Everything posted by subiemech85
Help - Electrical Power Loss
subiemech85 replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
NO!!!!! BIG MISTAKE IT BLEW FOR A REASON FIX THE PROBLEM BEFORE YOU HURT SOMETINNG THE FUSIBLE LINK IS MORE THAN JUST WIRE, WIRE WILL NOT BLOW AT 180 AMPS DON'T SAY I DIDN'T WARN YOU:cool: -
blower quit working...couple questions
subiemech85 replied to teasdam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check all fuses in fuse panel the resistors in the air duct often break, search for resistor -
pop the tab that is on the bottom of the grey cover with your finger as you pull straight up the tab is on the coil side, see diagram I checked carb and turbo -
you may have blown a fusible link it's a black rectangle box near the battery, pop the cover off, remove each one and check for continuity best place for new ones is the junk yard good luck sparky to see if the starter is crap run a hot wire to the male connector, the small one to hotwire the igniton, run a wire from battery + to coil + -
"local connections" $5 each, bought all 4
i thought all ea81 blocks were the same?
subiemech85 replied to snowstormer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here is the carb and intake manifold swap I did http://www.ultimatesubaru.org/forum/showthread.php?t=24564 -
subaruclub.NET worldwide subaru forum
subiemech85 replied to observer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Question on Vacuum Hose Routing
subiemech85 replied to Mudboat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah, don't you NEED a GENUINE SUBARU PCV valve hook up dipstick side valve cover fresh air intake to filtered air port in air box hook up oil fill tube side vavle cover crankcase air to pcv valve plug all vacunm ports EXCEPT for the choke / secondary and distributor advance, connect those to intake manifold make sure base timing is at 8* with advance line removed and plugged, and engine at 800 rpm -
for those of u that work at subaru parts
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I called payallup subaru 253 286 5900 $29.95 subaruparts.com 24.73 + 7.95 shipping -
hanes is fairly good as far as showing you the connections and componets, and they have good diagrams you need the grey book the red book is good up to 84 the blue book is the one before the red book, ff1 era
bump for the day shift still looking for one -
I did order a svx one the "too lasy to check the book" issue happens most of the time I just buy the oil drain plug gaskets from them, they keep them behind the counter in a box of 1,000? computer cross reference? http://www.defa.com/finn_bil.php3?lang=&ndid=&heater=240 should do the trick -
will a subaru engine run backwards...
I was just thinking the ea81 being timing gear, as in the brat it seems to not want to hold on compression when the rear is pointed downhill, would there be the possibility of it running in reverse rotation? a diesel engine will run in reverse rotation if you slam into sometning, dock, while in reverse -
please look for a block heater and cost the "MORONS" at ramsey subaur in des moines 18006696400 weren't very helpful when I asked them for one for an 83 brat, so the next day I called them for one for a svx, and the called me back saying $43 any "GOOD" parts person should know they use the same thing :cool:
EA81T - Which Oil Weight?
read the owner's manual, there is a warning about oil for turbo engines, and the recommended oil -
the worst you will do is remove the engine head threads when the stud comes out
ea81 had NO water cooling ea82 does have water cooling
A mate removed the distributor and how It wont start
subiemech85 replied to Bro's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check the timing, should be 8* btdc, hook advance line to manifold helps -
if it smokes, it may be the seals in the wastegate, no big deal good move replacing the auto, it's crap
mine will do 70+ in 5th low although the rear 1/2 driveshaft is out, it was a "BET" it won't
