Did anyone ever try dual webers?
Get a Tig welder and a die grinder and mae yourself some dual port heads. That's what RAM does..... GD
EA81 Carby question
According to all the research I have done, and Skip did before me, the whole 2WD disty business is a load of crap. The FSM gives only a single advance curve for both types of disty's. There has to date been no solid eveidence of ANY kind presented that I know of to support the supposition that EA81 disty's had different advance curve's on the 2WD's vs. 4WD's. That's not to say that the advance curve's didn't change depending on the year of the EA81 in question, but a thorough examination of all the FSM advance curve listings has not been done due to no single person haveing FSM's for every single year..... at the *least* the situation is a heck of a lot more complicated than just "go get a 2WD disty" as some years are certainly not different across drive trains, and other years might be different, or might be the same but different than a newer or older model. I also have to make a point of noting that the Hitachi distributor's reluctor design is a lot more reliable in that it can handle more shaft slop before going out completely. The ND disty's used in the 2WD's seem to be much more sensitive the shaft slop, and according to my conversations with CCR, are more likely to blow up their ignition moduals as well. Perhaps Subaru used the Hitachi on the 4WD because it is a more rugged design, but was more expensive because of this. I really don't know what the reason for the change was.... GD
Gasket sets
Do whatever you like - you already have my opinion on the situation. As for the dealer HG's being better..... I seriously doubt that. Fel-Pro is a very trusted name in gaskets. Not to mention they have 20 years of continued improvement upon their products that the OEM gaskets don't have. I put Fel-Pro's in my EA81, and less than 2k miles later lost ALL of my coolant on the freeway (blown heater core hose). The needle was pegged. I drove another 2 miles this way till I could pull off into a parking lot - my speed continued to drop due to pinging. By the time I stopped, the engine was pinging so badly from predetonation that I couldn't maintain 30 MPH, and the engine was smoking (cooking the oil and sludge off the block). After it cooled I repaired the hose and refilled the coolant. NO damage. I've put another 5k on it since that happened, and not a single drop of coolant has leaked. GD
can u put this weber on ur soob????????
Usually, every time I look on ebay there's 5 or 6 of them. It will probably sell for around 100 or more. They usually do. Just cause someone posted this here doesn't mean it's unusual to see them on ebay. They are common as dirt - they often seem to be attached to those silly VW intake's too. I suppose that's what keeps the Jeep heads from buying them. I have asked sellers when I bid on them if they would kindly remove that awkward POS before shipping...... GD
ea81 LOUSY gas mileage?
My Brat gets 28, and isn't even feedback..... my wagon when it was 2WD got 30 with the feedback Hitachi, and about 32 with the weber. My friend has my old feedback Hitachi carb on his 2WD 84 wagon and is getting about 33 due to high compression from carbon build up. GD
Gasket sets
There is a LOT more gaskets than you think. Likely you only need about 5% of what you would get in a full kit in order to stop your leaking. Zero in on what exactly is leaking and fix that. Oil pan - Valve covers - Cam seals - front and rear mains.... etc. Buying an entire set is silly if you don't intend to remove the heads even. Personally, I would do the HG's on general principle if you are yanking the engine to do other seals. I like the Fel-Pro ones myself, and when they only cost about $20 each for the HG's, it seems like good insurance. GD
Throttle body/carb spacer gasket?
