Everything posted by 86BRATMAN
Timing belt or something else?
Happened on my celica last fall, the rotor button screw had simply backed out.
welded front diff?
Worst comes to worst you can keep an outer cv end of a dead axle in the car and swap it out if you need to drive it on paved roads.
'93 EJ22 going into my '92 Loyale. Motor thoughts?
They are different from the toyotas, I've got an 82 Celica Supra I've been toying around with for the last few years. I'd much rather play with the subaru.
Help me win ROTM?
86BRATMAN replied to cal_look_zero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI liked it as well, don't know if there was more to do or not.
How heavy is a 4EAT, will it fit in the hatch?
86BRATMAN replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI go about 160lbs, and I could do an ej22 by hand like that too, before my middle back went to crap... Wonder why that happened:dead:
86BRATMAN replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell its still heavier than me, lol. That sounds about right though from when I did the one in my 93 legacy
1989 GL Hatchback 4WD
Yes, thats the one.
The Subaru Search and Rescue Thread
That is one beautiful hatchback. I want your radio console, can't find them anymore around here.
If it has factory front struts you have height adjustment. The torsion tube will have the adjustment point on it either way.
my lifted subi
looks good man, what size tire you running under there, forgive me if I missed it I'm on a smartphone lol
the hatch model remained basically unchanged after 84, should be all familiar territory for you.
has anyone swapped a ej25 turbo into their ea82 car
honestly that's what I was thinking, but you're roughly 300 miles away according to Google maps
Alternator rebuild or use a Mod?
Honestly I don't know, I've never had a gen1 vehicle so my knowledge is limited on them.
If it were me I would look to the better option long term. Which parts would be more plentiful in 5 years should you have similar problems again. If you aren't dead set on keeping it original the mitsubishi option may be a better alternative.
2nd transfercase rigs
Something tells me a garage lift would have been an easier option to get those pics. But they really did turn out well with the sunlight
Real horsepower from A 2.2l
which ej25 pistons are you running Ivan, I've considered building a destroked ej25 but couldn't find anything one the compression ratio
83 GL Clutch Replacement
Well, technically the engine doesn't have to be removed. When I did my XT I unbolted the motor from trans, exhaust, and moved it forward to where I could get the clutch and flywheel off in car.
General Disorder has said the comp ratio of the ej251 with ej22 heads is well over 12 :1
I have nothing real interesting to say here, but where in VA are you located?
EA82 T.P.I. has no top end power
If you can get me the part number off yours I'll see if any of the maf's I have at home match it, I have a few laying around.
- The One Behind the Wheel! (Pics of Us!)
#48 and #50
I can easily see me getting to that total, hell I'm a few days away from 30 and I'm on 14, working on #15.
what size hex?
86BRATMAN replied to Suba_GL_87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA T70 would be a torx bit, while it would still work I could see the possiblility of damaging the plug.
what size hex?
86BRATMAN replied to Suba_GL_87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX14MM should be the one you need.
I think i have owls!
86BRATMAN replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRubbing rear brake pads or ebrake shoes? My nephew's eclipse does the same type noise, but it started after him and my brother adjusted his ebrake cables a few months ago.
