440
1984 GL 4spd Transmission Rebuild Kit
GeneralDisorder replied to 84GLPROJECT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes - they are both 4WD, Dual-Range transmissions. The transmissions to get are from '85 to '89 Non-Turbo GL's - wagon's, sedan's, and three-door coupe's (not the hatchback). You don't want a DL, and you don't want a 90-94 Loyale as those were push-button single-range transmissions. Junk yards are your friend. U-Pull-It style yards are usually cheapest but call around and see what you find. Cost is generally around $75 to $250 depending on what you get and where you get it. Some places offer warantee's ect. Contact Jerry (Bratsrus1 here on the board). He makes a cross-member for mounting the 5 speed to the EA81 body. He is very reasonble. You will also need the driveline from the donor car as the 5 speed's are physically shorter than the 4's. You need the clutch for the 5 speed as well - depending on how you do it you can use the EA81 flywheel and pressure plate with the EA82 disc or you can use the entire EA82 assembly. GD -
Brumby Gear oil topup
GeneralDisorder replied to Dan90's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You fill it through the dip-stick hole so it's on the top where you can't see it. It will be on the driver's side (for you AUS folk), just to the left of the pitching stopper. GD -
I try for about 1/16" of squeeze out on my RTV applications. I notice that most folks go nuts with the stuff and it looks like a 4 year old with a caulking gun went off his Rittlin. I guess a lot of people prescribe to the adage "more is better". I'm just paranoid about peices breaking off and getting jammed up in oil galley's and such. I have WAY too much attention to detail unless I've been drinking.... a lot. GD
My axle rebuild write-up should answer most of your questions. It's geared towards EA81 rear axles, but it applies to the EA front inner joint as well. The front outer joint is not easily dissasembled as you need a special tool and ideally a press to do it right. http://home.comcast.net/~trilinear/axle_rebuilding.html GD
Sealed wheel bearing question
GeneralDisorder replied to Greenley's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We can dissagree about bearing greasing. It's ok. Lots of people dissagree with it. I get flak for my posistions on greaseing every time I voice them. There is a lot of old "wisdom" on the subject that is ingrained in the older generation as most have not kept up with the literature on the subject, are not aware of the changes in qualities of lubricants, and very much *want* to beleive they are still doing it right. I want to draw your attention to some documents from my library: Here's some facts: 1. At 60 MPH, an EA series wheel bearing spins at ~870 RPM. 2. The 6207 has an inner bore diameter of 35mm. 3. Due to the resolution of this chart, I chose a 40mm bore and a 1000 RPM speed to insure that I underestimate the usable life of the bearing grease. 4. The chart indicates a usuable grease life (when the grease should be serviced), of 20,000 hours. 5. If every single hour of operation were @ 60 MPH, that works out to 1,200,000 miles for the usable life of the grease. If you even got HALF that number of miles (possibly due to higher temps from excessive braking, lots of stop/go style driving, etc) you would be exceeding the usable life of the car by several times over in most cases. Please take note of the paragraph under "How long does the grease remain usable?". It notes that: I must emphasize that this paragraph implicitly indicates that most bearings fitted with sheilds or seals ARE lubricated for life. Such is the case with all the one's I've seen so emperical evidence would seem to validate. ALSO I would draw your attention to the grease compatibility matrix. Notice all the red? That's because you can't just mix grease types in most cases. Thus EA series wheel bearings can NEVER be regreased as it will damage them to remove and reinstall them and there is no other way to flush the old grease out. Plus if you just smear new grease in there - even if it's compatible you are contaminating it with the old grease and the contaminates already present. They are not timken roller bearings and can't be treated as such. If they were, you would (should) be repacking them every 120,000 miles (by the chart - probably it would be reccomended more often than that to be safe). The same does not apply to ball bearings - the forces applied to the bearing surfaces and the grease are different. This ain't your daddy's Chevy truck. It's also a really poor idea to flush brand new bearings, repack them, and reinstall the seals - you risk contamination from the solvents and any remaining bits of the OEM grease. It's also very hard to insure you have applied *just* the right amount so the bearing receives correct lubrication without overheating. GD -