It's not going to keep the carb any cooler with coolant running to the base of the throttle body.... and that would have been exactly the opposite of what Subaru wanted. The carbs are heated for emmissions. GD
EA81 Carby question
All the EA81 carbs *with the same model number* are jetted the same. As far as I know the sedan didn't get anything special that the rest of the cars didn't get. Depends on the year of manufacture, and weather the car was 2WD or 4WD determines which model they got. Besides - a change in jet's isn't going to do sqat for performance on these carbs - the 26mm primary is just too small. Take the jets out and see. It's not hard to do. GD
Mine did a lot better than that. You have problems. GD
Pictures of my car which I need help with
And some of us do all three!! GD
That's the big plastic spacer right? I've installed them without it.... not on a 78, but as I recall, the spacer is there basically so you can get the nuts on the mounting studs..... without it there isn't enough room. I just lifted the carb slightly, and threaded the nuts on, then tightened them down.... That's technically not a gasket, but a spacer - they aren't readily availible except from the dealership I would imagine. But you should be able to use any spacer from an EA71 or EA81.... same carb mounting. GD
Wheel click noise 86 Brat
There's some good posts on here about replacement procedure..... it's not totally straight-forward if you know what I mean. Another Subaru oddity.... Autozone carries Timken brand bearings for the front for I think $13 or so each. You need two for each side of the car. And also the seals - those are about $5 each. GD
Any machinists out here that want a challenge?
I was speaking stricktly of US versions of course. EA81 RX's had all sorts of nifty things - rear discs, LSD's, and really, really cool engine upgrades that we never got..... GD
I'm not argueing - I'm telling you that NO EA81 ever came with a 5 speed 4WD of any kind. 83/84 were EA81 years. Period. There's nothing to argue about - I guarantee it. I have an 82 4 speed in my wagon right now - and an 82 Brat sitting out there. Plus an 85 Brat as well. I KNOW the gearing of EA81's. I don't know the gearing of the EA82's as well so I can't comment on that. GD
Please Help With My Subaru
No - they came with 5 speeds after 84. Autos were of course still an option as well. GD
That's not quite right - 83/84 didn't have a 5 speed D/R..... and there is no difference between an 82 Brat 4 speed and any other 82 4 speed. The change in the 4 speed's came in 83, and was across all models..... GD
Well makin some progres... next comes powersteering
BAH! We all do stupid things. Your mom should be glad that you are alright, and have learned a valuable lesson. She probably doesn't see it that way tho. GD
Why is it I have brake problems everytime I let one of my cars sit for a month or so?
I've never seen that, but as you are in PA, I would have to say it's probably rust related. Either rusty rotors, or rusty calipers. Could be that those calipers are in need of a rebuild... I've seen ones out here on the left coast that caused the pads to wear at an angle, and made sqealing noises because of it. In the end you'll probably just have to start dismantling the brake systems to see what's what. It's not something that is easily diagnosed from a description of the noise it makes :-p Note that there are two types of calipers and rotors - vented rotor style, and non-vented style. Make sure you know which one you have, and order the parts accordingly. For the vented, use an '84 model year, and for the solid rotor's use the '82 model year. '83 was half and half, and will confuse the situation. GD
Classic wheel bearing. Doesn't do it when jacked up because there's no load on the bearing. GD
Those pumps are tough as nails. I've only ever heard or seen of 1 dying.... that was on an EA81T. I'm sure it will be fine. GD
Might have to cut out the side of the tranny, and tig weld a cover back over the now exposed gears..... anything is possible, but the cost might be pretty high. Unless we could find someone that would do a bunch of them and get a bulk order going. If we just bought the parts and assembled them ourselves it might not be terribly expensive, but getting enough people on board for what is sure to be no less than $500 - $1k for each set is unlikely. Too bad too..... I would really like to see that happen. Oh - and lets not forget the HUGE pile of broken stubs and axles that would result from this..... carnage on a scale that has not been seen before on this board anyway. Rectifiing that situation is possible to... chromoly stubs, and cryo-treated axle cups.... maybe with reinforcing welded to them as well.... GD
PS fuild doesn't flow near the steering wheel - I would guess that's something else. The EA82 PS system uses ATF - which is bright red too...... there's really not much that can go wrong with the system - fill it up and see if it works again. GD
Yes - I agree, but the Z car diff's have a bigger aftermarket than ours. If you could make it fit, then you could probably get a 5.xx ring and pinion for it.... GD
Some of the Z cars had R-180's with 4.11 ratio's.... modified Z U-joint axles could perhaps be fitted with some work..... GD
Brakes again...
Probably just need more bleeding.... helps to have a friend. Can take a LONG time. GD
