Everything posted by lmdew
Legacy Shocks on an Outback
lmdew replied to 94Loyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should be as long as the wheels and tires clear.
Axle Sale
Is this the good place? Axle Sale http://denver.craigslist.org/pts/734203535.html
IAC or Temp Sensor or?
lmdew replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet some Sea Foam and pour it in the 1" hose going to the IAC. Let it soak a bit and then start the car. You can block most of the hose and let a little more Sea Foam be pulled through as it runs.
Aurora, CO 80013 Help Needed
Anyone near this address that could hold a set of Subaru Wheels and Tires for a week and a half? I purchased these and paid with PayPal. I'm in Milwaukee WI for the next week and can not get up to Denver to pick them up. If someone is close by that could hold them that would be great. S. Andes Wy Aurora, CO 80013 Thanks, Larry Lmdew@hotmail.com
are rear drum/disk e-brake cables interchangeable?
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat will be the easy way to go. I did my 98 with a early 90 Legacy. The attachment for the ebrake to drum was different, so I cut a short piece of heater hose to make the couplings stay together. It's working fine, but the next time I'd just grab the ebrake cables as well. All the ones I've looked at are the same up in the car and you should not have a problem with the length.
Tried to check codes, got strange result
lmdew replied to BoostedBalls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's it, single plug about 1/4" wide. The other half may still be tapped up to the harness. It's there.
lmdew replied to BoostedBalls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXConnect the black connectors close by the green one. Green puts the car in the D-Check mode, cycles through all the relays and sensors. Black will pull the codes Green and black at the same time will clear the codes
Subaru Impreza Bucket Seats
lmdew replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo but if there are a great deal, you should pick them up for my 98 Impreza OBS. Larry
Front Diff Swap on a 92 Turbo Auto
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the info.
I have a 92 Turbo Legacy Automatic, and someone put trans fluid in it. It trashed the gears. It's my lucky day, as my local yard has a 92 Turbo with a good front Diff. How hard is it to swap? Can I swap the complete front case and diff as a unit so its properly set? Thanks, Larry
92 Turbo Sedan Trans ?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone put trans fluid in the front Diff. When I jack all 4 wheels, I could put it in gear and all 4 turned. The front wheels had a jerky movement as the Diff went in and out of gear. I drained the trans it looked good, then drained the front diff, which also had trans fluid and lots of gear chunks. Anyone have a front Diff for a 92 Turbo Auto Trans?
A/C Evaporator. How tough to replace?
lmdew replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe dash has to come out. Not to bad. What year? I may have one for you. If you pull one out from a yard, you will then know how to do it on y our car. Did the shop evacuate the system for you? R12 or R134? If you have never done this job, plan on a full day.
Concerned about rear struts.....
lmdew replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPush the dust boot up and see if the strut is leaking. If its wet, you have lost the fluid. I'd also check the top mount, jack the car from the frame so the wheel hangs down and then check for play up and down. Check to see if the sway bar is in good conditions and links.
97 Legacy Window Switch Assembly
lmdew replied to Manarius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you don't find one, I've got several. $20 shipped. Larry
96 EJ22 to be installed on a 95 EJ22 Legacy...
lmdew replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the Starter bolt/stud configuration is the same. Single port or dual port exhaust on both engines. Other than that it should plug and play.
I Busted the Cat pipe, 97 OBW
lmdew replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat section? The y pipe or the section just behind it? Single O2 Sensor or Dual O2 sensors on the Cat? I believe it should be dual O2 sensors. I may have one for you if you can wait 2 weeks until I be home.
One bad strut mount - replace both?
lmdew replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUP
EJ 22 engine problems still won't start
lmdew replied to sube_forester's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're still having problems let me know. I'm out of town for 2 weeks, but my son may be able to come down from Fort Collins and have a look.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will not drive. I'm out of town for the next 2 weeks, so I paid the guy and will pick it up when I get back. Then the investigation will start!
Picked up 92 Turbo Sedan 142K on it. The PO thought the CV were bad, but it sounds like a transmission to me. When you put it in gear, you can hear a light grinding, kind of like swinging your ratchet around by the socket. It does shift into R and D, the sound changes slightly. No movement on the car. I was not able to get under the car to see what the status of the driveline was, but the front CV were not turning. Any ideas?
daagnostic connectors
lmdew replied to bdecriscio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd take it back to the shop that caused the problem and tell them to fix it! If it was damage done by the shop they should correct it. If its a wire issue inside the pan, a new valve body may not fix it. What code are they getting from the TCU? A good trans shop or you Subaru dealer should be able to isolate the fault. Wiring can be very time consuming to troubleshoot.
95/97 2.2 ECU Code Help
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got the ECU pin out from a Michaels CD at an auto shop.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, first I had the EGR code. Once I set the ECU to a manual trans, it needed the neutral SW.
Need parts resources...
lmdew replied to unverviking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMight have one for you, what length and do you need the front rear or both? I parted a 97 OBS.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's good. I cut wire 78 about a foot from the ECU, 4.75 volts out of the ECU. Wired it to the neutral sw and the sw to ground. The ECU is getting what it wants, no CEL. Thanks for the help.
