Everything posted by ccrinc
will 1996 2.2. fit into 90 legacy? issues??
ccrinc replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe left head IS different on a '96. In '95 they started putting an EGR pipe on that head. If you take the intake with the rest of the engine, it'll work. Your exhaust pattern is different however. The '90-95 EJ22 was dual port exhaust: from '96 on the exhaust is single port. Won't mate up to your current y-pipe, so grab that too. As for the ECU and wiring, it should work together ok. Use the engine wiring harness that's with the intake, and plug it into your main wiring harness. (Check the configuration of the plugs first just to be sure.) I think the ECU will work with it. Stands to reason: you can replace an EJ25 with a '95 EJ22 thru mid-'98. Emily http://www.ccrengines.com
Timing Belt Jumping?
ccrinc replied to WAMB00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess you might consider the difference as being "off" time and "jumped" time. But, point taken. Emily http://www.ccrengines.com
ccrinc replied to WAMB00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat I'm wondering is how an EJ25 can have "jumped timing" and have no valve damage? These are so sensitive to timing issues that if the timing belt is off by 3 teeth, it's already jumped time and you'll have internal damage of some kind. While I agree with the hydraulic tensioner probably being the culprit, if the engine is undamaged, he's really, really lucky. Another possibility is a cam trying to seize. That's common too. Incidentally, the EJ25 isn't exactly a bored out EJ22. The blocks are nearly identical, but the cylinder castings are simply made bigger. Emily http://www.ccrengines.com
legacy LE AWD touring wagon?
ccrinc replied to turbomatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlenty of touring wagons. I was told that about the LE series only. Emily http://www.ccrengines.com
How come these pistons not look the same?
THe new ones are either EA81 or EA71 pistons. Emily http://www.ccrengines.com
Purchasing a Legacy with rebuilt 2.2L
ccrinc replied to recurve's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe '99 Legacy had a one-year-only, interferential 2.2L engine. Sort of a hybrid between the EJ22 and the EJ25 SOHC engines. All in all, it's a good engine, but when it fails, it fails catestrophically, and suddenly. $4500 is not a bad price at all for a '99 Legacy. You could do better if you were in a different part of the country, but for NY State, not bad. Emily http://www.ccrengines.com
Total Engine Failure at 107k?
ccrinc replied to snaffle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA bad knock sensor can, and without repair (spell that "replacement"), WILL cause an engine to fail! The knock sensor effects the mechanical workings of the engine. The EA82 turbo engines were especially prone to failure from having a bad (or aftermarket) knock sensor. As for metal in the oil, "analysis" is over the top for that. A simple draining of some will show you immediately if there's any kind of metal in the oil. Don't need a lab for that! IMHO, these are two things that fall into the KISS principle category: Keep It Simple (subsitute your favorite "S" word here). Emily http://www.ccrengines.com
ccrinc replied to turbomatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have two of them! Identical, in fact. Only 67 numbers different in the VINs. I've had one for 6 years: It's my baby, my favorite. Got the chance to pick up another last week for $1200. Almost in as good condition as, well, as my other one. Basically, I bought it for spare parts, but I'm having second thoughts about that. I mean, who in their right mind would essentially part out a car that rare?!? There were only about 50 of the Turbo Touring Wagon LE models made! And Josh is right: none of them had the 5 speed. Frankly, as much as I love to drive a stick, on an every day basis the automatic is great. Very sturdy, and very responsive. (Doesn't hurt that mine has a shift kit in it ) So, my big question now is....what do I do about the '92 SVX that's also sitting in the driveway? I mean, a gal can only drive one car at a time, know what I mean? Sigh...to become a car-a-holic at my age is, well...is a heck of a lot of fun! Emily http://www.ccrengines.com
93-94 Turbo with a non-t auto Trans??
ccrinc replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLarry, I'd be wary of putting a non-turbo auto trans in that car. The turbo internals are heavier to handle the torque from the turbo engine. Plus, the gear ratio is different. It will work in the short term if you swap out the rear diff also, but it ain't gonna last! (Especially not with a kid driving it.) Emily http://www.ccrengines.com
98 Outback Legacy Limited Rusty Engine
ccrinc replied to Pinny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you are up for making a road trip, call Steve at Inca Auto (part of Strictly Subaru Automotive) at (303) 436-1700. He can usually fix you up for a really reasonable price. Emily http://www.ccrengines.com
ccrinc replied to Pinny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs a mother and grandparent (who's very familiar with these engines), I'd personally recommend you look for a pre-1997 Legacy or Impreza. The EJ22 engines in those are extremely reliable, the AWD is great, and they'll be less expensive to run and insure. Emily http://www.ccrengines.com
Help!Resealed engine...zero oil pressure..FIXED!
OK, this is reaching, but...waaaaay early on, we had one that had kinda the same problem. A "past" employee had rebuilt it without putting a new o-ring on the pickup tube (or it was mangled or damaged in some way...I forget exactly what. I've slept a lot since then.) Mickey is also a good possibility, or if you didn't use a Subaru Genuine Mickey. Emily http://www.ccrengines.com
Wanted: Justy Carb rebuilder or EFI stuff
No guarantees, but try Kerry Gallagher at Roo Builders. (rubuild@aol.com) I think he may still have the right stuff sitting around. Emily http://www.ccrengines.com
SVX Review & Photo Shoot...
ccrinc replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Vicky. There's a '96 that's almost identical at our shop that's for sale . (Not mine.) An SVX can be scarey-fast. And, yep, it handles like a dream. Emily http://www.ccrengines.com
Turn corner..oil light flickers...
You would not believe how many engines we've replaced because "my son ran it out of oil"! The very first thing I've taught every kid we've gotten a car: check your oil here, your tranny fluid here, your tires like this....you get the picture. AND, read your owners manual! How do you know how much to put in if you don't know how much it holds? Kids...geesh! Emily http://www.ccrengines.com
Best 'value' in brake pads?
ccrinc replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru Genuine pads last longer and don't squeal. We don't use any other kind. Emily http://www.ccrengines.com
Appearance/surface of ring grooves after cleaning...
We don't usually get scratches from cleaning ring grooves. Unless there is upward gouging of the metal which would cause the rings to not fit properly, I don't see a problem. If there are small ridges, you might be able to smooth them out with a very small, fine file. Emily http://www.ccrengines.com
twisted sleeves...
We see a few of those. Needless to say, they become scrap metal immediately. Not even good enough for a coffee table, IMHO. Emily http://www.ccrengines.com
CCR Hiring. See post in Marketplace.
The title says it all. Emily http://www.ccrengines.com
CCR Hiring: see post in Marketplace
DOHC valve adjust
ccrinc replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a '96, they're hydraulic. '97-99 are solid lifter, which use "adjusting pucks" or shims in varying thicknesses. It's possible (barely) to do in the car, but a royal pain. Probably why the shops/dealers get the big bucks for the job. Emily http://www.ccrengines.com
Which motor would be in this?
My vote is also for EA81. See the ASV pipes coming off the back of the left head? Emily http://www.ccrengines.com
Calling Mudrat
Hey, John....where's my core? :-p Just kidding. You're still good in my book. Emily http://www.ccrengines.com
1999 Forester 2.5 Needs a new Engine
ccrinc replied to dhripper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLarry, not a plug here...just to let everyone know that we ship worldwide. Emily http://www.ccrengines.com
Is Roo-Builders on vacation or something?
I just talked to Kerry earlier this week. I know he's been having phone problems, both with cell and land line. I'll let him know. Email me your name and phone #. Emily http://www.ccrengines.com
