- Stub axle part number for Loyale
Tire Circumference?
idosubaru replied to Mike104's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny number of possibilities: they’re gambling Shaft disconnected FWD fuse FWD transmission - I’ve converted Subarus to FWD If the other side rear is same size as front it could “work”. Some Tire shops do that - install two new tires on front and opposite side rear. I asked here how that works, there’s a thread about it. Car/engine is trashed and it doesn’t matter its not being driven like that. I’ve installed mismatched tires on Subarus mid-project to keep the knuckle covered (just did this last week) or borrow a wheel for another vehicle, etc.
Which Year?
idosubaru replied to manureman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgoogle search took about 8 seconds: https://www.partcycle.com/parts/2005/Subaru/Outback/400/Transmission Assembly/770108/AT, Exc. Outback, (2.5L), Without Turbo, California Emissions/item/9576538?gclid=EAIaIQobChMIuef41rGS3gIVCD0MCh0v8A1jEAQYAyABEgKSV_D_BwE
Which Year?
idosubaru replied to manureman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX400k nice. Car-part.com ebay or google Subaru JDM
Forester situation
Vacuum leak. Check all air hoses around intake and recirculation/PVC hoses "ran fine before the O2 change?" - but still had a check engine code for oxygen sensor so it wasn't entirely symptom free. did you buy this thing from a wrecked and drive it 500 yards before doing this work or have you owned it since new? what are the lengths of time it was "asymptomatic" and "driven with an O2 code showing"?
94 Legacy replacing struts - what else should I do?
idosubaru replied to Zootal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOEM Strut mounts - at least check them or have them on hand and return if not needed. Brakes - clean and grease the slides (if disc) with high quality Sil Glyde or equivalent. I would buy a brake kit with new pad clips as they get old and hang pads due to build up corrosion or rust. Get OEM clips or top quality if possible, I’ve seen aftermarkets rust not long after install. Check cv boots and see if they’re split.
1998 Subaru Legacy outback 2.5l head gasket or cylinder head
idosubaru replied to Chrisg12222's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo an EJ22 or EJ18 swap. Plug and play easy, I have a write up about it. Ive bought an EJ18 before for $150 in car-part.com and ran it hundreds of thousands of miles in place of an EJ25. Look at my write up to determine which engines work and any needed work arounds it’s really easy - easier than a head job you should diagnosis it properly first. Pressure test the cooling system, leak down test and compression test in that order. Compression test is nearly useless on that engine for anyone familiar with it If it’s bad enough to fail that it’s obvious it’s the HGs if it’s head related Itll be the gaskets and not the heads. The bigger concern is how badly it’s been overheated in the past (there’s a good chance it was previously overheated badly), this will cause bearings to fail later. If you want to repair, Use the FSM from Subaru. Follow directions, ask about anything you need. Remove crank pulley, fans, radiator, drive belts/tensioner pulley, covers and timing belt swing AC compressor to the drivers side battery tray area and leave it sit there. pull intake manifold and drop exhaust manifold remove engine and replace gaskets or attempt to do it in the car - have to remove lower 14mm engine mount nuts and jack up one side at a time for access. remove valve covers then heads. reaurface heads and use Subaru gaskets
CVT reliability and OEM replacement reliability/warranty?
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo far they seem readily available and not expensive so demand isn't vastly outstripping supply. I feel like they're a little higher than 10 year old 4EAT's were 10 years ago but maybe that's just inflation GD cautioned extended warranties may have kept prices low.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's the thing - I haven't seen any FB or CVT issues personally yet. Acquaintances, friends, and family driving these things who typically come to me with questions are cruising along without issues. Also Subaru's growth over that same time period is going to result in increased *numbers* of vehicles with issues even if the *rate* stays absolutely flat. If the CVT has the same amount of failures as the older EAT trans, you'd see the same rate of failures but 3 times as many in quantity due to sales increases from like 180,000 to almost 700,000 in those 10 years. It wouldn't be hard for anecdotal people...which comprises most of this country...to make incorrect assessments from something that isn't noteworthy. There are FB and CVT issues but let the data speak not emotions, anecdotes, and opinions...
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo If a small risk of cheap, straight forward trans replacement has you balking you’d never survive an auto swap on a modern Subaru. It would bolt up but swapping the harness would be a nightmare and playing nice with the CANBUS and FB would be all but impossible.
Is a ea81 DR trans with a cracked housing worth anything
no. put it up for sale right now and give it 6 months or a year. see what happens and let the market tell you. if you want $200 for it, won't disassemble, won't ship, and won't spread it across various venues for exposure it's not likely going anywhere any time soon. ; if you disassemble it, sell it for $50 and ship it - maybe someone will jump. if you're not willing to disassemble it to sell the guts that further constrains the value since it's unlikely to find a local buyer, you'll need to ship more than likely. yes - someone could look for one in a few years, maybe stumble on this forum, be close enough to get it....but that's highly unlikely. if you want to stash it away for that roll of a dice maybe, then sure have at it.
2006 LL Bean Outback wagon with bad rear u-joint
idosubaru replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have handed a shop the shaft and Ujoints and let them install them as well. Remove it and see how many feel lumpy, given how rarely they fail, easier to remove, and how many 200k+ originals I’ve seen, I’d be tempted to just replace the bad one if the others feel fine and money is on the radar.
