109
Everything posted by Numbchux
	beefaru had issues with running a one-piece in his wagon on some serious high-mileage stuff....but I might try it here before too long. I should have it up off the ground to do a wheel bearing here in a couple days, so I'll try to get a picture of the bracket I made.
	that's what I'm running. Loyale shifter/knob with '85 hi/low shifter on my RX trans. he pretty much got it. as for the wiring side. 2 wires to each solenoid, one gets grounded, and the other is switched power. when the power wire is turned on, the solenoid opens and let's the vacuum through to the diaphragm on the trans.
	I'm not exactly sure if I'm understanding you completely, but I'll say this. the tranny cases are NOT the same. the bearings that the input shaft ride on are substantially larger. AND there's a "hole" (a little more than just a hole.....but you get the picture) for the low range shift linkage. while it is possible to assemble an EJ D/R trans, really the only reason to do it is to swap in EA parts (low range gears....locking center diff). if you're content with EJ ratios and an EJ LSD center diff, just buy the whole trans from overseas and be done with it. also, even a heavily modified gearbox isn't going to get you much of a gearing advantage. if you really NEED low range. nothing made by subaru is going to help you.
	not all FWD impreza 5MTs are 23. late '94 and '95 ones had 25. FWD legacies all had 25, FWD AT imps all had 25 too.
	the EA82-length springs compressed to fit on NB Miata front shocks made the rear of my wagon sit about 4" higher than stock, and would not compress.....zero travel at all. So I bought a pair of Monroe shocks for the EA82 to run until I can get my hands on shorter springs (I'm going to skip right to the Ground Control setup.....when I can afford it. and then I'll continue to experiment to see what shock will work best).
	other way around
	highway miles are as hard on axles as anything (if not worse...). on my AA high clearance lift (4" at the struts, 3" on the drivetrain) I did ok, but as soon as I cranked up my front struts (had adjustables from my '85), I'd start killing front axles. probably 60% of the front CVs that failed on my cars, failed on the street.....usually on the freeway.
	Napa timing belt part #25-050275 from here: http://www.rs25.com/forums/showthread.php?t=75177
	I would not go any higher without doing a body lift too. the adjustables already put your axles pretty much at the max...... I ran 215/75r15s on my 4" lifted '88 and only had a little rubbing while beating on it, with very little trimming. and 235/75r15s on a 3" lifted '88 with a bunch of rubbing and a lot of trimming..... you're probably already at ~2".
	no, struts were not on that list. interchanging them is very possible......not a direct bolt-on, but doable.
	EJ front struts can be used in XT6s......so I would assume the reverse would be true. front axles, hubs, bearings, knuckles and brakes all have to come from the same car. but if you wanted to, you could use XT6 stuff on the imp. EJ trannies are a different length (shorter?) than EA ones. and the center carrier bracket is very different from one car to the other. so you'd have to use the imp's driveshaft, and it would have to be modified. but the slip yoke and flange at the driveshaft are the same..... like gary said.....the rear is an enormous project, with zero advantages (inferior parts to pretty readily available EJ stuff). Just run up to UPull, and get a rear disc setup off of one of the dozens of early Legacies....
	+1 pretty sure that's the only way to do it.
				problem starting EJ22t after swap (resolved. now other problems)
Numbchux replied to s'ko's topic in Subaru Retrofitting
the large gauge white wire goes to the battery. the yellow one gets a switched, fused 12v from elsewhere in the harness (this is for the voltage regulator, one of the wires going to the EA alt fits the bill just fine.), and the black one gets grounded if/when the yellow one has power and the alt is not charging (i.e. ign on and engine not running, engine running but broken belt, or failed alt....this wire is optional, I don't have it hooked up in mine.). -
				EJ22 wiring harness fun
Numbchux replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yep, look on the bottom of the page. there should be a reference to which plug is which (the letter), and where the pins are on the plug (number). also, the Chiltons manual is pretty much a photocopy of the FSM....but here's the real FSM diagrams (for a '92 legacy) for ya: http://www.numbchuxconversions.com/Files/FSMs/92%20Legacy%20Engine%20Wiring.pdf and a clearer version of the pinout that's in my write-up: http://www.numbchuxconversions.com/Files/FSMs/1992_Legacy_ECU_I-O.pdf -
				will EA82's run on 3 cylinders?
