Everything posted by subiemech85
1986 GL10 Dies after warming up
subiemech85 replied to 86scuzzaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As I was saying: need to know for example my brown '86 gl-10 turbo wagon 5spd s/r pb 4x4 has ea81 engine and radiator with ea82 intake and carb and the only codes it has is 12 and 14 the GREEN test connector does NOT need to be connected to read codes!! -
turbo, mpfi, spfi, carb, ea82, ea81, ea71 you need to be more specific, as anything is possible try disconnecting maf eilctrical connector, if you use one you may have a leak on the intake side after the maf or weak fuel system, restrictions, crud -
it's convenience the wide gap seems to work fine remove plug from box and install in engine no need to set gap std. gap plugs usually around .030" for B2LM, gave up checking gap on them after about 10, buy them pack of 25 at a time
almost all ea series take or can use NGK BPR6EY-11 Y = V power s = standard 11 = 1.1mm gap http://www.ngksparkplugs.ca/partfinder/partsdefault.cfm http://www.ngksparkplugs.ca/documents/partnumberkey.pdf
cts iac
Top Ten Things To Do when....
subiemech85 replied to SovereignMK's topic in Old Gen.: 80's GL/DL/XT/Loyales...
since you mentioned it: EVERYTHING on the list + upgrade engine from ea82t to ea81 swap radiator from ea82t to ea81 replace front oil seal, dist. drive gear, and dist. replace fuel tank, sending unit, fuel lines, fuel filters, fuel pump clean rear washer fluid check valve clean front left squirter repair P.O. wiring upgrade to xt6 alt with 4g. output wire some parts are always "reserved for moving to other bodies and engines" 1. PUGS 2. LSD 3. BLOCK HEATER also forgot to mention: 16. brakes 17. flush cooling system -
What should I pay for an lsd?
subiemech85 replied to subystomper's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I bought the 3.7 and use it every day although mine came with some spare opens all for $130 -
also, which engine?? and trans?? and pics??, and outside temp! fuel pump relay mine does not turn on when too cold jumper wire takes care of the problem -
Suby Newby with a couple questions.
subiemech85 replied to 87jewbaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks like you took an '87 or newer rx 3door, installed early style front bumper, removed body kit and spoiler, painted body, 5 lug conversion, and no mudflaps sure is a lot of work to make a "not quite a RX" RX -
rx does not mean 3door rx was option group which allowed other rx only options! I was not expecting to see the 3door rx I drove for a year and sold bonus points for knowing where it is now controller: http://www.ultimatesubaru.org/forum/showthread.php?t=93326&highlight=virgin+switch search for virgin switch -
Numbchux doesn't empty his pm box
subiemech85 replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this feature is OLD I also get the e-mails -
Heating Question
subiemech85 replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
defrost works fine with mine! air cooled vw is another topic, some of them had electric defrost grid on the front window -
1. check tires: good, all the same size, snow, etc. 2. change fluids: washer, brake, trans, rear dif, power steering, engine oil and filter, NOT FRAM, halogen headlaght fluid and synthetic blinker fluid 3. replace all filters, air, fuel, oil, breathers, asv, etc. 4. NGK BPR6EY-11 cap, rotor, check wires 5. CLEAN ALL COMMON GROUNDS!!!!!! 6. adjust washer fluid sqirters 7. THOROUGH cleaning interior, engine, underhood, body, underbody, wheels, windows, mirrors, heater duct, blower box, EVERYTHING!!!!! 8. SYLVANIA SILVERSTAR headlight bulbs, correct aim 9. lubricate doors: hinges, latches, and window tracks 10. install LSD 11. UPGRADE alternator, XT6 or GM?? 12. good battery and battery cables 13. BLOCK HEATER 14. blower motor resistors 15. engine SWAP 16. RADIATOR, CLEAN or REPLACE this basically covers the majority of everything -
the relay is under the steering wheel area by the computer with other relays for headlights, defrost, ignition, etc..... I had to swap fuel tanks due to lagre amount of crud in tank, but now is good I used to have an '87 RX 3door, and sold it about a year later now I drive the '86 gl-10 turbo wagon with ea81 ask any questions you may have
hmmmm still running like poo
subiemech85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good you grabbed the dist. I may still have a few sets of ea71 valve cover gaskets -
woke up this morning to the sound of neighbor's work truck chevy 3500 duramax auto, service body stuck in the "skating rink" 4+" of snow covering 1+" of ice woke up subaru to try to help, broke nylon tow strap, tried chain, and all 3 tires spin, try brother's bronco and 2 tires spin, he now wants lsd, finally got the truck free using shovels and sand went to town during the "blizzARD" and it was near whiteout some times pushbutton 4x4 sure is nice going up the driveway hill in fwd was a little "sticky" didn't notice not in 4x4 until it wouldn't go any more trying to make the last turn, but in 4x4 no problem subaru 4x4 + winterforce snows + lsd =
I have also noticed that if the car is cold, the computer will not operate the realy, even if the test connector is connected now I just keep a jumper wire handy for this reason remove relay and install jumper wire after car warms up, replace jumper wire with relay and all is good I suggest if you are going to add a switch, to connect it to the blue and red fat wires of the relay plug so that if the relay were to not turn on the pump, you could turn on the switch which does the same function as the relay the colors may be different on your year, but the system should be the same
Survey: EA81 Oil Filter Price
subiemech85 replied to NV Zeno's topic in Old Gen.: 80's GL/DL/XT/Loyales...
since we are so good at hijacking..... purolator AA advance auto series, red textured makes removal and install easier they had a buy one get one free sale, and bought every one they had, total $ 1.44 EACH the CORRECT part number is 15208AA000 *Part 15208AA000 is superseded by 15208AA001. http://www.legacygt.com/forums/showthread.php?t=103007 http://www.ahgwa.com.au/includes/download_file.php?file=../userfiles/Dealerships/Subaru_Osborne_Park/files/Parts/Common-Parts-March-2008.pdf -
? clutch clamp force / upgrade ?
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just measured flwheel step for both d/r carb and s/r turbo 20mm hopefully we can get to the bottom of this msystery! please measure your flywheels! -
03 - 06 wrx 9 x 1 x 24 93 - 95 2wd 7 7/8 x 27/32 x 21 93 4wd 8 1/2 x 1 x 24 all other impreza 8 7/8 x 1 x 24 -
yes it is !! always wondered how many would fit up there
wrong-o skip!! fuse link feeds fuel pump relay for power circuit fuse feeds fuel pump relay for control circuit ecm grounds coil in fuel pump relay for control circuit to "hotwire" pump remove relay and jumper blue to red fat wires the colors may be different on your year, but the system should be the same
fuel pump is under car on fuel filler side, located just before the rear axle connecting the green connectors puts the computer in test mode, and cycles everything it can, including fuel pump, and waste gate solenoids to help give extra boost when really needed just lay on your back and stick your head under the car by the wheel you will see a plate held by 3 bolts 10mm socket to remove
