Everything posted by silverhelme
- 3rd cracked windshield in 2 years..
BRAT taillight lenses, anywhere?
The right hand side is still available here http://www.subaru-parts-dealer.com/ for $97 and the lens for both the left and the right. I ordered the lenses last year and thy had both in stock. If your housing is in good shape it is easy to change the lens but you will need to make your own seal if yours is bad (I used foam door seal).
'91 Fuel Injectors interchange
silverhelme replied to silverhelme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHas anyone thought about machining adapter bungs to use standard injectors and rails on the EJ22? I doesn't look like it would be all that hard.
silverhelme replied to silverhelme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is the information I was looking for to start with. As a retired mechanic I've dealt with "rebuilt" injectors and as a rule have found that the quality is lacking. Most of the time good used ones are a better choise as long as they haven't sat and varnished up.
silverhelme replied to silverhelme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBy local you must mean Spokane, a 240 mile round trip. That would be the nearest place with a rebuild shop. As far as used injectors, you take you chances with those also especially when they have sat for a while.
silverhelme replied to silverhelme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI may need to flush the fuel rails as I am seeing garbage on the ones I am pulling out. As far as a local shop, there is only one and I used to work there. I was the second best mechanic there, the best mechanic and I retired and the 2 kids that got hired I wouldn't trust to change a tire much less work on a fuel system.
silverhelme replied to silverhelme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I installed the motor it had 2 dead cylinders that turned out to be stuck injectors. when I started hunting for injectors i found that the ones I have are the expensive ones. Now I have one more that is giving me problems and was just wondering if the manual ones interchange,they look the same except for the pintle. NAPA wants $134 and the cheapest I can find elsewhere is about $75 for rebuilt.
silverhelme replied to silverhelme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's great. It's only a 240 mile round trip to the nearest pick a part.
The '91 Legacy uses 2 different types of injectors, one for automatics and one for manual transmissions. Does anyone know if they are interchangeable? The one for autos is about twice as expensive as the manual and from the pictures I have seen they are the same except for the pintle that covers the tip. Anyone know if the manuals can be used in place of the autos without changing out the fuel lines?
3AT just quit on me
Have you actually disassembled the pump and checked for scoring on the faces?
Ej swapped loyale staring issues
It sounds like a candidate for a relay mod for the solenoid.
3AT just quit on me
I would assume that with the length of the shaft and the amount of fore and aft slop built into it, it is because of movement. I would imagine that there is some flex as well, which would actually shorten the shaft minutely each time it is used as well as lengthening when it is shut off.
- BRZ Radiator for ej swap
3AT just quit on me
As long as you have it out and easy to reach be sure and adjust the 2-3 band. It's easier to get to on the bench but not terribly hard in the car.
3AT just quit on me
If it was me I'd put the diff off of the no reverse trans on the one with the bad diff with the shaft that has intermediate wear. I've pulled the trans changed it over and reinstalled in the car in a little over 4 hours. Hardest thing is saving the gasket between the trans and the diff.
3AT just quit on me
I have found that with a well maintained trans in my Brat I get 29-30 mpg highway and 25 in town. It didn't change when I changed engines to an 1.8 ea82 SPFI but I tend to stay on top of tuneups.
MSD Atomic EFI, Any Experience?
Probably not a good replacement as they are designed for a minimum of a small block chev and probably flow at least 600cfm. That is way more than a 1.8 Subaru needs. Then you have the problem of adapting the 4 barrel design to out manifolds, they are made to replace a Holley 4 barrel.
3AT just quit on me
As I said you can just change the shaft although I would drain it and pull the pan then remove the transfer case and check the pump. You need to disassemble the pump anyway and and look for scoring inside. I generally don't just reassemble the without I installing new clutches and bands while I'm in there. They are an easy transmission to work on, similar to a Ford C4 reversed. I think Rockauto still has most of the parts for them.
Project Scubaroo (picture heavy)
Be sure and document how you do the extra injector. This is an interesting build although I wonder if the same thing could be done with an ej22.
SPFI factory training manual and other stuff
I'm sorry to hear you are not going to post these in PDF. I tend to collect as much information as I can so that I can so that I can pass it on to help others with there Subarus.
3AT just quit on me
Yes it can be pulled and replaced without any problem once the engine or trans is removed and the converter is taken out. Just be sure and reset the converter correctly when it goes back. A stripped pump shaft would cause your problem but it also could be the splines in the converter or the pump. I've seen them fail for no known reason but a seized pump would cause it.
Brat rear-ended! Need rear taillight lens
Do you need the lens or the whole assembly? If you only need the lens try these http://www.partswebsite.com/subarucatalog/?i=2&make=153&model=2028&year=1983&type=parts&act=new_subcategory_hp§ion=137&catid=30201&subcatid=30734&fl_id=49. I ordered a left and a right a year ago and they work fine.
Ea82 rear wheel bearing tool?
I have had some that came apart with punch and a couple that took a 3 foot breaker to get loose. Sir tools used to make one under the part #SU 022 and I think OTC used to make one but I could not find it in a quick search. I had a buddy make one from a bad 1/2 drive socket and a couple of pieces of flat stock welded to it. It worked just as well as factory.
What does a brand new 81 Brat owner need to know - The Basics
One of the things you need to look out for are your friends. I loaned mine to a friend who just had to go and test the 4 wheel drive. I got it back with dents in half the body panels, a broken shock and water in the gas tank ( don't know haw he did that one ).
4 lug redrill for my loyale
I am not for sure why this has never become a popular modification. It seems like it should be fairly straight forward job with the only thing that needs to be farmed out is the lathe work to mill the hub for the center of the wheel. Maybe someone needs to document it well enough so that anyone can do it ( lots of photos ).