Yep - someone used red RTV instead of the factory grey. It is supposed to be that way although it does indicate they were liberal with the application and it for sure indicates your cam towers have been removed at some point along the line. That is usually only done if the head/head gaskets need replacement or the engine is being rebuilt. GD
Gary - get the pliers for your type of boot clamp - they are $10 at the local discount auto parts house here. The other option is to source the VW 1/4" wide (6mm) axle boot clamps. They are hose clamps but are thin to fit in the groove that the regular boot clamp fits in. Check to make sure you have enough clearance for the hose clamp worn gear all around where it will sit on the joint. Loyale - If it just has a pin-hole then you can do both boots without removing the axle from the knuckle. It's not that fun but it's doable. I typically remove them anyway as I've been doing it since the beginning of time and I'm pretty quick at this point. You do run the risk of not having the removal go well and ending up replacing the axle and wheel bearings anyway. Safest bet is to just reboot it with two new ones and make sure the grease still looks good - scrape away some and add about as much as you remove plus a bit for what's been lost through the pin-hole. Better that you do it now as if you wait till the axle splits completely there's a much greater chance of contamination of the grease/joint and then you will have to remove the axle to properly clean it out. GD
Air Compressors... How to keep them quiet?
GeneralDisorder replied to Subarutex's topic in Shop Talk
Yeah - the type of air filter on the machine can make a difference. Typically they are a screwed-in NPT fitting but being a highly custom type of machine and fully enclosed it could very well be totally different. Try this - when it's running just put your hand over the intake to the compressor (do this before it starts getting hot). That will instantly tell you exactly how much of the "noise" is comming from the intake. It won't hurt you - that's actually how we test the bottom end on recips - block the intake and listen for the sound of rods knocking..... GD -
IAC service on EA82
GeneralDisorder replied to paulpicard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You may or may not have the PCV "fix" for long, sweeping, right hand turns causing clouds of oil smoke..... At any rate there should be a restriction somewhere on the line from the driver's side valve cover. Either the line will neck down to 1/4" ID, or there will be an oddball T fitting with an orifice drilled into it. On the carb models this is obvious as the line necks down with an "F" fitting going to the PCV and to the air-filter housing. With the SPFI's it looks different but the effect is similar. GD -
Accelerator cable for Loyale
GeneralDisorder replied to markjw's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's likely this one: SOA Part #737065251 $13.25 from subaruparts.com That might be the EA81 part though - there seems to be some superceeded part numbers thrown into the mix. I've done SPFI conversions to EA81's and the EA81 throttle cable works just fine. I think they are more-or-less interchangable. GD -
I guarantee the dealer can get them. My parts guy will give me the number with no trouble at all. I'll get it for you when I'm there in the next few days to pickup some stuff I ordered. GD -
All the boot kits I've done say to use the entire pouch. They say to pack the grease into joint and use the rest to in the boot. Never had an issue doing it this way. It is important to get the bands on REALLY tight. If you don't they will slip off the joint. Speaking economically, I doubt the bean-counters would allow them to include *more* grease than you needed to do the job. And they wouldn't sell many boots if they shorted you on grease. I think it's in their best intrest to at least try to include about the right amount. Also - you NEVER want to "fill" the housing. There has to be room for expansion. 1/3 full is industry standard for bearing cavities. GD
'83 was the first year for ignition controlled lighting. It's normal for your '82 to have manual lights. GD
holley/weber carb on ea82
