Everything posted by colemanapp
				Brat barn find... now what to do first?
colemanapp replied to Bratastick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
we removed the panel for the fuel level sender, carefully, and then you have enough room to look inside. theres a mesh sock around the tank outlet, might as well get a coathanger or something and tear that out, it may look like a small sandman at this point. Now I didn't believe the gravel cleanout would work but it worked great. Put some gravel in the tank, like a couple shovels full. Then get a friend and shake that tank with the gravel all around. You'll then dump the gravel and a bunch of the powdered mess in your tank. -
	I added some 99 outback seats in my loyale. I think the main reason the seat sets you up higher is the extra padding in the newer seats. The ea82 seats are pretty much glorified lawn chairs. I was able to move the seat back further on the ea82 rails which helped quite a bit. The drivers seat was able to be mounted lower as I had to hack out the height adjustable stuff. I've noticed the passenger seat sits a little higher and longer bodied passengers are pretty close to the roof. The newer seats barely squeezed in with the center console.
I would try and get a look inside the gas tank before firing it up. Those tanks get lots of corrosion above the gas line so if it didn't have much gas and you end up putting more in it, its going to possibly clog up all your lines, filter, carb once you get it going and then back to square one cleaning all that out. Did the exact same thing with a gl wagon that sat 10 years without running. Ended up having to drop the tank, fill with clean gravel, shake and clean out that residue. -
				Blown CV Axle or something else? Help?
colemanapp replied to JWD06OBXT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check the ebrake on your front wheel thats hard to turn. I've had on side stick. You should also look at ball joints and tie rod ends for play. Even sway bar links -
	Check the u joint from steering shaft to your rack. I've had that wear out and it caused a little binding and flip flopping of the steering wheel.
	thats one from my area. I know if you'd stuff larger tires on it with the single range, it won't crawl, it'll be tall gearing. We even have a dual range with lift and big tires and it wont climb anything close to the stock dual range wagon with stock tires. Tall tires, tall gearing. My nephew called about that $400 wagon couple weeks ago but never got a call back. I suspect head gasket as well.
	yes, worthwhile product. Easy to install.
- 13 replies
- control arm
 - control arm bushing
					(and 3 more)
Tagged with:
	I bought some last year at www.jayracing.com he had them in stock for the ea82. Company is in Indiana.
- 13 replies
- control arm
					(and 3 more)
Tagged with:
colemanapp replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Some midwest subarus Then my nephew picked this 85 lifted RX up. I see that its got some documented info on this site. Its Roxy from mykingcrab's build. I've been in touch with Mykingcrab about some of the details of the build. Nephews a body guy and painter so hopefully some of the bodywork gets straightened out. -
				Won't restart when warm
colemanapp replied to Srubendall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The distributor gets hot and stops working best I can tell. I blasted mine with a freezing spray when it was hot and wouldn't start. Fired right up when its cooled down -
Hmmm, Sounds like when my distributor went south. -
	We've got a couple blown 3eat tranny's from an 83 gl turbo and 84 gl wagon. I also know how hard it is to come by parts in our area. That said, I believe there'll be some spare parts from the 84 wagon depending on what you need. My nephew was just in your area and picked up a lifted 85 RX sedan for $800 so you're fine on price. Personally, especially after looking into the parts and labor to convert, I'd wait for the manual vs getting the auto now.
	what car do you have? I had my dash lights go out on the loyale as well as the running lights on exterior too. If that's your situation, its one of the 4 relays behind the dash, almost directly behind the fuse box.
				I squished my 87 Gl-10 :(
colemanapp replied to fuentemoon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've had good luck using Rust's winch and keeping the hood latched while you pull. Use something solid behind the hood latch to attach to. Aim that car at a tree and use the winch, and tree to undo the damage. Basically just a reverse accident is what your looking to create. if you keep the hood connected and latched when you do this, youll most likely be able to open/close that hood normally. -
				EA81T Health, checkup, etc.
colemanapp replied to BratRod's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My buddy has his injector wires go bad on his ea81T. Check em out. He just tugged/squeezed the injector wires and it idled differently. -
				Automatic transmission wanted for 83-84 Gl 4wd
colemanapp replied to colemanapp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks, that's option 1 right now. HAHA. -
	I'm hoping to finish up an 83 4WD turbo wagon for my friend who was killed this past weekend. I'd love to finish this car up for his wife/widow. I'm in St. Louis, MO and willing to travel throughout the Midwest to get an automatic transmission for this car. Or if you have one and willing to ship it, that would work as well.
				Impreza RS seats into 1988 Subaru RX
colemanapp replied to D3F0's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did a similar seat upgrade with some 99 outback seats in my loyale. I ended up using the loyale rails and just bolting the new seat onto the rails, Was able to use stock seat belts and even moved the seat back an inch and half for more leg room. Seats are a great upgrade.- 5 replies
- Seat swap cloth interior
 - Impreza rs Subaru RS Mounts
 - (and 5 more)
				15" Peugeot 505 Wheels - Are They Desirable?
colemanapp replied to pudd7575's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those look exactly like the metric ones I bought. Mine came with new unused tires (well, new in the 80's), Michelin Gravel Rally tires and 2 spares. If you don't have metric tires, its tough to find any to purchase. It was a gamble getting them.
