Everything posted by ShawnW
A-Pillar antenna
Has anyone ever added an A pillar antenna like you see on the Legacy L and such cars? Im thinking about putting an 82 and 84 fender on each side that doesnt have the antenna hole and making it accessible for 4wheeling.
99 Legacy Outback Aftermarket Headunit Install Power Antenna Problem
ShawnW replied to kamusta1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy not add a switch on that wire so you can manually raise your antenna? If you pull the stereo out its probably an orange wire and its probably labeled power antenna.
2L 1993 Legacy SQUEEEEEKY
ShawnW replied to habib99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats your pilot bearing. REPLACE IT with any clutch job. That little guy takes a big beating. Id also recommend tossing out the rubber cover that the flywheel access hole is plugged with. That will occasionally shrink a little, fall into the bellhousing, and reak havoc.
Calling Mudrat
EVERYONE: Please be sure to use the feedback system on USMB. Alot of this could have been avoided. John isn't perfect but hes providing a service that no business would be able to properly provide services for so I think we should cut him some slack but if you disagree, or it takes an unexcusable amount of time you are more than able to leave him (or anyone) a negative feedback. Please also be sure to not duplicate postings in an attempt to "get your point across". Thanks, Shawn Former ASSISTANT ADMIN, back when there was a BillyC on USMB.
OEM style horns
Shape Doesnt matter, almost any of them are very user friendly on the instructions too.
Rear main seal
Flush with the block and no further. Tap it in with a rubber mallet.
custom axle info and identity help
Ill sell you my custom axles with 0 miles on them but they have been installed. I paid $120 a piece for em i want 100 each for em and you can keep your cores I won't need em. Im going to rebuild my transmission and switch the stubs out so I can run standard axles. These were built by CV Of Ocala.
COPPER HEAD GASKETS for XT6!!!!
How much boost do you really need with twin turbo xt6? Seems like a stock 7PSI would be unbelievable as is to me.
SubieSport Magazine
Congrats to Mick (McBrat) for getting a full page picture of his Brat flinging mud on page 3! Theres a pretty damn happy passenger aboard too.
AIS and reed valves, Q's an need A's Please
Yes, they have em on the Carb'd engines and usually 2 on the ea82's.
Top Dead Center
Compression tester into #1. Turn engine by hand until compression rises and then watch the flywheel for the 0 mark.
98 2.5 GT 4AT "AT OIL TEMP" Light???
ShawnW replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats normal.
97 EJ22 - timing belt versus valves... FIGHT
ShawnW replied to rogue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 97 EJ22 - timing belt versus valves... FIGHT
ShawnW replied to rogue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to help you not repeat your mistake. Cam gears have arrows on them. Make sure they point at 2:00 and the notch in the side of the gear is at 12:00. The solid lines on the new timing belt (USE A NEW ONE!), line up on the 12:00 marks. The crank gear has a notch for 12:00, make sure thats pointed at 12 and that another mark at 3:00 is pointed at 3, dont make it so you have 9 and 12 on the crank. The Key for the crank pulley should be at the bottom if you have it right. Also be sure you dont follow the manual on the crank pulley bolt torque. Books say around 80 pounds, it should be around 120. A healthy 1/2" impact gun will torque it properly. Use Locktite on the bolt. If your belt tensioner looks like a long tube with two bolt on ears, you can re-compress it in a Vise. If it doesnt, then either get a new one (recommended) or take it to a Subaru dealer to have them re-compress it for you.- 97 EJ22 - timing belt versus valves... FIGHT
ShawnW replied to rogue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX- 99 cd player
ShawnW replied to elviscan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMarketplace is a good place to start for just the CD section if its the 2 din separate radio that has am/FM/Cass on top and CD on bottom, etc. Ebay has always been good for the 6 disc in dash takeout units from WRX's and such. These look and sound awesome!- rocker panels/fuel tank
A 80-84 4wd wagon or coupe tank will work in an 82-88 Brat as well, dont rule those out. Hatch won't work.- Door Chime
ShawnW replied to Reverendray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes your dome light flicker on when the key chime comes on? If so the door switch is bad. Attack the cause of the problem instead of the result.- best year for trannies?
ShawnW replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAvoid 89 and 90 Legacy transmissions(yes there is an 89 Legacy). Otherwise the 91-94 are the most durable IMO.- 99 Legacy Outback AT OIL Light
ShawnW replied to thehorn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe dealer needs to plug their "SELECT MONITOR" into it. THe AT OIL light is coming on because theres a fault stored in the trans computer.- Ok, this roo is really starting to get on my nerves...no start--fixed!....Broke again
That sounds like the coil to me.- Tire replacement for the 2006 Subaru Forester
ShawnW replied to n0stalgia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook at: yokohama avid touring, michelin X radial.- Discharged Battery & AECS issues
ShawnW replied to nvrquit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake the battery out and to a parts store. Have it tested. If bad, Replace and start there. Maybe you cleaned the interior and switched the park light switch on?- HELP: EJ25 DOHC Head Bolt Removal
ShawnW replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use a 2' long 1/2" drive breaker bar and have to push with nearly all my weight (140#'s) to bust em loose. Ive torn down at least 25 of them and they are always stubborn, more so if the engine has had head gasket issues.- ***HELP*** 2.2 Timing belt horror!!!!! (UPDATE)
ShawnW replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlock is scrap. youre never going to be able to trust it to hold a timing belt properly. - 97 EJ22 - timing belt versus valves... FIGHT