GeneralDisorder replied to raven1835's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would steer clear of the Holley Weber. It's a DFV clone but they have extraneous stuff on them like bowl vent solenoids, etc. They also have smaller venturi's than normal DGV's making them of dubious upgrade potential. Then you would have to rejet it - not with the same jets as a DGV because of the smaller venturi's....Get yourself a DGV, peen a dent in the power steering reservior to clear the choke housing and call it a day. GD -
Weber Carb for a Brat
GeneralDisorder replied to Universeman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I beleive they are specific to the manifold. It should be a 19mm. A flare-nut wrench would be helpful. Take a small propane torch and heat up the area around the threads. Alternatively, that's the EGR line not the coolant line - you could just eliminate the EGR and then plug the hole in the head. GD -
No one sells kits for them. I checked into it a few years back. Subaru never made a kit either. You'll have to tear it down, make a list of the parts you need, and order them through the dealer. Some of them like the seals and bearings will probably be off-the-shelf parts at any bearing house. You are in for a real treat if you really plan to rebuild a 4 speed. There's a reason no one ever does.... that and 5 speed's are so plentiful and cheap that there's just no reason to mess with the 4's. There's so many ways that the 5's are better that it's worth the little bit of fab work to install them. The price for the parts to rebuild a 4 will be twice the price of a good used 5. GD -
I just go to the dealer for all my cable needs. They are better quality and not that expensive. I think the last EA81 throttle cable I ordered with like $12 or $15 GD -
Your Hitachi is a DCP-306-7xx. Probably a 721. Irregardless, all of the DCP's use the same rebuild kit. The EA82's use the DCZ carbs. As for mileage - the 4WD's get worse mileage because of the gearing, the tire size, and the weight. Mostly it's the gearing though - the 2WD's had 3.7 final drive ratio and smaller tires, while the 4WD's have 3.9 and larger tires. The carbs *are* jetted differently, and most of the 2WD's also had the feedback computer controlled versions. But the difference is like 1 or 2 MPG between the 4WD non-feedback and the 4WD CA spec models. It's not at all worth the hassle of that system. I routinely get 26 with my Weber in mixed driving. On my last trip to the beach I got 31.5 on my 4WD hatch with the Weber. I just drive normally - I don't try to get amazing mileage or anything. And my engine burns a lot of oil and has one cylinder with low compression. I tuned it with a wideband O2 sensor though. It's getting an EJ22 very soon so I haven't bothered to put any work into the engine. Be glad you get high 20's. I get 16 in my turbo legacy GD
Other than having done it "many, many times" (anecdotal evidence at best without *at least* usage information both pre and post replacement), do you have any good reason to be repacking sealed bearings? What evidence can you show that proves they wouldn't have lasted just as long or longer had you not repacked them? Do you still have or keep track of all these bearings you have replaced? Lets not forget that most EA wheel bearings have already lasted more than half the life of the car before needing replacement - ONE replacement is most often all that is needed for the remaining life of the automobile and that lifetime is often considerably shorter than the factory set..... My reasoning is backed up by industry standards and tons of research into the subject by the nuclear power industry, NLGI, and others. Not to mention my own experience. And lets not even go into the damage you can cause to the seals by removing and installing them with a pick. Don't screw with sealed bearings unless you plan on leaving the seals out - often bearing houses will only carry 2RS bearings and tell you to pull the seals if you want an open, greaseable bearing for your application so that's not uncommon to pull them. But you don't put them back in - that's a no-no for a number of reasons. GD -
I just installed an OBD-I 5 speed into a '96 OBD-II. The biggest difference was the exhaust bracket for the mid-pipe. The bosses on the tranmission for the mount simply didn't exist. I fabed up a mount and welded it to part of the transmission cross-member. The wireing is different but I just swapped the reverse and neutral switches with the one's from the blown tranny. Otherwise it bolted right up. They were both cable clutch's and both 3.9's. YMMV with a 2000 though. GD
