Everything posted by beataru
Gear oil question
You can Use GL-4 or GL-5 (I prefer GL-5 and also mobile 1 synthetic) and the tranny holds 3.5 qts, at least thats what my owners manual says....
help, brake rotors
I think they gave you the Turbo model rotor.
Head rebuild cost question
beataru replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo me, that seems a bit steep, although you are going with comp valves those should not offset the price that much. A Suggestion would be to take it to a local machine shop and ask them how much it would be for them to rebuild your heads for you, also, they can determine what needs to be replaced and what does not. As far as keeping it stock or performance, it sounds to me that you dont want to go all out since it will also be a daily driver. Are you thinking about increasing the revs by a bit? if so then get slightly stiffer springs but remember revs break rods. (Im trying not to say what I would do, but just take all of this as a suggestion)
Turbo problems??
If your not hitting fuel cut, whats the problem? are you positive this is a problem or is that pancake finally getting the air it needs.
Everyone thinks I'm crazy
That thing is pretty, your not crazy, people think your crazy for not doing what they tell you to.
the electric fe coupe
Wow that thing is rad, and 40 miles range, thats good for a home made electric mobile, great work.
delete
I take offense to that... well actually it is the generation about 2 years behind me that seem to write in their essays with U and ttyl and other crap like that... and I hate texting... it takes forever, and yes I try T9 and it works for crap too!
Increase legroom in 87 gl?
Haha how about mounting the front seats in the rear mounts? that would give you some more leg room
UAFC: Ultra Air Fuel Controller
Make me one too, and while your at it, send me a SAFC for me too!
Im still at a miss as to why we cant just slap on a ej series MAF sensor and go from there.
That thing seems way more complicated than an SAFC. Its fairly cheap though, but I think that for the money an SAFC would be the better one if you had to depend on it. Thanks for the insight though, it makes more options out there known.
GL hard to start when cold
Do a wet Compression test now. That will show you if its valve train related, well basically it will tell you if the low value is the rings fault or not.
I Got Gen 3 Heads!!!!!!
Anything is possible on any motor, it just requires money and alot of it. I dont know if your local machine shop could do everything, why not just go in there and ask them. Theres a machine shop right by my house that my bro in law took his RS heads to and they assembled the brian crower this and titanium that. Anyways, I dont know where exactly to take them to get them welded up but a machine shop guru should know.
Ram Engines again...
Thank you, thats exactly what I am about! I dont have the cash right now to dump into an EJ, now people would ask "not enough money? its not that expensive" true, but if and when I get an ej engine wether it be in the blueroo I have now, or some Impreza L or somethign like that in the future, I will build it up, and I will build it up right. 165 hp for an EJ25d is great, but not enough for me.
Project: RAMROD (wrx TDO4L Port and Polish) !Dialup!WARNING!
Hey I appreciate all of the support and ideas. When (if ever ) I get this thing made, If it is decent design I will have it ceramic coated, assuming I have the money of course, and I might get header wrap for it and possibly a turbo blanket. I washed the beast today.. Its so nice to have a clean car, although my inside needs to be clean, Im mad at my self for letting it get this dirty . If I do ever get this turbo spooling again, and redo my intercooler setup after that, all in all it should be a quick wagon. Im not asking for much, just a 12 second car :-p
XT hunting we go now..... heh I doubt theres one down here, or one that isnt on its way to the smasher In a turbo charged system you want, and it will always be this way, the turbo to be the largest restriction. I could, and probably will, step the header size up after the merge collector. Idk its a long road ahead.
Actually thats far too big for this engine to spool my turbo.
Ebay Clutch Kit. Should I?
beataru replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Clutch Kit looks fine to me, NTN is a good bearing manufacturer. I doubt youll beat the price. Well, maybe. Go to town!
calling all boost guru's
beataru replied to ninjaben43's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat I ment by underpressure is meaning, when the system is under boost it leaks. Sorry for the poor terminology
Radio Antenna replacement 91 loyale
The hardest part about changing an antenna is when you have to route the new wire behind the dash, the mounting of the antenna wont be hard at all.
Vibrating againare you serious?
beataru replied to chadwick35/04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldnt run in circles, I would do 4 wheel burnouts have you considered what I saied about the exhaust?
it runs...but it has a miss....
Make sure the new old disty has the screw in it.
Oil Seal Installer
Generally you would get a socket that fits over the seal perfectly, dont forget to lube it with oil, and gently pound it in. The rear might be a difficult one to find a socket for
Help! FrankenWagon is down! Starter failure after clutch job
Rebuilding starters was one of our competencys or whatever their called at EVIT for auto electrical.
Ea81 blown headgasket?
I say headgasket.... Check the water pump weap hole.
