Everything posted by Subarian
Better than bailing wire! (or how I "fixed" my tranny mounts)
Cheap is good!!!
Seatbelt Man
You'll help us help you if you tell us what year and model you're dealing with.
Push Button vs D/R 5 SPD Tranny Q
definitely dual range. Better for getting yourself out of a jam, and less likely to have a problem.
engine noise
Subarian replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLeft side, under timing cover, coolant problem- I'd check the water pump.
Why do *YOU* prefer old gens?
I have a 94 Legacy 2.2 AWD, an 86 GL carbureted wagon w/ d/r 5spd, and an 86 turbo wagon pushbutton 5 spd. My wife keeps asking me this same question, because I also have an 86 project car. I guess my answer is that I enjoy driving it more. It was and is a very unique car that combines good economy with real 4 wheel drive. Plus the fact that I enjoy keeping something running that I put together with my own hands. Having said that, the project car is definitely getting a 2.2, because there's no comparison in the power.
Now What?!!!!!!!!!
Your problem is probably not the timing, but it should be at 8 degrees BTDC on the carbureted engine. When you say it bogs down and acts like it's running on two cylinders, is there a lot of vibration in the engine? Does it do this at idle, or at a particular RPM range?
ea82 runs then dies and has no spark
Do this check. When the engine dies, short to the negative (-) terminal on the coil (with the key still in the run position). Pull the jumper away from the terminal, and you should generate a spark. If not, the coil is most likely bad.
SpeedO ? on my 87 Wagon
It's most likely the speedo. You can take it apart and clean and lubricate it.
choosing a subaru? help
Go for the EA82 wagon, d/r 5 speed. I get 27 MPG out of mine, and it goes pretty much anywhere I want it to. Lots of room for my Army stuff in the back.
LSD rear diff
GL-10 turbo wagons are a good place to look.
'92 Loyale Parts Car
If it's a 87 GL, it's probably a SPFI motor. I've swapped many parts between GLs and Loyales, and most of it is a direct fit.
Do i have a duel intake mainfold or single?
Carbed are all single port intake.
15" spare tires...
Do a search- someone on here did this a short while ago. They're really not designed to be run for very long or very far, so the rim isn't very robust.
carb alternatives for ea-82?
Actually, with the DGV the throttle cable is routed in the stock position. This is a DGEV on an EA82. Notice that the cable is in the stock position using the stock bellcrank.
Air intake questions - carb'd EA82
I've been running an air filter box from a SPFI with my Weber. I use a length of dryer duct to connect it to a plenum I built for the carb out of sheet aluminum. I'm not running any vacuum lines to the air box, just the carb (for the distributor) and the manifold (brake, vacuum contols). It seems to breathe pretty well all the way to redline.
EGR; replace, block, plug or leave alone?
EA82, Weber 32/36, 4 degrees additional initial advance (to compensate for altitude), blocked EGR, run this way for 100,000 miles, and NO knock, detonation, pinging, etc.
Twist on clicky valves
If it only does it when cold, you might be running too thick of a grade of oil. GD is correct, there is no valve adjustment for hydraulic lash adjusters.
I can't believe this thread is still alive. Bottom line is this: you can try it without making a permanent mod (see my previous posts on this topic) and if you like the results, keep it. If not, it takes about 60 seconds to undo. Oh, and if you melt your pistons, it's not my fault!
32/36 DGEV is the easiest swap. It's got the electric choke on the front and the bellcrank on the same side as the stock carb. The DFEV has the bellcrank on the opposite side.
84 High Roof touring wagon?
The 4spd also makes me think it's an EA81.
Finally built my snorkel **UP-DATE 3/8/06 NEW CARB ADAPTOR! NO TOILET FLANGE**
Cool project. Since you asked, the venturi in the carb only serves a useful purpose in the carburetor, where it speeds up the air in order to allow the Bernoulli effect to draw fuel into the airstream. On the intake, it's just a restriction to airflow, and you would be better off without it, if you can trim it out.
(Crazy Idea thread) What'll happen if...
Actually, the purpose of the coolant flow is just the opposite. It's to warm the intake charge for better vaporization and to prevent icing.
I need some help
Subarian replied to kayaba2006's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA 2.2 should fit with no problem, as that was the standard engine in the United States. Without knowing the configuration of the 1.6, it's difficult to say if you'll have to do any rewiring.
93 legacy wont start after timming work
Subarian replied to thebruce50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWoodchip, I think you're talking about an EA82 motor. On an EJ22, the timing marks will both be up, not exactly TDC but pointing to the marks on the timing cover. The mark on the rear of the crank sprocket is on one of the tabs that activate the crank angle sensor.
Where to buy metric thread inserts
Anyone know of a good place to find metric thread inserts?
