Everything posted by Durania
Back in a GL
Which L-series are you referring to? Legacy L/Brighton?
Back in a GL
I think it's where it's got the dealer add-on AC system. I have another wiring harness that came with this from a non-AC model and it doesn't have that fuse.
Back in a GL
- Back in a GL
So, what are my options on window cranks? I've got a couple that have suffered the effects of age and the splines have stripped out on them. Did anyone ever make aftermarket ones that slid on? I've dealt with this problem on 4 different EA81s. Also, I have some replacement hatch struts but the previous owner has lost the brackets on the left-hand side one where they attach to the body. Does anyone have those laying around? Thanks!- Back in a GL
The chrome bumpers is what I always look for on these to indicate 2wd vs 4wd.- Back in a GL
Thanks! It appears someone definitely paid for the undercoating and it paid off. I've only seen some very minor flaking on the front bumper attachment points.- Back in a GL
Thanks man, I really appreciate it! Yes, it's 2WD 5MT. I'm going on vacation tomorrow for a week so I'm going to have to tackle it when I get back. I wanted to do more testing before I dropped ~$100 on one of those resistors and the one I have now definitely looks to have been replaced. Good call on the radiator.- Back in a GL
- Back in a GL
- Back in a GL
First joined this forum 20 years ago when I had an 84 hatch that I had bought sitting in a field while I was in high school. At the time, I had a 91 Legacy. Drove that till it blew up and then picked up an 83 Brat that I found for sale on here and picked up another 83 for parts. Had a 2000 RS coupe in college, then a 95 Outback beater. Sold the RS and got an 05 STi, sold it in 2016 and got back into an 04 WRX in 2022. Picked up this 84 GL 2 weeks ago as if I needed another project but I am not poor on vehicles - also have a 2019 Tundra and 2015 Rav4. This thing was in surprisingly good shape for being an east TN car. With that, it does have its issues. I have on my work bench a new rear wheel bearing to install, hatch struts, will need a radiator as I see it dripping. I am also trying to nail down why the blower isn't working. I pulled the fan resistor switch last night and it showed continuity but I need to see exactly what ohm values it's supposed to have. Nothing like reading 20+ year old USMB posts. We still like pics on here?- Here's my 1984 GL Turbor Wagon
Care to post more pics? Engine bay, interior, etc.- Valve cover leaks on 2004 WRX
Durania replied to Ramone899's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave fun doing them. I would suggest you change both sides and go ahead and do your spark plugs while you're in there. Get the gaskets from the dealer as I got two driver's side gaskets from the Amazon Fel-Pros and didn't discover this until I had my car torn apart. I did have good luck with the half-moon seals I got from Amazon: https://www.amazon.com/gp/product/B001KSASOO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1.- Ball joint removal hell
Durania replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dealt with this garbage on my 95 Outback. Both sides snapped off. Drilled the old bolt out and put this back in its place.- 2002 Legacy: Low, wavering idle, bad hesitation once warmed up?
Durania replied to 1986Brat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoing some quick googling of that trouble code, people are saying a fault neutral safety switch. http://www.subaruoutback.org/forums/66-problems-maintenance/23128-engine-light-p1507.html- I cant believe I am even saying this...but...
Durania replied to vtwinjunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, been in the same situation with my 95 Outback over my 05 STi. It was just so much more convenient to hop in the wagon and not have to worry about where I park at a store. I have recently sold my wagon and looking to upgrade to an LL Bean Edition H6 Outback. I honestly feel like I loved the wagon more than the STi that I am currently daily driving.- 98 Subaru header questions
Durania replied to That New guy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI may be wrong but won't the testing station look to see if that header is C.A.R.B compliant? If not, they may fail you. It also looks like the kit uses a hell of an angled extension piece to get the rear oxygen sensor out of the exhaust stream. That used to be a way to keep from getting the P0420 code on my RS. The idea is to pull it further out of the exhaust stream so the CEL would go off. Didn't work for me though.- Alternator upgrade options for 95 Outback
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had used a local guy to rebuild the alternator(s) for my Brat many years ago and they didn't really turn out like I wanted them to. The voltage while idling was pretty low the other day when I checked it. Was around 13 volts and from what I gather, should be around 14. The headlights will dim slightly when I hit the brakes and the turn signal will make the blower motor slow down as it blinks.- Alternator upgrade options for 95 Outback
Looking like the alternator on my Outback is getting weaker and was wanting to see about upgrade options for it. Is there a drop in replacement that is a higher output than the stock 85 amp from another model that won't require any modifications to the wiring?- Trailer wiring for 95 Legacy Outback
I recently got a hitch for my wagon and am wanting to go with a plug-n-play solution to adding trailer lights. Do they pretty much plug in to one of the tail lights and split off from there to the trailer? Anybody have one they can recommend? Thanks.- Single knock/clunk when braking
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, that is a good point to start with. When I changed my rotors, I left the pads in the calipers so I didn't have to fool with all the pins and clips on the brembo 4 pots. Just picked it up and sat it out of the way as one whole unit. May just need to get some lube in there. Will try it out whenever I get a chance.- Single knock/clunk when braking
Noticed in the last week that when braking at speeds below 55, I get a single clunk or a knock on my STi. Definitely feeling it in the front. I recently replaced the rotors with Centric High Premiums in July. I pulled the car up on ramps last night and checked all my bolts that I removed to install the rotors and they were tight. I gave them a jiggle test, did not touch anything with a socket. Aside from noticing a recently slung open inner passenger side cv boot, I am out of ideas. I did have a problem when taking the old rotors off that they were seized to the hub. Speaking to a mechanic friend, he said his STi did this when he got some rust on the hub.- Thermostat housing leak
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, the gasket is new. I do plan to replace the hose and clamps, not thrilled about using cut to fit crap. Is there a thermostat diy somewhere so I can find out if I did something wrong or not?- Thermostat housing leak
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, after putting a metric ton of RTV on this thing, I am now leaking from the radiator house where it meets the housing. I shouldn't have to use all this damn goo to make it not leak. Either I did not install the thermostat gasket right or this housing is crap. I wrapped it around the thermostat like the old one was. After the first use of RTV I started getting coolant leaking out of the bolt holes, more rtv on them and that seemed to fix the problem but I still have the coolant coming past the clamp.- Thermostat housing leak
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood thinking. Will put some RTV on it tonight at the seam.- Thermostat housing leak
Last week I finally tracked down the source of my coolant leak to be at the thermostat housing. This evening was my first change to tackle the job on my 95 Outback. Put the OE gasket around the OE thermostat and slid it back in, no problem. Noticed while filling the coolant that I still had the same leak at the housing where it meets the water pump. What the hell did I do wrong? Is the thermostat supposed to support itself inside of the water pump underbelly as in holding itself before I put the housing on? Is my plastic housing warped? I gave it a good visual inspection and did not see a problem with the housing. Open for suggestions. Thanks. - Back in a GL
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
