Everything posted by erik litchy
Stereo Installation Finished!
erik litchy replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you forgot to tell us how it sounds. -
Possible Engine swap for "92 Loyale 4WD?
erik litchy replied to Bruman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what about the XT ea82 the regular one had Dual port heads and a mutch better designed intake manifold. also look into a muffler, the stock one is restrictive. mines off a XT as well. -
PCV stink/High idle/Blowby probs.
erik litchy replied to markman34's topic in Old Gen.: 80's GL/DL/XT/Loyales...
have you done a leakdown test? -
yes they only go in from the deck. the wristpin snaprings subaru uses are a pain to use though
my car spat out its timing belt today
erik litchy replied to erik litchy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
new tensioners and it was tighter than the old belt -
why not use one of these http://www.ingallseng.com/parts/38100.htm
Where to find an EA82T rebuild kit
erik litchy replied to diluded000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
for the less than the price of rebuild you can get jdm engine so i dunno -
A lot changes in 20 years...
erik litchy replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
give it a go -
the very top tip of the fork the only reason i asked is becasue the parts computer shows a spring there.
is the top of the fork supposed to have a spring? what does it attach to? mine never had-is missing? i ordered a bolt 773028050 and forgot where it goes. any help?
Oil pressure/main bearings
erik litchy replied to pyromanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
im guessing its because theres only 3 main bearings instead? thats an excellent question -
how do you blow a IH engine? hydrolock it? those motors are made TOUGH TOUGH 345 or 392?
do you have the right distrubitor already? it would be easier to just use all parts from a carbed engine.
i suppose its possible you have to make a spacer since the throttle body on the spfi has coolant running through the base. it would be better to use a carb manifold in that case becasue then you could use a 2bbl. what are you trying to do?
im not sure what you mean by that
the most id do is change all the seals. have you rebuilt transmissions before?
whatever you get synthetic always seems to make the shifting smoother. in any manual i have ever owned. this stuff is great but expect to change it every so often. http://www.racerpartswholesale.com/redtech4.htm
id call a lot of used car dealers and see what company they use. im sure there is someone alerady heading out that way. lots of times when i worked at the ford dealer when the trailer was full they would use a driver and the cars that didnt fit on it would have to follow along. but that was using the cheapest service they could get.
'88 EA82 SPFI: engine repair options
erik litchy replied to dgsav's topic in Old Gen.: 80's GL/DL/XT/Loyales...
maybe one of the 3 oil pump relief springs went bad? thats my guess. how are you loosing coolant? does it go into the catch can? if you let it sit does it go empty?
