Everything posted by Quidam
EA-82 Oil Change, Brakes
Hey, I changed the oil and brakes about a year ago in my '86 GL DR 5 speed wagon. I changed the filter twice and topped off the oil as needed during the year. It doesn't burn any noticable ammount but the drivers side cam seal weeps a little. No leaks at all. The car has about 120K miles on it. It's time to do both again. I ran 10-30 oil last time, I put this in today: The motor would carry 45 psi oil pressure at 3000 rpm hot on the road. It's a carb motor but with good gas and the timing bumped it will rev and pull to 7000 rpm. 6000 factory redline. The car has small tires, I don't carry around a lot of stuff, and gets 30 mpg on the highway. It has no air conditioning equipment firewall foreward. I removed it all. Has manual steering rack. No roof rack at all unless I put my Thule on. That costs me a couple miles per gallon, last time I checked. I run one fan belt, tires pumped to 32 psi. Modified Hitachi, exhaust no cat. It has those light bumpers on it as well. Haven't had it on the scales, but it's light for a wagon. The brakes. I live in the hills. I'm not easy on brakes. Run through a set in a year, about 12000 miles. I had to fill the master cylinder twice during the year when the dash "Brake" light came on. I filled it two days ago. Today I got the ole front disk pad squeel:) Time for a change. Later on, Doug I've got the new pads and rotors in stock. I ordered a brake caliper kit for the right front from RockAuto. Crap. Forgot to order the rear shoes. Ordered a bunch of other stuff tho. I love RockAuto:).
Documented: The 1970 FF-1 Project car...
Yea. And, that's a big window Chevy pickup in front of the Subaru in the top picture. The back window. There were three different configurations for the rear window...windows. One small window. One small, and two side... corner windows, then the big window. Just rambling. Doug
Wrestling with your car aka The Silly Plastic Belly Pan
Quidam replied to stevetone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlastic doesn't stick to rocks. Sincerely, Doug
vintage gas
Experience...the most through teacher.
You and your Hitachi. A sordid tale of love, hate, and vacuum valves.
Welcome to the Machine...real loud:)
Paul, I messed up back there. I wanted to delete the pics...didn't need them, and won't do it again. Thanks for the reminder. I vote for #10. Doug
Need input on restoring a 88 wagon or to toss out
Restore is an over used, out of context word, mostly. You can't get what you listed for 3K, and on a car with 240K on it... I'd be bidding on the seventy odd thousand mile GL on eBay from Arizona...or something. You asked:). But It's at twenty five hundred right now.
Subaru Stuff Shop Touring Wagon
Looks like one I repaired. That one suffered a front end collision. Someone had straightened the hood but didn't replace the hood hinges. I had to massage the mounting area with a hammer too.
Looking good man. It's fun when you start screwing it back together:). Chemical strip, sandblast. Ready for primer, seam sealer, and paint. Not a Subaru of course...just don't give up:).
Justy gauges?
Hi, One thing you should know: The oil pressure sender is a BSPT and is the same fitting as some Mazda, Ford, and others. British Standard Pipe Thread. More than likely you'll be going from 1/8 NPT with any aftermarket gauge to the 1/8 BSPT male fitting that screws into the block, replacing the factory sending unit. That fitting can be bought on ebay and major speed shops. I got one in a cheap gauge set from WallMart one time. I bought it just for the fitting and tossed the gauge. It was much cheaper than the $15 to $20 I've paid on line for just the fitting. Doug
Installation of Head Gasket
Quidam replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUh huh. Wrench every day, and it becomes second nature. Or something. Zen and the Art of Subaru. Measuring bolt streach is consistantly dead nuts accurate, tho. Doug
Quidam replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"If it's aluminum, It ain't straight". Word. I'm back, kinda:) Doug
micro subaru!
Assuming all is disconnected except the trans mount, linkage, and CV...do those and pull. You did take the radiator AND the radiator core support out, didn't you? If you pull the suspension, you're doing it wrong. hth Doug
Need some help... one cylinder low compression
Yes. Cause: bore rust. No. Yes.
CCR reputation follow up
Quidam replied to CAS83Brumby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you need anger management classes.
EA82T theoretical power?
Edit:Borescoped the heads, SPFI and MPFI. /me still not clear on this point. Well, not absolutly certain on, oh NM:)
It might take me a year:) It's all about pressure. My estimate is that there's never been but a couple handfulls or less of serious EA-82's built. Built the right way. Tuned the right way. The ignition system. The fuel system. The cooling system. You mess one of these up making big numbers, that engine is toast. Run it lean, never. Too much spark advance for the fuel, never. Cooling system, you better have it together and figured out. And, a dyno is just a measuring device. Like lots of others. It ain't all it's cracked up to be. /me who has been sweating over an EA all day. Doug Edit: What I'm wondering is, has anyone here, first hand knowledge of an EA-82 block being decked?
check-headgasket: you drill and tap for head studs. you have the block align bored and decked, case halves pinned. replace the block bolts with studs. epoxy all studs in If you've done all that, it's got a chance of being reliable. Oh, 75 to 100 hp per cylinder. Doug
carb on mpfi intake?
I'm making one out of wood. Really:)
Hi, I've ran an EA-82 with dual port heads, Turbo intake...and no carb, no injectors, just an open hole. Pour fuel down the hole and fire it up. Does that count? Doug
variable gear ratio manual steering
Hi, Boot kits are pricey. About $40.00+ per kit at parts houses. Autozone and RockAuto. You can't go wrong with dealer parts if the price is right. I have power rack boots on a v/r manual rack. They are too large a diameter for the boot to rack interface. I haven't seen a problem with the length tho. One board member suggested I make a spacer to use a power boot on a manual rack. That will work. I'd be interested in what you choose to do. Doug
Hey, Weber. dual port, high compression. What are you waiting for? There's studs involved, lots of them. Huh? "ancient technology....severely simple". Simple? Think Barry Grant...all the others. so on and so forth. Sincerely, Doug
Help diagnosing my TOD
Hey Andy, Have you tried an Italian tune up? Redline should be 6000? Doug
Randomness
Hi Scott, I've been looking over wide five and I've got a couple questions. How much does your kit weigh? Adaptors with supplied studs? I've got my eye on a set of_______ wheels. First run bare steel? How thick? Sincerely, Doug
Randomness
lmao. I cringed with that text. Really. You could have used Hillbillie, I don't care:) Doug Edit: I got a network, a rifle, and a four wheel drive.