The problems are: 1. It's a 3600 RPM motor. It's running those little pistons REALLY fast (probably @3600 RPM - which is totally insane). 2. It's an oil-free recip - it's totally open (exposed crank) and needs to be in order to properly cool it. 3. Being a tiny-piston, oil free, high RPM, aluminium/plastic machine - it makes a TON of heat and has to reject it somehow. Air compressors double as excelent heaters and anything you do has to keep in mind that your machine (especially) needs proper airflow or it's going to melt. What you can do: 1. Slow it down. Change the belt shivs if that's possible with your machine's design. This will reduce the speed of the air-end and of course also reduce the noise. You will lose CFM. 2. Enclose the machine. Basically build an insulated enclosure for it to sit inside of - you will need to provide a fan (attic vent fan perhaps?) to circulate air through the enclosure. DO NOT underestimate how hot that thing will get. All that plastic shrouding hides the fact that at 100 psi the discharge temp of that little machine is easily 250-300* F. 3. Put it outside with a shed roof over it and plumb some copper through the wall for your air supply. Provide a quick disconnect for the machine so it's still portable. Chain it up or wheel it inside at night though. 4. Get a bigger, oil lubed recip. I know that's probably not an option for you but I just wanted to point out that larger machines that are oil-lubed, typically run at 1800 RPM and as such make less noise. They are also heavier and the noise they do make is usually devoid of the annoying "buzzing" of the smaller, lighter machines. It's more of a thump, thump, thump noise and not at all annoying (IMO). I have a little machine that is my portable with a 30 gallon tank - it's an oil-lubed recip. The machine was made by Coleman and it's a few years old (I beleive they don't make them anymore). But the air-end was made by Briggs and Stratton (the engine manufacturer) and although it does have a 3600 RPM motor the air-end runs at about 1200 RPM. It's not bad at all for what it is. Puts out about 5 or 6 CFM.... I got it for $84 from work when a customer never came to pick it up after I fixed the thing. I would reccomend something like that (it was probably a $300 or $400 machine new) over an oil-free machine. Especially if you are just running air tools as the oil won't hurt them. If you are painting a coalescing filter and a drier would be needed anyway so I'm not sure what the draw is for the tiny oil-free recips. They don't fill any niche that I can think of although it does mean you never have to worry about changing the oil. GD -
DO NOT repack sealed bearings. They do take *very* little grease. This is by design as they do not exchange grease with a larger bearing cavity. The grease needs airspace to expand as it warms to it's dropping point. If you pack them solid the grease will simply overheat, cook itself, and fail - contaminating the bearing and causing premature failure. Also - unless you first flush them very well with solvent, wash them with soap and water, and regrease them you have no idea if the grease used by the manufacturere is compatible with the grease you are packing them with. The result could be anything from the grease losing it's lubrication properties, never dropping at all, to just turning to plastic. Greenly - YES - apply grease to the outside of the bearings and the lip seals. If the lip seals do not have lubrication they will fail in short order. I put the normal amount of grease between the bearings as well. This just serves to trap particulates and moisture that gets past the seals and also keeps the bearing pockets from corroding. GD -
crankshaft bearings? ea82
GeneralDisorder replied to blazelate's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That sounds like a pretty normal low-reading gauge/sending unit. At idle and cruise you are at lower RPM than at other times. Oil pressure is purely a function of RPM. As the RPM's climb the oil pressure does also to a point. That point is where the bypass valve opens and allows the pump to return extra oil pressure back to it's own inlet. Tell me - did the "mechanic" test your oil pressure with a known-good shop gauge? Do you have test readings from said gauge at various RPM's - taken cold, warm, and hot with temp gun readings to match? If not your mechanic is a hack. GD -
I'm telling you - it's a mistake to remove those spacers. But if you do it remember there's a gasket between them and the head - it's a narrow ring that fits in a groove in the spacer and I'm guessing the only reliable source for them is the dealer. Seriously - the heli-coil approach is WAY more work than just running the tap through both the spacer and the head and calling it day. It will be 10x stronger and if you wanted to heli-coil it back to metric later that's easily done as the 7/16 x 20 tap does not require any drilling - the hole is already the correct size for it. GD
