Everything posted by bratman18
Nico's 1986 Subaru Leone Turbo
I really hope this get's completed!
plow car ?
- Mustache Bar Bushings
I just added another set of wornish washers/bushings onto mine and had good results.- Replacing 2.5 with 2.2 - What's Involved?
Haha sorry Chris, I didn't read it quite right.- Replacing 2.5 with 2.2 - What's Involved?
Just curious, why is that? The 2.2 flywheel will fit the 2.5, so why wouldn't the opposite work?- plow car ?
I did it with my BRAT. Worked great, pushed snow pretty easy, even my whole road after 14" of wet stuff. I have a friend with a first Gen Legacy wagon with 6" of lift, Outback tranny and diff for the lower gears, swampers and a plow. That thing pushes snow nice!- 5 speed to 6 speed ?
bratman18 replied to SubaruJawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy Forester?- PUGS on the way!!! Will a 2" lift do?
Chris, those 205 75 14's that I had on that car measured 26 1/4 when they were brandy new!! and they rubbed a tiny bit. 27's will rub a little bit more, but not too bad.- 5 speed to 6 speed ?
bratman18 replied to SubaruJawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can just change the transmission, driveshaft(out of an auto Outback) an a matching ratio rear diff. I spent 2750 on my 04 STi 6 speed for my Forester. You can use a 5 speed clutch for an 02-05WRX, and you can find a non DCCD 6 speed as well. Really not that much work, it will all bolt right in, but yes, TOO much money and not needed in an Outback.- 97-98 Legacy Intake Mani on 90-94 Heads
They are Cometic gaskets, not cosmetic:)- BMW M5 V10 Powered Subaru Impreza 2.5RS
bratman18 replied to Pooparu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone posted this on my local forum. The video of it is pretty insane. All though, not a boxer, it is still pretty awesome, and the work behind it is great as well. And it goes!- 97-98 Legacy Intake Mani on 90-94 Heads
^Lol. I think you have some learning to do, or maybe just more experience.- ea81 to turbo ea82 swap?
search around on here, you will find your answer about the EA82T- My '95 Legacy: Trashwagon10
All I'm saying is it seems like you have a bad attitude about everything now. Just hope all is good, and hoping things get better if it isn't!! Keep up the work on your cars, and good to hear that this one is running good again.- Gas filler neck alternatives
bratman18 replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepends on the car. 99 wasn't the only year they used that type of filler neck. But it sucks, the filler necks with the valve are stupid expensive compared to the older type!- My '95 Legacy: Trashwagon10
Actually, I used to like reading TheLoyales threads on his cars, but seems that has been his attitude for a while now....................Dunno what happened, but definitely not the same.- ATV Tires on a lifted Subaru
Just because the ATV doesn't weigh that much, doesn't mean some of the aftermarket ATV tires aren't rated for that much......- 2.0 turbo question
bratman18 replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can reuse your stock head bolts- My '95 Legacy: Trashwagon10
And just because there is no CEL, doesn't mean the computer hasn't thrown any codes- ATV Tires on a lifted Subaru
Actually, as I already stated, some of the newer, larger ATV tires are rated fore the weight.- Hood mounted radiator?
That was this one http://subarubrat.com/- eBay Timing Belt Kit Questions
bratman18 replied to Tmb9862's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a deal!- My '95 Legacy: Trashwagon10
That grille will fit between the headlights just fine, but will NOT fit with that bumper. The Outback and GT style grilles need their own style bumper as the grille itself is taller, and needs the cut out in the bumper for it. So if you changed to an Outback or GT style front bumper, the grille would slip right on.- ATV Tires on a lifted Subaru
A lot of the newer ATV tires are rated for a lot of weight, easily enough for an older Subaru. They have many in 14" rim size too.- Axles, what's the diff?
bratman18 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot all OEM EJ axles are green. I have seen black ones, and they were OEM originals - Mustache Bar Bushings
