Everything posted by northguy
YES!!!!!! new engine
So, what did it set you back?
new member
northguy replied to AB/S05Bean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board. You're right; we are much more active in corespondence about our rides.
Ignition/fuel cut...on stock boost
Is there a possibility of a partially clogged fuel filter or a leak in the seal on the filler cap that would be causing a void in pressure?
only serious replies please
If it's only been a month and a half, don't go into full scale panic just yet. I (and many others) have had to wait longer on other "vendors", as long as 6 months in one case for me. Soobme is a trusted board member, but that doesn't suggest he shouldn't be communicating with you. Keep trying.
Adds 35bhp? I don't think so!
northguy replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore like "Turdinator.":grin:
Tire Decision
I picked up a set of Coopers for a bit over 3 bills. Good tires.
If not Subaru, then what would you choose........
northguy replied to sagebrushsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX(Insert Zap's signature here ) If you just can't drive a Subaru, walk. But you might look at an older Toyota extended cab pick up. It may not provide the comfort you're looking for if you have 4 adults, but if it's 4wd and gas mileage that are your priorities, the other person not in the front seat can just suffer for the few times he/she will be in the rig.
where to get Peugeot wheels
I didn't say it this time, Ed.
new member
a few questions on off road tires
Check out Zap's tire write up - very informative.
Please HEEEEELP(MY 86 Leone)!!!
If I'm reading your post correctly, it sounds as though when you place a load on the electrical system, you start to experience shorts in the system - i.e.: erratic electrical delivery to the tachometer and bucking from the motor (which may be due to fault in the spark to the power path (coil, wires, plugs)). Runa a diagnostic check on the alternator/regulator, and coil. Good luck.
Replacement Driver Seat Foam ???
Go to a sewing shop, like JoAnn Fabrics (good place to cruise for dates, also) and buy some high density foam cushion and replace the whole thing. You may want to put something stiffer next to the springs first, like tag board.
Brake rotors?
northguy replied to Carrot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKeep watching E bay.
Subaru dealer cutting off body parts
Maybe they're building a Frankenstein Subaru?
Thanks to northguy
Not a problem, Torxxx. I hope it worked fine and got you home.
Help! Tranny goes, dealer says "your fault"
northguy replied to Matty L's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf there was no defect in the transmission before it failed, how did it get so low to cause fault? If it leaked at a rate that was either so fast it couldn't be caught in time, or so slow it couldn't be detected, then the factory is at fault. Of course the dealer is going to say it's not their fault. Be persistent.
Introduction
Welcome to the board. Glad to have you aboard.
Score!!!
northguy replied to GLCraig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is a good score.
new member in southern oregon
Welcome to the board. There are a bunch of members in Oregon.
Offroad tire write-up (Summarized)
Zap, thanks for the write up. It should save a bunch of questions and be a handy reference in the future.
1990 Legacy Wagon L AWD $1,200...worth it???
I'd say go for it.
Hello to all from new member
Welcome to the board. Try using the search function for subaru parts online and you'll find a ton of them.
1991 Subaru Legacy won't start!
northguy replied to grdnrofeden's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease describe the symptoms more. Does it crank over? Is there no spark to plugs? No power at all? Did you attempt to recover codes?
brake line resources......for lift
Wasn't someone also offering stainless steel braided lines? WJM maybe? I'll concur that you don't need them for a 3" lift. Mine extended out fine after I released them from the retainers and straightened them a bit.
Rainy days
northguy replied to brandon04r6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt very well could be a leak around the pinchweld of the windshield.