Numbchux replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not really any question now. but my buddy drove his '86 EA82 (carbed, now sitting in my driveway waiting on an EJ22) over to my house with the passenger side cam seized and belt broken.......yea, they don't need all 4. -
				any interest in a borked RX tranny?
Numbchux replied to soobscript's topic in Old Gen.: 80's GL/DL/XT/Loyales...
could be. it'll be getting a drastic overhaul anyway...I'd need the front ring and pinion though too. I'm not sure it'd be worth paying for shipping. but if MilesFox could bring the whole thing over, it might be worth playing with. -
^AFAIK if the crank angle sensor wasn't working, it wouldn't get spark either. but, I am curious as to the history of this motor. was it out of a donor car? running before pulled? -
	suberdave put HIDs in his wagon. search for his post.....lots of information. the problem with EA82 headlights is the lense. the diffuser wastes a ton of light. so regardless of what bulb you put in there, most of the light will be wasted. ALSO, HIDs really need to be behind clear lenses. and obviously EA82 subaru lenses are far from clear. prepare to blind everyone else on the road I've been thinking about what it would take to make a clear lense for them (I would LOVE to have HIDs with angel eyes).....but have come up empty-handed
				Beefaru's in Minnesota ........ yah!
Numbchux replied to BeefaRu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
crap. I was down there last weekend. if you have some free time, and want to head north and check out beautiful Duluth.....let me know. otherwise, if you're still around on Friday, you could stop in at the weekly MNSubaru hangout in St Paul on University Ave. map thread I won't be there, but you're sure to see some pretty high-hp subies (look for the white STi with the turbo in the bumper...) -
I'd be interested in the center diff and it's housing, and what's left of the driven shaft. I'd like to piece together a hybrid trans, and that's pretty much all I need from the RX trans. I've got a line on a good one locally, but it'd be a shame to cannibalize a good trans just for a few parts. -
	yea...no pictures of any corvettes this was kind of a last minute event. I wish I would have known about it earlier, or I would have posted here.....we weren't too far from you Iowa folks. there were about 6 of us there in subarus, and 3 friends of mine in Mustangs (and one other stang owned by a guy I'd never met before). brought my wagon, got laughed at at the entrance gate, then proceeded to put down faster times than most of the vettes. so phooey on them!! top 3 official times were put down by one of my friends in his '05 STi, an '07 R32, and some integra that looked like crap and sounded worse.....but in some free lapping afterward, the top 4 times were all subarus. video of my third run: my pictures I was having trouble getting my camera to focus, so I got a ton of pictures that looked like crap. but this one was worth posting. I believe this was just moments before Musashi (guy who won) swapped ends for the third time in the same run :laugh: and all the guys from the MNSubaru club. I'm the one with the big hair, and Musashi is holding his 1st place hardware! more pictures as the other guys post them.
	not a whole car to replace your loyale. but a whole car to donate the motor. please read the write-up. it took me 6 months to compile it, and I'm putting more time into it now to keep it up-to-date. it will answer most of your questions. you need a lot more parts than just the motor. and if you get a complete car you'll know you have everything you need, and you'll be able to hear the engine run before you mess with it. AND, first gen ('90-'94) Legacies in perfect shape for donating a motor typically sell for only a few hundred dollars anyway (look for ones with damage, rust, blown transmission, etc.). And those motors are good for many many hundreds of thousands of miles (mine's got almost 270k on it now, with only very basic maintenence on it).
do you have a full FSM for the legacy? that has all the info about testing the sensors. I'd start by checking the power. the #2 and #4 injectors share the same power source. I'm pretty sure that's the only common thing between the 2.
