Help for a DIY
The sqeaking sounds like possibly a wheel bearing. You can inspect them when you do your axle(s). I would say that if you have never done an axle before, and you are somewhat mechanically inclined, you could easily do one of the two axles in a weekend. That's including the wheel bearings, brakes, and all that other stuff. You should do a search on here for "axle removal" or something along those lines. There have been a lot of discussions posted on it in the past.... especially you should note that most manual's will say that you can't do it - that only the dealer can. Don't be scared by this as it's really not that hard. I do a full axle swap - from the time it's up in the air to the time it's back down in about 30 minutes if I'm really moving.... although I rarely am, and usually take my time - inspect things carefully, and perhaps adjust some other things while I'm in there. GD
have u seen this brat on ebay yet?
HG's really are cake on an EA81. Half a day if you don't break an intake bolt.... GD
blowing smoke off and on
I concur - a cheap solution possibly. I would add that you should use ONLY a SOA valve. The aftermarket ones are notorious for sucking oil into the intake. It's very uncommon for EA81's to smoke heavily like that.... rings and valve guides typically last the lifetime of the engine. The bottom end gets sloppy, and EA81's typically die by blown rod when they are allowed to run long enough for mehcanical failure to occur. Usually they are sent to the junk yard long before this happens with bad carbs, or transmissions (those auto's were crap!). If by some odd coincidence it does turn out to be your rings or valves, then just get another engine. Fortunately they are cheap, and probably a board member will have one for you anyway.... GD
hill holder
The HH was pretty standard one just about everything - even my DL single range 4WD has one. They don't seem to fail a lot out here on the left coast. Mine are both fine, and I have yet to replace one on any Subaru. Must be a rust belt thing. GD
Dizzy Vac Advance units....
Huh - last time I was there I had my disty rebushed, and the vac can rebuilt - both together cost me $55..... that was about a year ago tho. I just passed their shop the other day - little hole in the wall. You wouldn't even know they were there if you weren't looking for them. They do goo work tho - even painted the vac can and shined my disty for me. GD
How hard is it to change a steering rack?
Well - I doubt they will even touch a body lifted soob, but who knows. Also - there actually is no adjustment possible for the camber - is this a PK kit? If so, your front strut's are probably adjusted all the way up causeing the bad camber situation. It's funny that there really is no alignment on a soob other than the tie-rod ends. Toe adjustment is all you have - the other factors are part of the suspension. Bad springs could cause negative camber, but positive is because the struts are too strong. The positvie camber will wear the outer edges of the front tires...... but those swampers are HARD rubber. and can take the abuse. If you really want to fix it, increase the size of the lift blocks on the engine cross-member by 1" - if they are 3" now, use 4" blocks. If they are 4", then use 5" blocks. You can make your own blocks or call PK - I'm sure he could hook you up as well. GD
Rear axle question
Start beating. You might have to disconnect the lower coil-over mount to get enough angle, but that's it. Dropping the diff is not necessary. GD
Maybe their prices changed - still the same on their site tho.... http://www.philbingroup.com/rebuilt/special_services.htm Was your VAU a dual unit? It does say $45 for those..... Mine was a single so only $25. GD
VAU's can be rebuilt - only cost me $25 last time I had one done. Seems silly to buy a new one when you can just do that. GD
Help for a DIY
Let me straighted some of this out.... 1. Clicking axles are caused *usually* by the outer joint, which will NOT generally cause vibration at freeway speeds unless the damage is severe. The inner joint (which is a Double Offset Joint (DOJ) - not a CV joint) when it goes bad will do so rapidly, and cause massive vibration at nearly all speeds over 20 MPH - they will click and clack and sound like something is seriously wrong (think rod knock noises here...) going in ANY direction - turning, straight - doesn't matter because the DOJ doesn't swivel when you turn like the CV. To summarize, your clicking *while turning* is almost certainly an outer CV joint, it is not the cause of your vibration, and if the clicking isn't severe and the boot is still good it can last a LONG time in this state. Think 10's of thousands of miles.... it will not hurt your performance in the slightest. If the boot is bad and the grease dries up, then it could fail sooner, but you will have plenty of warning before it does. If it fails, just throw it in 4WD and go straight home - it will make awful, horrible noises, but it shouldn't damge anything you won't be replaceing anyway.... and you steering won't lock up - that's just BS. Clicking axles are not a good representation of the overall condition of the car. Older Subaru's eat axles like candy, and it has nothing to do with maintenance or care. Hardly a month goes by that I don't put an axle in someone's Subaru - sometimes 3 or 4 a month. 2. $750 is insanely expensive. You can get BRAND NEW axles for $90 each, or remaned units for about $65. An axle would take an experienced mechanic about 1 hour for each side, and even at dealership rates that's only about $200 in labor (that's an overestimate - more like $150 - $160 I should think).You can do it yourself and save a lot of cash. The tools to do the job won't cost you what the labor would to have somone else do it. If the clicking isn't too bad, and there is still grease in there, buy a boot kit and a tube of grease and pull the axle out - clean and reboot it. A boot kit and some grease will run you less than $20. 3. Tires and rims..... you shouldn't need ALL new rims - maybe 1 if it's bent too badly, but unlikely - even the big chains will straighted a steel rim with a hammer and rebalance it. You can get a set of tires for about $80 at the discount places - true they are cheap tires, but they are better than nothing, and will last at least 30-40k with careful driving. If you do need a rim or two, you can get them brand new for $25, or get one from a junk yard for $10. 4. Brakes - they are so easy to do that if you do nothing else yourself you should do this. You need only a couple tools (12 and 17mm wrench, jack, and lug wrench, and the little tools that spins the caliper piston back in) and the pads are like $20 for a complete set. Rears are like $10 for the shoes. A tube of anti-squeal compound is a good idea to.... and probably some brake fluid. GD
extreme egr guru needed
"Half that's missing" is not very technical - I don't know what you are saying. The EGR "system" consists of only one part - the EGR valve. That's it. It could be causeing a vacuum leak - the remedy for that is to remove and clean the valve, or replace it. It's really that simple. Sounds like you are confusing "EGR" with the rest of junk in the engine bay that people mistakenly call "emmissions stuff". The only emmissions thing on an EA81 that will make any difference on a tail pipe test is the cat, and it's ASV system..... and you can pass without those pretty easily. You just need a tune up, and to fix all your vac leaks. GD
And what exactly is wrong with your EGR now? GD
About the 6 lug conversion....
