idosubaru
342
I always felt like the cars don’t drive quite as good as I’d expect after installing new KYBs. I wondered if they weren’t quite up to OEM specs but figured it was more likely because I’m installing them on older cars. Can a 10 year old Subaru with new struts drive like a brand new one? Maybe I’ll try an OEM set one day.
A friend had 4 new struts installed on her 2004 Outback and they were complete bolt in units. I’m not picky with suspension but they were awful, they were soft and floaty. I don’t know what brand but they were complete bolt in units installed by Firestone so I think they were likely a Monroe or Gabriel. If they performed that bad new I didn’t have much hope for long term quality either.
should be well over 120. If compression is the same across all cylinders then it’s possible the measuring set up caused the low compression reading, not the engine. Device is in good condition, not leaking, fitted well, intake all open up, strong power source to turn engine over and not it’s only battery in equally horrid condition? Leak down test might be better here. Timing being screwed is possible if each cylinder is giving the same low readings.
Yes it could - vibrating under load that goes away when letting off the gas is 100% of the time inner axle joint or front diff. Front diff usually has noise associated with it (whining), axle is noiseless. You didn’t mention any noise so I assumed it was the axle. Draining the diff oil might show some swirling Apparently the axle was part of it, though you seem unsure? It took 7 or 9 axle changes to figure out the bad passengers side axle. How much confidence do we have in the drivers side?
1. Is the car lifted? How much? If it’s stock height then yes the chances of that many axles having the same symptom seems absurd. But I’ve had aftermarket axles vibrate or click on lifted Subarus but work fine on stock height Subaru. anything beyond moderate use is torture for them poor things. If it’s lifted I would wonder how high it’s lifted and 2” or more I’d be a little (maybe not a lot) suspicious 2. I would check those front control arm rear bushing *bolts* for looseness or stripped captive nuts. I’ve seen that before on 00-04 models. 3. Also while you’re there - I’ve seen those front/rear 00-04 aftermarket bushings on that same car last a year or so and tear. Shortest lives bushing I’ve seen from aftermarket cars on any Subaru part - that same bushing on 00-04 models. I’ll still use them since they’re so easy to replace and cheap. If you replaced it before symptoms and are assuming it’s good you may want to double check them. 4. how’s the front bushing on that front control arm? 5. 00-04 had rear subframe rust issues. Have you gotten a really good look at the rear subframe? I think you’re not in a rust prone area but maybe it spent time in one with a prior owner?
$10,000 hahaha - I’ll pass on that. Fuel being cut due to a bent rim, wow. What position were the bent wheels in - both front, both rear, or one front and one rear? didn’t know that was possible, forgive me for being inquisitive. How do you know this isn’t like previous times when a fix was coincidental and the issue returned? It seems odd for a bent wheel to cause limping and fuel trim issues. my 2009 has a bent wheel that can’t be balanced. No CEL and engine runs fine. have had bent wheels before though I don’t recall which model/years... So if I temporarily hang some weights on one or two of my wheels....?
Agreed - axles are particularly prone to vibrating (no noises) at the inner joint under load - accelerating, up hill, and then it immediately goes away when letting off the gas. I think he said he swapped axles already...and is adamant they're good. If they're aftermarket - there's no telling. I"ve seen so many bad aftermarket axles, getting a few bad ones in a row would not shock me at all. It's annoying but OEM used axles are available - at yards, cars-part.com, ebay (usually pricey), etc.
I'm assuming you have no guess as to whether this is coming from the front or rear right? Did you replace both inner and outer tie rods? I'm inclined to think this is bushing related. Check front control arm bushings and make sure all the bolts are tight with no stripped captive nuts. If the steering rack bushings are shot there's often (always?) a slight delay or sloppiness in the steering, or a light noise, due to the rack shifting within the weak/nonexistent bushings. I doubt this is steering rack mounting related. No. Definitely not.
Dual range transmission problem on 1986 Subaru
idosubaru replied to 3crows's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check all the clutch cable linkages underneath. -
He’s in Canada and I think some industries can still get it for legacy (old) equipment in the US but it’s pricey usually here. It may be damaging on an individual basis, but large scale is different and not that simple. retrofitting every AC system in the US would be problematic and not environmentally advantageous over a slower roll out of new refrigerant. New equipment, supplies, travel, logistics, costs, manufacturing costs, and ramping up for inordinate one time production, and labor are an environmental disaster too. 134a is nice but asking companies to produce enough to retrofit every US unit in a short period of time requires manufacturing, delivery, storage, etc. and companies would have to ramp up for a huge 1-3 year supply boost and prepare for a HUGE let down when it’s all done. That’s a manufacturing and logistics nightmare. Slow phase outs and roll outs are economically viable, and imperfect but reasonable environmentally as well.
Sounds like it’s too little. It’s cool but not cold abs the compressor cycles on and off. Id just add some more. got a left over/old cheap auto parts store cans that come with cheap simple gauges with too little-correct-over or whatever colored gauge? They work well enough to get it cold it’s always those two orings on that car. Fixed a ton of them.
Not that I’m aware of - do you mean engine oil, like turbos? NA never got those. In terms of oil this is the same oil pump and oil supply system since 1990. Good! Thats a good car, I like that shade of green on those years too. Best part about 2006 is it’s the latest model generation 4EAT transmission you can get. That’s probably the single biggest reliability win over anything else mechanically.
I think 2006 does have immobilizer. Don’t loose that key until you verify. 2006 also has the airbag light come on due to the dome light issue. Solder or replace dome light if soldering doesn’t work. the struts suck. They’re fine new but don’t take age and mileage as well as any previous generation Subaru. I just figure any 2006 is going to need them and consider myself lucky if not. 2006 power steering pumps also suck. More frequently problematic (squealing leaking air bubbles loose power assist), not resealable like previous models, and aftermarket is a crap shoot waste of time. Those last two won’t strand you so they’re low key, just annoying how much worse they are than prior generations.
It needs a new timing kit. new belt is usually pointless because they don't replace the lower cogged idler which is the most prone item to fail. It's an interference engine = bent valves. bare minimum it needs a new Subaru belt and new lower cogged idler: they're like $30 on ebay. best case scenario is a full Subaru or AISIN timing kit and water pump and Subaru thermostat/gasket. that's what i do on any vehicle expected to last awhile. i'll ocassionally go belt and lower idler (bare minimum) if it's rusty or someone really needs to save every penny they can. the other components rarely fail, water pump usually gives plenty of warning, and the tensioner can be visually inspected for hydraulic oil leakage and kept if it's not wet - so they can be avoided and are less risky. look up 2006 outback on cars101.com and look over it's features to familiarize yourself with the ones that are most important to you. ignore everything else - but that's a good resource for the few items that stick out to you. they typically leak oil at the lower headgaskets - keep an eye on it. progressively get worse over time, very manageable, nothing dire.
