Everything posted by subiemech85
gizmo between exhaust and engine?
subiemech85 replied to lukr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am guessing it is the resonator, a type of quieter, looks like over-grown sausage stick you can remove it just a guess, vauge description, no pic -
80+ when cold 40+ when warm 15W40
20 X 1.5 is the size
Engine Steam Cleaning....
subiemech85 replied to Alexx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes and yes you got ripped off -
gettin annoyed!! help??
subiemech85 replied to subawoohoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
remove emissions controls REMOVE EGR, install block off plate remove all lines from carb except supply and return remove and plug all lines^ connect vac guage adjust idle speed and timing tuneup change fuel filters make sure carb linkages work, lube make sure manifold bolts and carb is tight, good seals -
Horrific Gas Mileage, Or Broken Gauge?
subiemech85 replied to Skipper47's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I noticed it was a Loyale, just thought it would help, since it is newer than most talked about here! any other newer Soob here., from the new gen most cars have accurate idiot lights that I have driven -
I believe your ? belongs in the newer gen! most gauges lie, but the IDIOT LIGHT should give you about a 50 mile warning, consider it a feature -
filters gas air oil magnetic drain plug spare car!
close by there says block model heads and block are also marked, underside look here http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b7a4f46.89471656/&FileType=Article&File=ARTICLE_3f53a13f7c7491.41102012.art ignore the huge vast quantity of white space between the two sections
it's the one after the dash board curves down, but before the speaker
lets fresh air in from outside, no blower faster you move, more air you get from one of the ones means only one air outlet doubles as the vent
New Forum? Sticky maybe? Or slippy maybe?
subiemech85 replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
maybe there should be tabs for each engine, as a quick search, somehow automatic? -
turns on the vent, it works on ONE of the ones, middle, IIRC, pass side
Uh-Oh!!! Looks like your butt made it to a non-existent page! Try again, Buck-O!! from the ilnk of WRXchic
I like mine with a standard milton hose connecter on it re-die your threads on the tester, replace 0-ring for sealing use long 14mm thread, with rubber hose ext, short threads don't "catch" properly
Need a "4wd" decal from the back of an EA82
subiemech85 replied to syphon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
want a quality reproduction, close to stock as possible! -
Supercharged 4 Cylinder?
subiemech85 replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there is no belt on that blower, it must remove power! -
GM alternator conversion
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1971 - 1985 GMC (All Models) (exc. orginial 80- or 100-amp.) 105-amp Alternator Conversion Kit Kit 71ZX0646U $34.99 Delco alternators, used by GM and others, including massey Freguson, Allis, Deere, INT, start looking for what you want, basically all the same base unit -
Subaru Leave No Trace
subiemech85 replied to Wrench Wench's topic in Meet n' Greet. Your USMB Welcome Center
the ultimate leave only one trace, your footprints! follow the outdoor code, be a member for life -
it was at last winter's play, I was ticket taker. girl on right is actually the drama coach, spanish teacher, Mrs. Alice Jeners
2005 Calendars for sale, 23 left!
subiemech85 replied to Subafly's topic in Old Gen.: 80's GL/DL/XT/Loyales...
when do the calendars start?, Feb is quickly ending don't know if you received check yet? -
bad rock chip in windshield, golfball size fix by cooking egg with hair dryer put magnetic sign on side of door that says Possum Lake bird sanctuary
