15
Everything posted by bratman18
USMB Shirts 4 Sale at WCSS
bratman18 replied to ShawnW's topic in Meet n' Greet. Your USMB Welcome Center
I will definitely be interested in a couple shirts when you offer them post WCSS. -
DIY Front wheel bearings - worth it ??
bratman18 replied to Dee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wouldn't hurt, but at the same time, if money is an issue, or whatever, now you'll know how to get everything apart, so replacing the axle won't be a hrad thing to do in the future. -
Thanks man! It's a fun ride, still plenty to do though!
Pics dude!
Tap on the axle with a piece of wood as a buffer while holding out on the lower part of the hub so that the axle has room to move. -
I just like the way black looks on silver. My winter wheels are black too. And I got a great deal on these, so it was hard to pass up.
Very nice! I have actually considered doing this to mine too. What prep did you have to do for it to stick? And yeah, aren't those Kartboy hangers great?!
Congrats!
+1. Listen to the people that have done this time and time again. You're making this way harder than it actually is. -
Well disconnecting the sway bar would be a huge help, so see if you can borrow the right socket, or wrench. As far as the punch, try a pair of dykes, or diagonal wire cutters, grab the punch with them, and pry against the axle cup and it should pry it loose. Or maybe tap on the roll pin and see if it will punch the punch back out.
tallest 13 inch ofroad tire available?
bratman18 replied to stinkydogfilms's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pretty sure 185 80 13 is the biggest. -
Put it through the knuckle first. Undo the sway bar where it connects to the control arm, and you have the inner control arm bolt removed right?
remove the inner control arm bolt, and the swap bar where it connects to the control arm, that gives enough swing for the axle to be removed from the hub. -
A t3 or t4 would not be bolt on. Sounds like you have a bunch of research to do. If you put on a different turbo than what was on there, or different than stock, you also need to have it tuned. There is really a fair amount involved with all of this, so make sure you learn as much as you can about your car, and what it had/has.
Nice pics! I like the look of those tires. I wonder of they make them in a 16". Pretty sure the 215 70 16's I'm running are about the same as the size you're running. Does the offset bother you at all? That's one thing that I don't like the look of with mine, the wheels sit in too far, especially the rear. I have thought about eventually swapping to GD style control arms and lateral links to widen it out a bit.
Glad you got it worked out! I thought that might have been the issue after you posted about the different plugs/terminals. It just made me remember the issue I had.
It would be worth checking. And I may be wrong about it, I just know that I had to mess with them on my Brat.
That may be your issue. The connectors may not be in the right positions in the plug. I ran into this when I used that type of headlight. Do you know if they worked right before you swapped them out?
Looks great! I actually had the same idea for paint when I had those style wheels. Any plans for any lift?
As he stated, he has bigger tires, so the actual speed was 65mph, but his speedo showed 60mph. Congrats on the trouble free trip!
