Everything posted by GLCraig
Early-bird Friday PDX to WCSS Thread
I've found this way to be a bit quicker between Reno and Klamath Falls. 395 to the turnoff for county hwy A3, near Janesville. Continue on A3 until it meets back up with 395 395 to Alturas 299 to Canby 139/39 to Klamath Falls
hot forester.never seen this before
GLCraig replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI once saw a Forester that the owners left in low gear when they towed it behind their motor home. The results were not pretty.
6:00 am??? You're getting soft in your old age Mike. Didn't you me and GD leave for WCSS6 at like 4:00 am?
WCCS 12 Site and Location are Set
Is it what I think it is?
Double rallycross weekend in August
Need a co driver?
93 loyale water in trunk
I'm guessing you have a sedan with this answer. Sometimes the sealant used between the taillights and body will dry out and crack. Allowing water to get in.
What to get on my License plate?
pwrwgn
Road Trip to Phoenix
That may have been a better way to go, considering it took an hour to get across Hoover Damn.
This is the route I took on the return trip. It's a better drive going this way. http://maps.google.com/maps?f=d&source=s_d&saddr=I-17+S&daddr=33.782572,-112.131958+to:W+12th+St+to:US-97+N+to:I-5+N&hl=en&geocode=FV6g_gEdFFlR-Q%3B%3BFQIoeQIdUo_Q-A%3BFRyohAIdLo-9-A%3BFUB3vwIdAQ6t-A&mra=dpe&mrcr=0&mrsp=1&sz=10&via=1,2,3&sll=33.702635,-112.447815&sspn=0.794015,1.783905&ie=UTF8&ll=41.376809,-121.245117&spn=22.875689,57.084961&z=5
There are a few things out there. Take a look at the pics I put up on facebook.
I'm on they way home now. I'm staying tonight in Vegas then I'm driving to Klamath Falls in the morning, that's going to be one long stretch.
Rings and Bearings for under $127?
GLCraig replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor rings and bearings, do you really want the cheapest parts you can get? Remember, you get what you pay for. Have you tried looking on Ebay?
Well I'm one day into the trip and all is well.
Next ORG RallyX--May 30th
I will not be back from Phoenix by then.
Crappy fuel economy, crappy power?
GLCraig replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you O2 sensor is indeed bad, your fuel mixture is going to get really rich and that second cat is not meant to see that much unburnt fuel. This can cause the cat to get too hot and melt or break apart. If changing the O2 sensor dose not make a significant improvement, you next step should be inspecting that second cat.
New to me Hatch
Well don't hold back on the details of your plans, inquiring minds want to know.
GLCraig replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat sounds like some kind of an exhaust restriction. Sometimes the catalytic converters will break apart and clog up the exhaust system down stream. Disassemble your exhaust and shake out the sections. Also do a visual inspection of the cats.
Official 2.5 mpg thread
GLCraig replied to CaptEditor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1. 18mpg City, 30mpg at 55mph, 25mpg at 65mph, 22mpg at 70mph, 19mpg we I'm having some fun. 2. 2009 Impreza STI 3. DOHC Turbo 28,500 4. 6-speed Manual, DCCD, Front LSD, Rear LSD 5. Mobil-1 or Castrol Syntec in the engine, OEM fluids in Transmission and Rear Diff 6. Stock 7. 245/40-18 Dunlop SP Sport 600 (OEM Tire) about 30% tread left.
I'm leaving on the 24th for Phoenix. Anyone down there I should drop in and say hi to? Here's the route I'm taking. http://maps.google.com/maps?f=d&source=s_d&saddr=I-5+S&daddr=Aultman+St+to:33.450296,-112.0706&hl=en&geocode=FZh4vwIdOgyt-A%3BFRrxVgIdohUn-Q%3B&mra=dme&mrcr=0&mrsp=2&sz=17&via=1&sll=33.450305,-112.070289&sspn=0.006221,0.013937&ie=UTF8&ll=33.47899,-112.022095&spn=0.398041,0.891953&z=11
EA 82 MPFI with no knock sensor
If I remember right only the MPFI turbo EA82s had the knock sensor.
Shocks & Struts - suggestions?
GLCraig replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou really can't go wrong with the GR2s
i keep hearing about a fwd fuse
GLCraig replied to 97ej22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf a Subaru Legacy/Impreza is equipped with an automatic transmission; there will be a fuse holder inside the engine bay without a fuse in it. If you sick a fuse in it, your transmission will only work in 2WD.
mythological JDM ea82t ?
They did exist at one time but finding one from an importer will be a challenge.
5 Speed D/R Strength Question
You would be better off finding someone who can make you an adapter plate, to mate the EJ33 to your existing transmission.
Wheel Bearings ea82/81 swap.
The front wheel bearings are the same for EA81 and EA82 but the inner seal is different. If the set of bearing that you are referring to are already in a knuckle, getting them out without damaging the bearings maybe challenging.
