25
Everything posted by nipper
Empty fuse holder is good. Thats the FWD fuse. You use a spare fuse in that slot when you have to run on the spare tire. The fact that its not there means the AWD is working. The bill states that the AWD unit was at the least serviced, if not rebuilt (If the bill is around 800.00 it was rebuilt). Make sure the tires all match Next do figure 8's with the car. The car should make this manuver with no throttle or very little htrottle applied. If it does this in a smooth motion then its fine. Only other thing is to see when the timing belt was changed, otherwise it sounds fine. nipper
"Tick of Death" or Rod Knock?
nipper replied to Gloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Actually a vaccum gauge is one of the best tools to find engine problems that a compression test wont pick up, and its really easy to read. I dont see how its easy to misread. http://www.fordf150.net/howto/diagnoseengine.php nipper -
What does it take to get a Subie with Blizzaks stuck?
nipper replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
An avalanch? nipper -
Too much oil?
nipper replied to mtbe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Too much oil ins a subaru can be catastrophic. I do agree its tough to read the dipstick on a subaru, so triple check. Unlike a V engine or a std engine, the pistons are on their sides. Over filling (could) get the oil up into the cylinders behind pistons. You wont have hydraulic lock (that would be too easy, as the starter motor cant bend anything). What can happen is the oil foams and gets airated. The oil pump cant pump air. Oil with bubbles in the oil can't lubricate. The carankshaft jounrals can throw the oil around and airate it. nipper -
Where can I find some snow around here....
nipper replied to zyewdall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your just a very greedy person and refuse to share with us east coast people :-p nipper -
You can reuse the tensioner, but why take the risk (see other p[osts on tensioners going bad). When i had it done on my legacy it was 600 - 650.00 ( i also needed a harmonic balancer) . That was basically replacing everything under the front covers, money well spent for another 106,000 miles of peace and quiet. You may want to by the tensioner yourself on https://www.subarugenuineparts.com/oe_parts_cat.html To save some bucks. nipper