SVX engine for sale
idosubaru replied to Mkiester's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a forum rule not to argue price and GD isn't known for being PR. Suffice it to say you'll have better luck listing that elsewhere with less subaru/mechanic experience. As you requested - it took 6 seconds to find one in his city that's being parted out: https://portland.craigslist.org/mlt/pts/d/subaru-svx-parts-parting-door/6720850576.html Here are more than 36 with warranties and no blown headgaskets: http://www.car-part.com/cgi-bin/search.cgi JDM importers may be able to still get some depending if it's supply or demand slowing down that train: https://jdmenginesimport.com/details/491/subaru/jdm-eg33-svx-engine-transmission.html
Wiring ej25 to ej22
idosubaru replied to Brownguy3617's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is not a possible combination from Subaru so you need to clarify something *first*. It may have confused Montana tom. A 99 GT came with a Phase I EJ25. A 99 legacy came with Phase II EJ22. Your description could sound like a Phase I or Phase II. Phase II would easily work in your 2003 but a Phase I does not, without additional work and issues since the plugs are different we can assume this was a 2.5 GT and swapped to a 2.2 at some point. So that is likely a 95-99 EJ22 95 would have dual port exhaust. 96-98 has single port. So no you can’t easiky swap that intakes do not swap. You can’t put a Phase II intake on a Phase I the holes don’t line up. 1. You can install the 2003 Phase II wiring harness into the Phase I EJ22. It leaves you with improper idle control though you need to work around and maybe check engine lights I forget 2. You can install Phase 2 heads and then bolt on a Phase II intake manifold that’s the easiest and cleanest way with no workarounds needed. Any 99-01 EJ22 heads and manifold. Any 00-04 EJ heads and intake. if there are can and crank issues as Montana tom mentioned that will be easily worked around by swapping the cam and crank sprocket, not the sensors. It’s easy - but don’t even think about that until you determine what you’re going to use and which option above you choose decide that first before the sprocket diffeneves that’s really easy
Wiring ej25 to ej22
idosubaru replied to Brownguy3617's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat’s not true by itself. EJ swaps are done all the time regardless of auto or manual. I’ve done them multiple times as well. You can also look up part numbers on Subaru website to verify this.
96 impreza 2.2 L code p0325 knock sensor
idosubaru replied to Bigsky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt doesn’t have two knock sensors. it’s really easy. One 12mm bolt and done. 10 minutes if concurrently sipping a beer. find the FSM from Subaru online and use the chiltons for kindling. They’re free and easy to find. Or get more picture grabs online, it’s really easy and will give you the torque value and orientation and location. FSM: ideally you get a 1996 Impreza FSM but any 95-98 legacy or Impreza 2.2 will suffice for the knock sensor job.
1996 2.2 into an 04 2.5 Forester swap help please!!
idosubaru replied to nerpel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat will reduce displacement, and compression or electronics, on a heavier and more ground clearance car. One guy ran low compression turbo pistons, many said it wouldn’t be drivable, and he said it was fine to drive around. But he didn’t change electronics, vehicle weight or displacement.
Can’t bleed clutch master cylinder
idosubaru replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do you know the stock MC failed? What about the Slave cylinder and slave hose - those are commonly replaced together? Could those be bad? I’m not well versed on these like those guys are so ignore me mechanically here but I’ll point out that some people have had horrid times bleeding clutch fluid. I hate them. I’ve spent stupid time bleeding, getting nowhere then the next day done in 3 minutes...I was already close to done? Bubbles migrated somewhere convenient overnight? Who knows but challenging clutch bleeding wouldn’t be a first
What is Leaking?
idosubaru replied to potter2010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn the rust belt - just remove the top strut mount bolt after marking it for alignment, loosen the lower one. No rust issues there. I've done it on a some 2005+ legacy/outbacks but I don't think it worked on the tribeca due to not enough clearance from the stubby shaft that now slides into the trans being apart of the axle. so i guess it's model dependent. But yeah - avoid the pinch bolt at all costs. The lower ball joint bolt might be easier if that's a possibility. Maybe it's model dependent but the swaybar link doesn't need to come off on the few 2005+ I've done.
Hello everyone, new user here. Rich. 1999 Subaru Legacy.
Verify diagnosis first. Is it piston slap - gets a little less loud as the engine warms up? Timing tensioner or exhaust leaks get blamed for rod knock. If it’s an EJ25D then EJ22 swap it.
1993 Impreza, EJ18, Idle Air Control Valve
idosubaru replied to viper75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo damage. pull a side timing cover to inspect - it’s only 3 10mm bolts, easier than changing oil.
What is Leaking?
idosubaru replied to potter2010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuse a Subaru seal, they are directional and therefore right/left dependent. correct, seal replacement is similar labor to axle job, as GD said it's not hard or long, certainly not a "butt load" of work. they're rather easy. get a free FSM online rather than the haynes manual. your front axle job will be identical to any outback since 2005 so you can also google axle job and probably find a video. as much as i hate aftermarket axles, it's unlikely to do damage if it's currently asymptomatic. i've only seen two new aftermarket axles blow to pieces while driving (one on the interstate)...they're trash but not much chance of damage.
New Member
howdy. broken timing belt. pull passengers or drivers side timing cover (3 10mm bolts) and look. you can often hear it as the engine just whirrs without cranking much of anything over. phillips head screw driver - pull fuel hose in engine bay and crank key - does fuel pour out or not? read check engine light and let us know what you got.
Worth it to save 03 obs?
idosubaru replied to comatosellama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX13-14 mpg is terrible and has a root cause and is probably not the cat. Do some better diagnosis, asking the dealer what they did won’t help at this point. Describe driving conditions / you lay into the pedal, let car idle/warm up a lot, city driving? One friend of mine got 11mpg and complained and none of his trips for months was more than a mile or two. I made fun of him for complaining - sure mileage was bad but he’s filling up his tank like once every two months, boo hoo!! Are there any other check engine codes? check brakes - clean and grease slide pins with silglyde. Check pad retaining clips for bends or corrosion. Air filter, plugs, wires? Knock sensor - you should get a code but maybe it’s possible to have poor performance without a code?
