All_talk
Everything posted by All_talk
  1. Maybe we should all put our IM stuff in our sigs? Gary
  2. Typically the inner and outer splines have different tooth counts, fine and coarse (I know the old VW stuff does), by mixing inner and outer changes you get very small increments of adjustments. With a little math you can calculate the change at the wheel per spline. On the VeeWee stuff the outers are the coarse set, one spline is about 2” lower, if that’s to much you go back up a spline or to on the fine inner set. I’m sure the Subie system works the same. Gary
  3. I just noticed this was Brad's first post and given the responce it may be his last. Sorry about that Brad and WELCOME to the board. Gary
  4. I don’t know how to disconnect the seatbelt bell and I’m not sure I would tell anyone if I did… you might go and kill yourself and I’d feel bad, you family wants to sue and all that, blah, blah, blah. Not to mention it’s a VERY BAD IDEA! You had to know this would turn into a seatbelt debate thread, and I’ll through in my two cents as well… DRIVING IS NOT YOUR RIGHT, it is a privilege granted to you buy the state and is subject to the provisions they deem necessary. Typically I’m not in favor of rules designed to protect people from themselves but this one is a no-brainer, there is just no good excuse not to wear your seatbelt. In fact, if cars contained a properly designed belt system that people faithfully used, all the extra supplemental impact stuff like air bags would not be necessary and new cars would cost thousands less. I was belting in my kids and wearing them myself (lead by example) long before it was the law, because it was smart and responsible. In the end you can choose not to wear your seatbelt, you can even modify you vehicle so you are not annoyed by the little bell telling you that you are an idiot (not meant as a personal attack), after all it is a free country. But with rights and freedoms comes responsibilities and obligations, so make your choice, but I don’t wanna hear any complaining when its time to pay the price, be that the ticket or your death. Gary P.S. if this post is out of place as Keith suggests then mods please move, edit or remove as necessary.
  5. I've had the same thought, is there enough meat to pull it off? Gary
  6. Yeah, as far as I can find, nobody aftermarket does anything with them. I guess I'll look for a good used spare before I open mine up, once I know what I need I'll have to send you a list. Just to get an idea on price can you look up the price on the 1st gear syncro? Thanks for you effort Gary
  7. I'm sure I'm not the only one who might need some tranny parts so I'll give this the... Bump.
  8. Two things to consider, first, fuel system parts in the passenger compartment can be VERY dangerous and is most likely illegal, maybe a safer external location or skid plate would be better. Second, Electric fuel pumps don’t “pull” very well, which is why the factory puts them close to the tank and near the level of the tank bottom, any relocation should do the same. Gary
  9. Hey Its most likely in the switch, as far as I've been able to figure out the early Subarus dont use headlight relays. Open up the column and take a look could be just a gummed up sitcky switch, if not look for a junkyard replacment. Gary
  10. Hey Peter I did exactly what you’re talking about to my ’87 GL wagon. I had a brand new “turbo” type muffler (it came off my dads ’89 Buick, it was louder than the stock one so he replaced it) and no money so I made it fit. I cut the stock one off the tail pipe and with the hanger rods off the stock muffler and a piece of tail pipe from one of my junkers I fashioned it up, works great. I have to run to Spokane right after work, but I’ll try to snap a few pics of it tomorrow. Gary
  11. As I understand it the only place to get parts is the dealer and since we now have an inside guy I figured I’d ask. I’m hoping to rebuild my RX tranny, its working well now, just a little stiff on the shifts (to be expected with 260,000 miles), so all I should need is bearings, seals, gaskets and syncros. Any info you could provide would be great, drawings, part numbers, pricing and such. Available as a kit or piece at a time? Gary
  12. Could someone just post a decent jpeg of the poster (good scan or transfrom direct from file)? That way we could just print out our own 8 1/2 x 11 copies to hand out locally, possible?? Gary
