Handtool
Everything posted by Handtool
Mitzpah Engineering HVLA - Where?
Handtool replied to soobscript's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.mizpahprecision.com/pricing.htm I've gone the DIY route as well, but never again. -
Who else has one of these? This thing has saved me so much time and a lot of cuss words. I keep it in my wallet always.
I like Meguiars cleaner wax for a one step type product for the paint. Areospace 303 protectant for the dash and anything plastic in or outside the car. A good upgrade for the stereo would be a 6disc changer/tapedeck unit out of a wrx or forrester. Plug and play wiring harness and mounting and can be had for approx. 100-150$ off ebay or Nasioc. Ebay is also a good source for a cheap owners manual. Good luck!
Radio sizes
Handtool replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yep, sporting the 6 disc changer/tape unit in my '95 legacy. As they said "plug and play". You can get them from the wrx guys on Naisoc for under $150. -
Wagon or Sedan? I swapped out struts all the way around on a '95 legacy sedan recently. If its a sedan you have to pull the back seat and window shelf to get to the top strut nuts. Pretty cramped work area. A 12mm ratcheting boxend wrench works well for the the one hard to reach nut, or you need to remove the seatbelt to be able to use a socket. I think the wagons are much simpler. Just pop the plastic panel and they are right there for you. Use side dikes to cut the mounting bracket on the strut for the brake lines, bend it up and slip the line out. (Definately true for front struts, rears might be a clip type affair? Can't recall.) Other than that get a breaker bar and a chunk of pipe for some leverage for the bottom bolts of the strut. They are tight. Good luck!
1995 Legacy
Handtool replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
2.2 -
score at the junk yard.. rare find :P
Handtool replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I bet his oil pressure is fine, it's just the sending unit that's tired. Looks like he just rolled 300,000 miles. You don't get to that kinda mileage on lousy oil pressure. -
Stupid Auto Parts Stores.
Handtool replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Neither do I. They can order them for your RX. Part #4553 (8.5mm) - $49.05 + Shipping (321) 725-3159 -
Here's the cheapest I've found Magnecore wires online: http://www.cyberauto.com/index.php/SubaruImpreza.txt As far as coils: http://www.348-409.com/forum/showthread.php?t=581 Good luck.
