Everything posted by colemanapp
	Ive ridden dirtbikes down in that area. We always called it Missouri on steroids. Rocks are bigger, hillclimbs are longer. Great area for anything outside. Been to St Joe park too. If you cut through, I could showcase some nice gravel and trails in the area south of St. Louis.
	I put some 04 forester struts, springs, etc on mine. I'd add a strut top spacer to rears as they ended up lower than the front by about a half inch.maybe 2" total gain but great upgrade for handling. Direct bolt on in all areas.
- 4 replies
- lifted outback
 - struts
					(and 2 more)
Tagged with:
				Car pulls left after making a left turn
colemanapp replied to Nickoli's topic in Old Gen.: 80's GL/DL/XT/Loyales...
might also be the steering joint coupler (not sure of the name). I had one go bad and it acted just like that before it got even more seized up. -
	to clean the tank, we went old school and dumped some clean gravel in it and shook it around. I couldn;t believe how much stuff came out. Coated the tank and its been good since.
- 30 replies
	it'd sure be worth checking that fuel sock in the gas tank. I don't know if that model has an accessible fuel level sender mounted on the rear of the tank but if you could remove that and look inside the tank, you'd probably find it full of crud and that sock caked in white gunk. Sounds exactly the same problem as a couple of older subarus we rescued. Dirty fuel tank, clogged pickup in tank.
- 30 replies
	you'll need to pull the radiator out to give you room to change it in car but its easy to do the belts with the motor in the car, but i bet itd be hard to video. I pitch the front timing belt covers after i do the job too.
- 17 replies
- Cam timing belts
 - EA82
					(and 1 more)
Tagged with:
				TheGageinator's 1992 Loyale build
colemanapp replied to TheGageinator's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not sure on the connectors but when I had similar problems, I poured some berrymans into the iacv hose, let it sit for while, start it and run til it clears, repeat. -
	I built a little lifted legacy from using some forester struts, springs, strut tops etc on a 95 legacy wagon. The forester stuff gave it a nice lift and still able to keep the cv axles quiet after a little settle in time., Went from the stock legacy tires (185-70-14) to some 02 outback wheels/tires 225/60/16 with no rub and really nice handling. i was surprised how tight it was on the street too. The forester must be quite a bit heavier than an older legacy. So, if you find a legacy, pretty easy to lift that too. Photo of 85 lifted RX bought in beautiful southern MO. Now thats a lift
	we picked one up with 50000 miles, cleaned and rebuilt the carb but it clogged up again right away due to the build up in the gas tank. Had to pull and clean the gas tank as well as remove a metal mesh sock around pickup area of gas tank. Ran perfect after another cleaning of the carb and new filter.
	those 'spacers' might already be the helicoils.
	my son has a 91 turbo ss at school, I'll see if he can shoot me a pic of that area for the ground.
				NEED HELP FAST UNKNOWN EA82 PART
colemanapp replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks just like the clutch cable piece. Just looked at the loyale. -
	I'll let you know how a high mileage (188000) does. My son is taking his 91 SS on a 36 hour round trip college boy spring break starting friday. Fingers crossed here. But its not got any motor mods and runs great.
- 27 replies
	The trim at base of window and along outside of door on mine was pretty pealed up and rusted. I ended up sanding it down and then brushing on some really thick rust stop oil based enamel and it ended up looking pretty much like the original stuff, from a distance.
	This is before paint but still a very nice car. It has some unseen dings in this pic.
	I recently painted my RX and left that trim alone. That was decided after I attempted to remove similar trim from a parts sedan that I have. No bueno on the removing that trim, at least for me.
	Theyve both been reliable cars. The 91 SS has a little crank noise from when I bought it 1.5 years ago. Same noise but no issues whatsoever. I used it the first 6 months and really just raced it around on gravel, then I gave it to my son who's off at college with it. We put 17000 miles on it so far, no issues despite what was called 'crank walk). 185000 miles on that one. The 94 wagon only had 115000 miles when I got it last year. Its got 138000 miles. I broke the original timing belt idling in traffic but just had it towed home and put a new timing kit on it. They both leak a little from the cams and power steering pump. I've had a lot of cars and driven a bunch of miles in my 40 years of driving. I'm sold on these first gen legacies.
	Very reliable, non interference timing belts as well. My experience is only with the turbos, I have a 91 SS and a 94 Turbo Wagon. The wagons only came with automatics and mine feels kinda sloppy but its tight for what it is. I would think an EJ22 na wagon with 5 speed would be the best you could get for your purposes.
	I've had a Surtrack axle on my loyale for a couple years and its been fine. It wasn;t the heavy duty model but I bought it from rockauto, surtrack's been around more than a couple months.