  13. Most hubs are thicker where the lugs go through and thinner in between (not sure about the ones in question), there may not be much meat to hold the stud and could be VERY dangerous. Best to take a close look at the hub. Gary
  14. You guys are giving me a great idea for an event… The USMB Old School Subaru Shootout Just imagine all the top guys on the board get together to put up or shut up. Maybe a three event format, ¼ Mile, AutoX and RallyX, with individual and overall honors. Whatta ya think... maybe at WCSS7? Gary
  15. Cabin Air Filter is the name I've heard it called, I dont if your car has one, most older cars dont, but yours being a 2003 I would think it would. Maybe call the dealer? Gary
  16. Take a look at what the VeeWee guys have been doing for decades with flat four carbs. Similar engine sizes so the same carbs should work with a little re-jetting, spread bore 40, 45 and 48mm Dells and Webers for duel ports and the 40mm Solexs (“Kadrons”) for the singles. Manifolds are the only issue, but aluminum welds, cuts and files pretty easy. Here are some links to good VW info: Basic run down of vw carb options: http://www.aircooled.net/gnrlsite/resource/articles/carbs101.htm Weber stuff: http://www.scatenterprises.com/weberperformancecarbkits.html Some pricing on this kinda stuff: http://www.socalautoparts.com/HotVWs_Ad/HotVWs_Ad_p12.html Gary
  17. It looks a bit familiar to me (which pretty much excludes a Lotus, as I can't even afford to look at one :-\ ), my guess is Triumph Spitfire/GT6. Gary
  18. Cross-reference is great, but normally requires lots of research. The only good cross-reference I know of are the books that the junkyard guys have, I’ve always wanted a set of those, I wonder how much they cost. Gary BTW, I know that site because I have a Z, do you?
  19. Most A/Ts have a vent and can push out fluid, this normaly only happens when the fluid gets pretty hot (like when towing) and the fluid is very full. You may have been just a bit over full, if it doesn't happen again you should be fine. Note: I dont know what the rated towing capacity for the OB is (if any), but if you are going to be towing regularly I would look into a external tranny cooler. And, if the trans is a 4 speed with overdrive, I'd probably shift down to 3ed on the hills (even little ones), rebuilding A/Ts is VERY expensive, best to avoid it. Gary
  20. Hey baccaruda, I'm planning on making it down, I'll be coming from Ellensburg down Hwy 97 to I-84 at Biggs OR. What day/time are you heading out? maybe we could meet up on 84 or something. Gary
  21. I'm with Corky, get a good vacuum gauge on it, make sure you connect it at the manifold with a relatively short large line. You don’t want the signal to be buffered or smoothed, you need to see the variations. I’d also do a compression check, bad valve timing can show there as well. Keep us posted. Gary
  22. Like BlueSoob said, its designed to only work when the nose of the car is higher by a measured amount (3 degrees I think, the FSM shows a procedure to shim the valve to adjust the angle). I like mine and do use it from time to time, I have it adjusted so that it only catches with the clutch pedal flat on the floor, well passed the engagement point of the clutch so I can choose when to engage it. Gary
  23. Hey Tyler Teeing into the existing brake system will be a BIG problem. You will apply hydraulic pressure to at least one whole “side” of the system (one front and one rear) and depending on the configuration of the proportioning valve/master cylinder maybe the whole system (these components are not designed to be back pressured). You really should re-plumb the system into a front to rear split if you want to use a hydraulic e-brake system (which is NOT legal btw). Locking both back wheels with 4WD will lock all the wheels (and kill the engine if you don’t hit the clutch), so AWD is the way to go with that. You might look into the turn/cutting brakes use in dune buggies and sand rails, the rear brake line passes through them and blocks back pressure when the handle is pulled. If you get the two-handle type you can brake either back wheel separately for sharp power on turns (will work with 4WD), or together like a standard e-brake. Gary
  24. You can run with one (I have), but the pulleys don’t get much wrap, especially the water pump, it could give you some trouble (like in the rain). I’d get the alt. pulley from the non-A/C car and double up, and remember to buy the belts in pairs or they’ll never last long. Gary
