Everything posted by subiemech85
E82 engine with 4 injectors with turbo
subiemech85 replied to yariv232's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you may be better off putting in a ea71 turbo engine -
Idle problems. Vacuum leak?
subiemech85 replied to ytza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds like iacv -
How many of you have low mileage EA82T.
subiemech85 replied to Gl-boost's topic in Old Gen.: 80's GL/DL/XT/Loyales...
80k engine 180k everything else '89 rx -
25+ psi on regular gas, just remove waste gate line no fuel cut experienced no idea how long it will last that way
but there is still the issue of top starter vs. side starter and the ea82 series 5spd d/r would work, including the '85 models, different gear ratios a decent LOW is all I want
works good now with pics! @ http://www.cardomain.com/ride/2328831 Easy weber air box swap.doc
I decided it was time for the "regular" rectangle air filter to go away, and wanted something that would be easy to swap. It works good and you can read the write-up
Subaru on the Simpsons tonight.
subiemech85 replied to BlindSight's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I thought of posting that myself it was chief wigam making the comment, and the other white cop directing traffic -
Justy Transmission broken,
subiemech85 replied to williamhilow's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if it's ecvt, it could be the brushes -
hood pin lock on subaru loyale - Q
subiemech85 replied to moshem74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good close-up pics! http://www.ultimatesubaru.org/forum/showthread.php?t=44427&page=2&highlight=details totally functional, no factory hood cable crap, cable broke -
blame the gauge! isn't it supposed to be inches of mercury :cool: stock turbo system with wastegate line removed will easily do 25+ psi on regular gas
but the one for a ea71 will if you need one, it's yours
should have NOT happened if properly maintained
it's like an appendix, keep it until it goes bad, then get rid of it!
has anyone actually done the air box mod? if not, must invent
The overweight Lady is about to Sing.
subiemech85 replied to robertwheeler's topic in Old Gen.: 80's GL/DL/XT/Loyales...
... good bye, so long, farewell ... or bolt on a steel plate approximately the shape of {> or play kill the subie, make it jump over speedbumps, curbs, hit pot holes, and most important - make it fly -
you can also bend down the locking tabs I have one with the return oil line that is so tight it takes a wrench to turn
ah, that ain't nuthin ever look at a vw rabbit with rusty strut towers, or holes in similar area you can fit your fist? and they still get repaired and the seat rails always rust out
Anything look out of place?
subiemech85 replied to MachineAgeVictim's topic in Historic Subaru Forum: 50's thru 70's
spare and carb pre-heat air hose -
supposedbly the do exist I have a timing window plug for one do you have any parts or pictures for them?
Joy uses a spoon
1986 EA71 Touring Wagon???
subiemech85 replied to keltik's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there was a ?grey ea71 3-door discussed about 2 months ago here! http://www.ultimatesubaru.org/forum/showthread.php?t=50229&highlight=ea71+coupe -
secondary air cleaner ?
subiemech85 replied to subiemech85's topic in Historic Subaru Forum: 50's thru 70's
located in front of master cylinder blue, round, hose connected to front removed the 2 nuts, split case, separated filter with lid from housing just looking for the element
