Everything posted by GLCraig
'86 stereo - MP3 in?
If you can find a working tape deck, one of these works just fine. http://www.amazon.com/Belkin-F8V366-Mobile-Cassette-Adapter/dp/B0001V2MF4
why dont we have cop cars like this
GLCraig replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor a while the Clark County Wa, sheriff's department had an unmarked WRX. They were using it to bust street racers, because no one would suspect a WRX would be a police car.
teh East Coast meet: Carlisle 2010 thread! Its on!
You know I'm still thinking about driving out.
It's Official, I've Joined the Dark Side (more pics added)
GLCraig replied to GLCraig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I just got back from a trip to the beach with the g/f. I've had the STI almost a year and it has over 23K on it. Here are a couple of pics from this weekend's adventure. These were taken on the beach at Tierra Del Mar
Anybody know what this is
It's one of the pieces of a synchro, the FSM calls it a synchronizer hub insert. Missing one will cause some problems shifting gears. About 12 years ago I had a 80 hatchback that would only shift into 4th gear after making a sharp right turn. When I drained the transmission before doing a transmission swap I found one of those on the magnet.
nothing exciting but I did oil changes on all 3 of my subarus today.
Anyone Planning on going to Carlisle this year?
Well I've scheduled the time off to make the trip out there if I decide to go. If I do end up going, there's about a 25% chance I'll drive my 84 wagon and a 75% chance I go soft and take my new Impreza.
New Struts for 94 Legy?
GLCraig replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can find a lot of suspension information about the 1st gen legacy on http://bbs.legacycentral.org In my personal experience the GR2s will raise your front suspension about 1in. For stiffer springs, I tried some front springs from an 97 OBS and it did stiffen the front end without increasing the ride height.
+1
Subaru Meet in the Seattle area?
Okay I've finally have a few pics for you guys.
Dash warning lights?
Those symptoms usually indicate the voltage regulator has gone bad inside your alternator. Use a test meter to measure the voltage at the alternator connection with the engine in the 2k to 4k rpm range. The voltage should stay below 15 VDC. Also test again with the test meter set for AC voltage. It should not read more than a few tenths of a volt AC.
hey it was fun seeing the gang, I'll try and get some of my pics up soon.
90 loyale 4x4 vibration + power loss.
Manual or Automatic transmission?
valve adjustment
Download this PDF, the info you need in it. http://www.worldwidecm.com/HTKYSA.pdf
EA trans to EJ Motor
I do not think anyone has done that yet because the EA81/EA82 3-speed automatics had enough problems with the far less powerful EA81/EA82 engines. There are adapter plates that are intended for mating a EJ22 to an EA82 manual transmission but since this is for a trike you probably will need an automatic. If there's enough room on your trike, a 2wd 4EAT, 4-speed automatic, from a 90-95 Legacy or 93-95 Impreza would be a better option.
it looks like the G/F and I will be heading up a day early and playing tourist. See you guys on Sunday.
FWD manual transmission
if it has the starter mounted on the side, it's a 5 speed.
Cig lighter socket doesn't have power--is there a fuse?
GLCraig replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubarus generaly require the ignition switch to be in the "ON" position for there to be power at the lighter. If there is not any power when the switch in in the ON position check for a blown fuse.
Put me down for a maybe, if you guys can push the time out to noon it would increase my chances of being there. The subaru that I would bring would depend on the weather.
My *new* (old) shop toy.
That's almost the same Logan lathe my dad had when I was growing up. Were you lucky enough to get the draw bar and collets for it? Also did it come with a couple of extra gears for the gearbox? The lathe my dad had, used to two different sets of gears to drive the quick change gearbox. One set was for regular machining and the other set was for threading.
Head Gasket, $2900?!?-need mechanic!
GLCraig replied to reelst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour Mechanic maybe giving you a high quote because he dose not want to do the job or he padding the quote in case the heads need to be replaced. I do not know of anyone around Salem but here are two shop in the Portland area that can do the job right. http://www.mttechsuba.com/about-us/ http://www.fixmysuby.com/
Annual Hatch Patrol Xmas Tree run
I'm working this weekend, you guys go have fun in the snow.
Electric Radiator Fan
The Fan on the left when facing the car, is an optional fan that gets installed on Subarus with air conditioning. Turn your A/C on and see if that fan turns on. If you do not have A/C, someone must have wired in that fan and you'll just have to figure out how they did it.
Fun with beemers
You ain't old
Why can I not go any faster?
When you rebuilt the carburetor, did you replace the secondary jets? If you did, did you replace them with the same size jets?
