Everything posted by monstaru
Hair-brained ideas from a guy who cant sleep
by the time the hatch is done it will have about 162:1 crawl ratio ..........and for about 800 bucks at that...that counts 4.44's at both ends, and the t-case. the fab time is mine,the steel is not up to 30 bucks yet at scrap prices so,it is possible with time and fab ability to do it.then you have to deal with flex ..........cheers, brian
EA81 4spd to EA82 5spd swap roll call...
yep , drilled a hole,cut a piece of 1/2x1/2 tubing to put in there with a long bolt and it worked out fine.beware though,the longer the bolt the more apt you are to have "play" in that mount.short and fat spacer is my vote for the next time i do this,to help with stability at that mount. i actually had to pull over just before white pass one time due to slop,and realized the nut had loosened considerably,even though it was a nylock!i attributed it tothe mount not being stout enough due to the spacer. i never had a problem again,but also never changed the mount either. i will be doing it a little different this time. and jibs,you can make two little "L" brackets to bolt to your tunnel for the driveshaft.i did it and never had any problems.of course you want to use bullet proof fasteners,but i just measured from side to side to get it as centered as possible and had very little whine or vibration. as a matter of fact i think i used pieces of an old bedframe.:lol:worked well though.cheers, brian
Colorblindness and fog lights
i believe he is using"foglights" as general term. his explanation to me was that she wanted to see better at night,which means,"driving lights"......make up your mind *********************..........:)cheers, brian
More Scanned Articles
i second that........
i say white because it is not the color she sees that matters..... it is the amount of illumination that matters.....regardless of color.....cheers, brian
Coming to seattle...
hey ONEEYE i'd still like to make it to the pit..but we will see about that.we have some things to do in town,and we will not make it there until around noonish.so i just don't know. although its very commendable to have folks(rob and ken) to say that if we do not make it that we will receive it anyhow.i am still pushing for an appearance:grin:cheers, brian
Brat chrome bed trim alternatives
i often thought about filling in the outside area to match the rest of the body to make a very unnoticable transition.and then adding tie downs along the inside . obviously one would want to use a fiberglass product as opposed to your regular filler. as far as the tailgate goes, there is a guy that comes on here very little that lives in my area that took a piece of poly-plastic and shaped it on a mill to fit as a tailgate trim. if a guy had access to the right tools anything is possible.but i have not seen any sort of spoiler on the back of one. someone made a tailgate trim piece out of diamondplate as well.cheers,brian
we are coming back sunday as it sits right now.cheers, brian
motor mounts question
that is them.and folks usually have great results with rock auto.let me know if you need mine.cheers, brian
you just need the fronts.IIRC the rears for an auto tranny setup.someone chime in here and tell me if i am wrong. and if you cannot find them new i have a great set that you could get.cheers, brian
what time do you think you guys would be coming in from reiters?cheers, brain
For CrazyCracker..some old loyal pics and info
yes very much so... if the ratio in the diff is different from the tranny they are spinning at different speeds.not much different ,but defenitely enough to cause a scream or howl. if the sticker is not present you could take the cover off to inspect the innards of the diff.the numbers on the ring gear will show you your ratio. and whatever the tranny is is a dead giveaway to the gurus to tell you your ratio.if they do not match you need to fix that .like now. the lsd is most likely 3.7 ,and it is possible the tranny is 3.9 in other words.just because the sticker on the rear diff says one thing does not mean it is true,that is why i sayed to take the rear diff cover off and check the numbers on the ring gear.... take some pics of the engine mating to the tranny,is there an adapter plate?because i am betting they just dropped an ej tranny in there.as it does not appear to be a dual range tranny from your pics. if it is an EJ tranny , it is 4.11 ratio'd. so, is it a dual range tranny,and do you have an adapter plate between the engine and tranny(it will look a little different opposed to the aluminum on the motor and tranny,might be shinier) cheers, brian
Headlight conversion complete!
