoses to the stock configuration. Got up to the top of the cliff along Cliff drive. I had parked a few hundred feet back from the first overlook and when I was walking back to my car a UTV was coming up. I heard the driver blurt out “what the f--k?” when he saw the Impreza. He told me he knows people who won't take their Jeeps up the rocky climb we took to get to the top. I then walked back to the overlook and he said the same thing to the other guys. We drove to the next overlook and hard parked on the edge for some pictures. The yoopers showed up again and we talked to them for a while. “This isn't what most people from Illinois do when they come up here” one of them says while holding out his pinky finger. They had both seen different UFOs and had some story about a cave nearby that no one could find with a wall of silver and a bag of gold coins. I believed the UFO stories more. We camped at the overlook. Saturday morning we headed up to Brockway Mountain. As we pulled on to the long road going there we were proceeded by three extremely slow drivers. We pulled off on a side trail rather than test our patience following them the whole way there. This trail eventually led to a very sketchy bridge but we managed to cross it. I think it was in this area I checked one muddy stretch on foot and it didn't seem too bad so I drove through it, but I was barely able to do so and then the ruts were deeper and softer. So I told B he shouldn't come through and I didn't want to go back through so worst case we come back to that spot in a half hour. Fortunately we were able to maintain radio contact and I was able to drive around the block so to speak and meet back up with them. We eventually found a different way out of the area. At one point the temps had started to creep up in the Impreza again and a fan fuse was blown. This one was probably from the fans running while driving in deep water, we replaced it and never had the problem again. We eventually got up to Brockway Mountain from the other side. After we'd been on trails for quite a while and got back to pavement B said the Forester was shaking quite a bit. Turned out all the LR lugnuts on his Forester were loose and one was missing. We tightened down the ones we could and continued. From there we did a little more trail riding and buzzed up to the beach to camp for the night. At camp B swapped out his wheel studs on the LR hub as most of them were somewhat damaged or packed full of aluminum. Sunday we started heading back on various trails. One of them eventually became deeply rutted and I didn't think I could get through without taking off a mirror so we turned around. We came to a fairly long and deep water crossing where beavers had flooded a road. There was a muskrat swimming in it when we pulled up. I walked it and it was just below knee deep for a couple hundred feet. I drove through it in the Impreza after we removed the fan fuses. There was water over the front of the hood for a good portion of the crossing and we realized we should have stuck the gopro on. B crossed it in the Forester and then we put the gopro on the Impreza and I crossed it back the way we came and then back again to proceed. At the top of the hill right next to the stream was a cool old furnace of some kind. Later we found the beaver dam that was flooding that road. The highlight of the day was probably discovering and climbing Mt Houghton. Probably the most intimidating rocky climb we accomplished that weekend (ever in the UP?) and one of the best views in the UP once we made it to the top. Got gas and water at the Lac La Belle resort. Cashier was using binoculars to read the mechanical gas pumps. Found a silly hillclimb along the border of a wildlife sanctuary that M almost convinced me to try but ultimately we decided it should wait for a different weekend. Buzzed down to Lake Linden to camp that night so J could take a shower and we'd be closer to the portage. Monday morning we took the Bill Nichols trail basically all the way from South Range to Adventure Mountain with a few detours and stops for some stunt areas and mines along the way. M and J enjoyed the Firesteel trestles and the lookout near the top of Adventure mountain and we headed back from there. The trail west out from the Adventure mountain climb was rough and narrow but we made it through with some extra dents in the rockers and floorboards. Stopped near the end of that trail to air up and eat PB&Js. We drove down to Watersmeet together and the Impreza seemed to have some high frequency vibration that didn't go away when I put the clutch in. Cleaned some dirt out of the wheels when we stopped for gas but that didn't help. Stopped again and discovered two of the driveshaft bolts were missing from the pinion flange. I had looked before but those two must have been up. Installed some bolts and tightened them all down and had a smooth ride home. Could only run the AC intermittently on the way home or the coolant temp would creep up. Overall a good weekend, cooling issues with the Impreza are still frustrating but we all had a good time. J and M were impressed with the Impreza, especially the EZ36. J definitely enjoyed the UP and quickly got in the groove of following overgrown trails (with a surprisingly high success rate of connecting to other trails this weekend). M said it was probably his favorite off road trip we've taken, no major malfunctions, lots of stunt areas, lots of overgrown trails (which he likes). Removed the radiator after we got home and it seemed clean. I had sprayed it off at the car wash but that's usually not too effective. So I'm still a bit surprised the car was running hot on the highway. We did check the overflow at least once when it was hot and still have never seen air bubbles. After spraying the condenser out from the back with a hose wand it did become clear that a lot of the fins on it are bent over. We did go through a lot of brush so it's probably from the fan blades spinning leaves and twigs against the condenser. Should be getting a replacement today, hopefully that brings the temps back under control. Also got a pair of 80s Ford Econoline heater cores I plan on putting where the extra heater core is now for more cooling capacity.
  25. Thanks Scooby! I'll give those a try if the fuel issue diagnosis doesn't solve it. Update: I tested the pump and it seems to have good flow. After a bit more diagnosis, I noticed that when starting cold giving it some gas almost instantly kills the engine. To me that seems like it's running rich and would point to a fuel pressure regulator. I bought a new regulator off Rockauto but it didn't fit despite their website saying it was compatible. Got the Delphi part #FP10485: https://www.rockauto.com/en/moreinfo.php?pk=10910396&cc=1270134&pt=6124&jsn=1162 The only other option on Rockauto is Intermotor part #PR263: https://www.rockauto.com/en/moreinfo.php?pk=817733&cc=1270134&pt=6124&jsn=1161 Has anyone else had issues finding a regulator and, if so, where did you find a viable replacement? Cheers!
  26. I went reverse, 2006 alternator in 98 impreza. Swapped from black rectangle to green oval plugs and works fine. Though 13.5-14v at the battery is kinda of standard nowadays, it's okay for newer batteries.
  27. I got my transmissions (plural) back today. After talking to the tech they decided that they'd only do a partial reseal. They didn't want to split the case fully since they couldn't get a reliable new parts source. Only major seal that wasn't replaced was the front main seal since that requires splitting the main case. Sounds like if that job comes to a head, I'm on my own. It shouldn't be that bad, I have a FSM and a practice transmission. The spare transmission was used for some NLA seals. 33194AA001 was one. Once I get the car up and running I'll have the time to check out the spare transmission. I expect carnage. Sorry no photos. There will be photos and detailed notes on the spare transmission though. :]
  1. Load more activity
