Everything posted by cobcob
EA82 LIFT PRE INSTALLATION advice please
cobcob replied to mykingcrab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
:eek: Good Lord you're right!! :eek: -
Can I sue the DOT for salting the roads?? PLEASE?? Seriously, enough to make me cry over my poor lil Brat ya know??
I reckon it'll never work, you'd better just give the whole shebang to me (car and all) and walk away:grin: -
Finally got around to uploading them!! Clicky
FINE!! I'll measure mine when I get home tonight...
LOL... that Toyo got NAILED!! I wouldn't count it as drifting though...
I believe standard backspacing on the Toyota rims is in the neighborhood of 3.5"
Have A Sitdown with Your Subie
cobcob replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've learned to carry a piece of wire with me. Has a female spade terminal on one end and the other end is stripped. That way if/when the key switch refuses to start the car I can put the key to "on" and jump the starter directly off the battery:headbang: Came up with THAT plan after realizing that talking her into starting doesn't always work -
strange button
cobcob replied to C150867's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Why bypass the relay? It's there for a reason! -
Brat- uk how much is it worth?
cobcob replied to rockhopper's topic in Old Gen.: 80's GL/DL/XT/Loyales...
He'd probably get that much for it down our way (SW MO) In the US prices really vary a LOT depending on what part of the country you're in... Tough to gauge!! -
Lovin the air horn!!
You'd have to adapt a summit racing or similar universal gauge pod I think... Certainly not anything specifically for the hatch
Where to Find Fel-Pro PT Head gskt
cobcob replied to Joey Joe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
worst case you can order online through O'Reilly Auto parts (http://www.oreillyauto.com) -
Ok, need to run this by folks better then me
cobcob replied to Tcat55371's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you using Fel-Pro Permatorque head gaskets? I believe other brands of head gaskets (including the OEM ones) require re-torquing after a certain length of time... -
Comin' at'cha like a whirlwind... Courtesy of yousendit.com (file transfer website)
KYB GR2 for 85 RX I need P/Ns-soruce???
http://www.kyb.com/catalog/2008_passenger_car.pdf 234046 - Fronts 341065 - Rears -
A HUGE thanks to Mellow Yellow for coming over tonight and helping me out!! Wound up being a combination of the timing being wrong and the distributor being shot. She's running great now!! Just have to bleed the breaks, re-fill the power steering fluid, find me some belts and I should be driving her real soon!! :clap:
Can someone get me the a sketch of the profile of the rocker as well as a length? I can program the waterjet at my work to cut a replacement out of stainless, carbon steel, cold rolled etc. and then bent on the brake If there's enough interest I might be able to get a limited run done here for a reasonable sum! (I need a set for my Brat soon I think)
I think you've got that angle covered! I'll go for the 6 lug conversion by drilling the hubs, slap some nice rims on her and a custom body kit... STREET BABY YEAH!! (more likely I'll leave it bone stock and drive her till she drops)
I'm planning on getting into it tomorrow morning with the intentions of having her drivable by the afternoon! first step will be charging the battery up and then confirming that I've got everything set/timed/located properly... Fingers are crossed that I'm going to get lucky! Definately swing on by if you have the time! I'll be home all day!
That's a European and Australian 14" alloy... as to where you'd get a set? Good question, I've only ever seen 1 set and that's on Roxy, Mykingcrab's RX sedan
Need some toilet reading material!
cobcob replied to SuperchargedRS's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How To Keep your Subaru Alive (pdf format) -
Joy's Brat... Interestingly, the first few appearances it was painted black...
