25
Everything posted by nipper
And I am an automotive engineer and I can tell you that is an old wives tail from old wives cars. Back before computer controlled transmissions, this was true. Materials and seals were differnt, along with how an automatic transmission operated. Modern transmissions last tthe life of the car now because internal clutch slippage has been greatly reduced (which was the cause for wear and failure in an automatic). Internal materials have changed a great deal since then. The old theory that the gunk that was baked onto the clutch plates no longer applies, since gunk doesnt get baked on the clutch plates anymore. Computers reduce engine torque for a split second at clutch engagement, so no internal slippage, nothing to get baked onto the plates. Now old fluid can gum up the solenoids and pistons. It can loose its ability to transfer heat effeciently. Transmission fluid usually doesnt have an issue with water contamination, but over many many many miles one can never tell. Chaining the fluid on a modern tranmission will not hurt. Yes there is ALWAYS someone who says "I changed mine for the first time at X00,000 miles and it failed". Most likely thier transmission was going to fail anyway. Its the same thought process of chaining from dino to synthetic oil caused oil leaks (as it does not because the engine was going to leak anyway). nipper
Your oil leaks probably mean you are using far less oil then you think you are. Have you had a timing belt done on this car yet? Those compression numbers I dont like, but if subaru says the leakdown is good i wont argue. When was the last time the cooling system was serviced, and what brand oil are you using? What oil change intervals do you use? What kind of driving do you do?
A Wishlist item had been a undercar wlkthrough, but a more realistic on had been to have one bay have a rear garage door of some kind depedning upon how the structure is laid out on the property. Locally the garage cuts off access to the back yard, so I always thought having a rear garage door would be great. nipper
Heated Seats
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
http://www.scoobymods.com/mod_heated_seat_install-t7348.html?t=7348&highlight=heated+seats That comes close -
He needed a sunroof. And besides, that was factually innacurate as VW bigs had plenty of head room, once you got in one. hehehehee
Just because the main switches (which usually are the culprit) pass a MM check doesnt mean they can carry all the current to power the motor. Take the main switch apart, clean and lube the contacts. Check the harness that goes through the drivers door. Test the motor by hot wiring it, but usually the first step fixes it. nipper
Ive been looking for one, and pay no attention to GD, hes just jelouse. Go to that site i posted. Justys actually had a fairly high hp/weight ratio for that size car. They arent too bad to own, engines are easy to rebuild. The only part that is getting hard to find are struts. Fuel injected is prefered over carbed. Also the auto CVTs have a an achillies heel, which is not too hard to fix. Its usually the brushes for the electric clutch that doom those things. nipper
Good more for the rest of us nipper
http://subarujusty.proboards20.com nipper
Chainging transmission fluid has zero to do with this. Check your level to make sure its full. Do a FULL fluid changes (three drain and fills). Then lkest see what happens. It is possible that your tranny is tired, but we do have one more trick up our sleeves if the full fluid change doesnt help. nipper
Heated Seats
They come up on ebay from time to time, and a universal kit is 80.00. nipper -
Heated Seats
Ill hunt this week. Impracticel if you pay someone else to do it. You need to really strip the seat apart to get to the element. Worse comes to worse ill do it in the end of the month and tell ya how. -
Now Now, my lawyer did very well by me with my own insurance company when the lost income adjuster dragged her feet for 3 months. He said its the first time he ever had to fight a clients insurance company because of a lazy employee, as he is used to fighting the other side. He said the other side was easy. nipper
1996 Chevy Lumina -Master cyl?
nipper replied to robertwheeler's topic in Non Soob Cars and Bikes Discussion
http://www.automotivehelper.com/topic314398.htm nipper
