8
Everything posted by ShawnW
Rocker Placement. OUTSIDE RIGHT NOW! HELP!
ShawnW replied to NuclearBacon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I second that. -
Soda can crumpled slightly between the pass seat and the e brake handle always worked for me.
New cam in an ea81 requires virtually a full rebuild of the engine and you might as well while youre at it.
Strange Ticking noise from the back
ShawnW replied to dave833's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Studded snow tires on rear? My votes the U joint in the driveshaft. -
Removing drive pulley when changing timing belts
ShawnW replied to sillaginid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check your pulley for holes down in the recessed areas. If they are there a punch, extension, bolt, etc can be stuffed into the appropriate hole and you can crank on the main bolt with a breaker bar to loosen. If you already have the car on a hoist or jack stands the starter trick works pretty good just scary the first time you do it wrong from what I have heard. -
Why more power at part throttle than floored?
ShawnW replied to Mantonite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There isnt a way to recondition/repair them. Used or new is about the only way to go. Used is considered illegal but if you do the work I dont see how it would come back to get you. -
Might as well put an 1800 in while youre at it, going to be easier.
Converting Part time 4WD to Full Time 4WD
ShawnW replied to fangster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its probably a 3.7 trans and turbo splines wont line up with the axles you have but u should try the 2wd ones you have out...just line it up with the stub on the trans and see if it will slide on. -
ID of the 2 rings is easy. The more flexible ring is the top ring. The 2nd ring is the one that REQUIRES a ring pliers and is very much breakable. They should have an N or an R on their top edge near the gap and in VERY small lettering sometimes. Most pistons that I have seen dont allow interchange of rings because the groove isnt wide enough for one of them to fit in.
Is this fixable? (after wreck)
ShawnW replied to Sister7's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks fixable to me. -
Boxer + Diesel=VW Vanagon Diesel. Just get the KEP adapter plate and a custom flywheel and of course do all the wiring, fuel changes, etc.
Turn em clockwise with the notch's. You can use a pair of pliers, a cube brake caliper tool or a piece of pipe similar in diameter to the caliper and notched to match the caliper piston.
Who knows? Days and Counting (Edit First post)
ShawnW replied to NoahDL88's topic in Subaru Retrofitting
Nice license plate. Now get it out there in circulation where people can see it! -
Looks good but depends on how fast it returns to 20. -
This is alot more easily diagnosed by a tire shop. Then can mount it on a balancer and really see what it does.
Need Oil Pump Help Badly!!!
ShawnW replied to Bobby_boucher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Put the oil filter back on and use it as a lever to rock the pump off. Simply twist the pump in the block by pushing the filter up and down. then when it starts turning easily pull the pump away from the block. It is VERY easy to crack the pumps inner layer. -
You can put a vac gauge on the engine to verify clogged exhaust. 1. Put the gauge on an intake manifold vac source. 2. Allow engine to reach full operating temp. (fans cycle on/off) 3. From idle (700-850 RPM) rev up engine to 2000 RPM. (Vac level on gauge should remain the same) 4. Quickly release throttle and watch gauge. Reading should slowly rise then smoothly return to normal reading you were getting at idle. If it rises or does not quickly return to normal the exhaust is likely restricted. This can be the cat or the muffler even if the muffler is clogged with cat material from a previous cat failure. 5. Disconnect exhaust and test if car fails test.