It's obvious that you don't have a working knowledge of what you are attempting to discuss - pull a wheel off the front of your Brat and ask these questions after you see how things are set up down there. GD
what engine?
The carb's have a big kidney shaped black air cleaner housing right in the middle of the engine compartment - the SPFI has a flat filter in a houseing on the passenger side near the front.... pretty easy to identify. The SPFI is pretty stout, but can be difficult to troubleshoot when it has problems..... The best bet for a carbed car is to swap out the Hitachi carb for a Weber. Easy to work on, simple, and reliable. Don't forget to replace the timing belts EVERY 60k - you will not be happy when you have to be towed because one broke (easily fixed, but still a pain)..... GD
Help for a DIY
It's far easier to just buy a turbo car. You shouldn't have any difficulty doing way over 70 with the engine you have tho.... You have 95 HP - My Brat only has 80 HP, and I've had it up to about 95 - smooth as silk. You just need to replace those bad axles, get your tires balanced, and get the engine running smooth. Unlike other cars, the older Subaru's don't have HP to spare - every bit counts, and losing a small amount can really suck. They are just fine if you make the needed repairs and maintenance. Turbo isn't what you want in an older soob if you aren't mechanical - they tend to be finicky at times, and don't have much more power than what you have. Your's is 95 HP, and the Turbo is 115..... GD
Off road tires
Their site claims that, yes, but it's apparently not very accurate. I believe it was Junkie that told me he called them and they weren't able to locate him a set.... but that could just be the 205's on a 14 rim. 215's on a 15 like I'm running might be easy to get - not sure. GD
what engine?
Only one engine came in that car - the EA82. '87 is probabaly SPFI, but could be carbed as well (last year for carbed EA82's). GD
Saw a running brat for first time in Bellevue(besides mine)
Brat's aren't as rare as you think - they built about 110,000 of them for the US market from 77 to 87.... And they are as common as dirt in a lot of other countries - Isreal got a ton of them - mostly 2WD tho it seems. And they were sold brand new until '94 in some select markets. Till '92 in Austrailia. GD
Yes!!! Now I Can Offroad!!!
I agree Zap, but it's a Gen 1, has a real nice newish paint job, and a near perfect interior..... it's just too dang nice, and there are plenty of beat up rusted Brats that would be even better for off-roading. Beating the hell out of a 1600 single range just because "it was made for it" doesn't make it right. This one's been almost fully restored and it just isn't right to smash it up. Rally-x would be fine, but not with a lift.....we've all seen what can happen to body lifted rigs at a rally-x. Mine will see some rally-x action too - I'm not afraid to get it dirty, but only when I decide it's ready..... it's far from ready yet Getting closer every day. GD
Off road tires
The Khumo's are different, but equally nice. I've always wanted to try those, but availibility doesn't seem real good. GD
V8 Brat?
Well - It's not a V8, but my parents have a couple Ford's van's with some monster V6's - the one has a 4.0 (244 ci) V6 that can MOVE. Basically, it's a bored and stroked 2.6L..... pushrod engine with a timing chain (I like!). Pushing 155 HP and 220 ft. lbs. of torque. The engine seems nearly bulletproof - they bought it new, it's got 230k on it with fairly regular maintenace (maybe every 7k - not religiously), has never had ANY engine work done and will peel out on command. The low end grunt is considerable.... I would think it would make a nice swap for a t-case modded rig, similar to what Unhatched had at one point (Chevy V6?). There's like 3 million of them on the road - they came in Explorers, Aerostars and Rangers. Only bad point I could see is they are cast iron, and probably a little on the heavy side. GD
If Ben even considers off-roading that white Brat I'll personally come up there and slap him up. And I'll probably have a posse behind me waiting to get their kicks in.... GD
Jackstands 101
Strong within this one, the funnay is..... GD
got the wagon back from the body shop!
I don't get it.... where's the Mud? :-\ GD
Weber question: DGEV vs. DGAV
Who invited the Klan? GD