you know, its funny because there a lot of people on here that think i am a brash *********************!and i am......but i never leave a man hangin if i can help it.so that has to say somethin... sorry it took so long for me to iron it out in my head.and that also means i was wrong..because i either had no bright lights ever,or i switched 'em in my plugs too and just don't remember.so cheers, jason......glad it is fixed..monstaru
Roll Call for Offroad Rigs 2008
i do man......i have been looking for another motor,and some old snowboard bindings.you ever get an axle?pm me..cheers, brian
so , i found a pic of my offroad rig for 2008......seeing as how the brat was down for most of the year.here i am at WCSS9 after going mudding. and i rode it locally here that year.as offroad as i could get.:grin:cheers, brian me making an "owie" face.......
Another New to the Stable..Swinging New Gen more
some people do dope......we do subarus.....what , i only uh only need one more , i swear, no really just one more......,i love it...cheers, rbain
OK IT IS ACTUALLY OFFICIAL,baccaruda and i will be coming over to the west side for a couple of days this next weekend(17th,18th)......would like to have some beers/drinks with folks saturday night.i talked to zap today and he said if there is any interest we can chill at his house or go to a tavern/bar.seeing as how andy and i know quite a few of you we think it would be cool to hang out since well, you are our bro's........and a few of you we have not met face to face ....might be cool to hang out. we just want to have a good time and hang out with folks we don't get to see alot or know. we are also transporting some parts over for folks and supposed to be picking some up from folks too so those folks will hear from us for sure.if you did not hear from us does not mean we do not want to hang out.....that just means we are fairly inconsiderate young *********************es who do not have everyones numbers.:lol:kidding.i imagine if you know zap you know how to get to his house. so if you are down to make an appearance let us know.it would be sweet!being that zap is hosting us it might be a good idea to run stuff by him as this goes along.i imagine he will chime in eventually.cheers, brian
New member to my Stable. Lego! New Pics pg 3
monstaru replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think she is ugly.you deserve better.(i hate you)i want a 250$ legacy.:-\kidding. good luck with it,thats awesome ,nothing like another car to take your mind off of other cars...oh yeah,(points finger)JUNKIE...........cheers, good find connie and neo!brian
put extra clothes on, grab your thermos full of joe, and move your rump roast!:)cheers, brian
Radius Rods Don't Like Curbs!
so guess everything fit right?and we forgoT to get you a copy of HTKYSA......... cheers, brian
i pm'ed you the solution.disregard the first 2 pm's as they are just me babbling outloud.the third pm is the goodness.cheers, brian sorry i did not think of doing it here sooner.cheers
29x8.50 Swampers on a Brat?
if i remember right his is 3rd gen.....it is maroon.check it in the offroad rig rollcall thread here. and i put 235/75/15s on my 4 inch lifted brat.it stuffed roughly.....i should have rolled and pounded more,but alas,i decided to cut the tread on my tires instead:rolleyes:.... you can see that there is not much fender room.those tires equated to 28.9 inches.cheers, brian
Reiter Pit Run Jan 17
i'll give you a call later on zap.we can do some ironing out of details.cheers, brian............
FOUND! stolen subaru wagon, spokane (not mine!)
maybe around you they do that.but there is only one "yard" around here that will accept anything without a title.and you have to know where it is,know the owner,and sure as hell not tell anyone where it is. the laws are very strict in washington when it comes to that.and the paperwork best be in order around here.most likely it is as jeszek said,kids wanting to do something stupid and leaving it abandoned later.of course it is usually in the woods here.so it will probably not be found by someone that cares enough.cheers, brian
thnaks mate...i don't see why we would not go,we both want to.we just don't have alol day.and we are gonna need to ride along with someone due to his wagon being pristine,and not wanting to wreck it.(which i understand but flip him ************ about continuosly).....i got your pm and have it noted.cheers, brain
