Everything posted by Kostamojen
1974 1400 coupe on ebay aus
OMG If that was here in the US i'd hit the buy it now right now
Anyone have info on the FF-1 1.0L motor???
Horsepower, torque, compression ratio, etc.
Im doing ressearch on US-spec subaru motors and I dont have any info on this engine. Does anyone have any specifications for it? heres my list so far, let me know if you see any errors: http://www.ultimatesubaru.org/forum/showthread.php?t=57925&page=3
Gen 1 BRAT price range
I dont think it will appreciate much if at all, but it wont depreciate any either.
Subaru Engine Designations
Kostamojen replied to Steve B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didnt know there was a 1000 engine. Thats probably the EA52. Know any info on it? Fixed the EJ18, that was a typo. I'm not including the E designation until I get both designations. Ill try to check on that one at work tommorow. Theres only one EG33, so the D doesnt really matter. I added it anyway. Are you sure the EZ30-R isnt EZ30R? Ill check tommorow too, but it shouldnt be the same as the earlier model considering the major differences.
Kostamojen replied to Steve B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry to bump this, but im working on a more complete/accurate list of US subaru motors. I need a hand with the engine codes though, check and see if you see any errors (sorry for the formating, its an excell file changed to a .txt): The first line was just a way for me to organize.
Exhaust Hangars
93-06 Impreza. A little update to this, I went to replace the two that hold up the muffler (I just did the one at the tail pipe) and the two by the muffler are about a cm longer between the holes... So its not quite the same as the stock impreza ones, However, Kartboy does make "extended" hangars which will work for those.
Exhaust Hangars
I dont know if this is common knowledge or not (I just tried searching, got nothing) but I was just looking at my Gen 1 exhaust and noticed that the exhaust hangars were getting bad. I am going to get a new exhaust soon, but I dont want to re-use old hangars like that. So, I had some of my stock Impreza hangars sitting around. I pulled off the old one, and what do you know, they might not look the same but they have the same holes and dimensions and are 100% compatible So if anyone needs to replace their hangars, they can just use hangars designed for Imprezas, even the aftermarket ones like Prodrive or Kartboy if you want
2 1969 360s for $1600 on Craigslist
This one? (minus the hick of course ) http://cgi.ebay.com/ebaymotors/1967-Subaru-Sambar-RARE-Truck-Runs_W0QQitemZ260017612740QQihZ016QQcategoryZ6737QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This one is better: http://cgi.ebay.com/ebaymotors/Subaru-360-2-Subaru-360s-Convertable-2-Stroke-Deluxe-360-1969_W0QQcmdZViewItemQQcategoryZ6467QQihZ012QQitemZ220014669348QQrdZ1QQsspagenameZWDVW
Exhaust time!
I thought about side pipes, but I already have a side pipe since theres a hole in my muffler and its spewing out the side Its making scorch marks on the paint, so I'm not sure I want to go that route, and im not sure how to fit the muffler doing side pipes too...
Rock climb video
Sucks, if that diff was working you would have made it
Exhaust time!
Alright, I'm planning on replacing the exhuast on my '78 4X4 wagon soon... What setup should I go for? I'm open to anything. I'd like it to be pretty unique. Cost isnt a huge factor, but I'd like to stay at $300 or under (the going rate for the exhaust shop im using to have one muffler with resonator installed is usually around $200) Since theres no cat, I can technically do anything I want even though this is california I probably need to keep it somewhat quiet, so straight pipes are out of the question. The one thing I DO need to keep is the stove-pipe piece, but I figure that can just get wraped around the curve of the exhaust leaving the head. I plan on taking it to a local muffler shop I use often and having them build the whole thing using a new design, and they have access to mostly magnaflow mufflers I believe. I was thinking 1" pipes from the heads, and if I do a Y pipe, make it 2" after that (running two seperate exhausts is also a possibility) but I'm pretty much up in the air on that... So, lets hear some ideas!
Vintage Koni suspension available
If they are indeed "inserts" then they shouldnt sit that much lower, since ride height is mostly based on spring design... I wouldnt mind a lower ride height unless it makes the fronts sit lower than the rears As for the rears, are you sure they are inserts, or are they the whole strut? The rears are what i'm most concerned about getting replaced.
I still need to know if they will work for the 4X4 models first Im fairly certain my rear struts are shot.
Any update on this?
3.9vlsd to 4.11non lsd..
Just use the ring/pinion from your old diff on the new diff and you wont have to change anything else. I've got a 3.9 VLSD WRX diff on my 4.11 RS tranny in my L via that method.
lifted 79 brat on sacramento craigs list (barter)
Hmm, wonder what exactly has been done to it...
pristine 1977 brat found in PAP
I know the guy who has the VIN plate from the first Impreza ever made for the US
Alternator swap question... '79 Brat to '75 coupe
I dont know if this will help, but I am using an alternator from a '76 EA63 on my '78 EA71 no problemo...
why are offroad foresters so rare?
Ya, I think its the price of Foresters. Even the '98's are still pretty expensive, and they dont have a low-range either in the US... The 80's subarus are a much cheaper option here. I'd setup an off-road forester if I had like $10k sitting around But there are other projects i'd rather do first, which is probably the case for most people...
Advice : 76 DL
Its been re-painted it looks like. But if you dont buy that car you are an idiot!!! Its in VERY good shape for a 76!!!
I could use some Service Manual info for my Offical Curb Weight list...
I noticed in some of the FSM specifications lists that the actual model designations were not listed... Rather hard to decipher at times, especially the new Tribeca info (the whole 5-seat/7-seat thing was super confusing) And if anyone else downloaded any of the older Specification FSM PDF's let me know! I could use them for this thread.
I havent seen any Justy specifications anywhere... Do you have a Justy manual that has curb weights listed?
Wheres my edit button so I can update this?
