Everything posted by lmdew
1998 Impreza OBS EJ22 No Start
lmdew replied to PhantomSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a few sets of Red Fuel Injectors if you want a set or two. $20 + shipping.
98 Outback EJ 25 - HG or retire it?....
lmdew replied to GorgeSuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, for under $300 I could grab a good used 2.2 and do the T-belt all the seals and have it ready to go. If you know the histor of the 2.5 and it was not overheated then it may be worth doing the HG. Most of the Outback 2.2 swaps I did were on cars I purchased that way. Know way of knowing how long or how bad they were overheated. I didn't want to take a chance on the lower end bearings.
Outback Overheating Mystery!
lmdew replied to FrustratedWit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the Fans coming on as they should? Have you checked the temp of the heater hoses? When you turn the temp to cold, you say the gauge goes back to "Normal". What happens to the temp of the upper and lower hoses before and after, when you do this. It makes little sense as you are controlling the airbox flaps, not the actual coolant flow. If you have an OBDII reader, you may want to track the coolant temp there as well.
Oil on plug threads (EJ22 phase 1 engine)
lmdew replied to floridarich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThose seals do NOT apply to your 92 Legacy.
Rodent damage or Sabotage?
lmdew replied to Averagejoes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe had rabbits at work getting up on top of engines and chewing through plug wires and engine harnesses. They can do real damage quickly.
lmdew replied to GorgeSuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAuto to Manual trans swap is 10X the work of swapping 2.5 to 2.2
lmdew replied to GorgeSuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1++++++ on the 2.2 swap. I've done 15+ of them and have been happy with each one. Under $500 you can find a good used 2.2. New Timing Belt and all the seals. Drop it in and drive it for another 100K+
what's it worth?
lmdew replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2009 Subaru Outback - $3,100 172K
Thoughts on a hard starting '92 Legacy?
lmdew replied to floridarich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have many sets of Red Injectors in rails. Let me know if you want some.
what's it worth?
lmdew replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I search the Craigslist and put a top value of $3K, I see some listed in the 2500 - 3000 range. Local market will play a huge part!
lmdew replied to floridarich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD may have an idea. Otherwise, the next time it is hard starting. I'd stop and pull the plugs and see if one is wet with fuel.
lmdew replied to floridarich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny CEL Codes? Might have a leaking fuel injector. I can be pretty random.
Rear fuel filter
lmdew replied to sask49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$24 that's a deal.
2018 Forester Tailgate - Power Lift/Manual Lift?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShe plans to keep it long term. Just Dad trying to keep the value in her Subaru and pass on some knowledge. Thanks
Rear fuel filter
lmdew replied to sask49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLMC Truck: 43-4760 FUEL PUMP "E" GAS F150 F250 87-89 1 $62.95
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. In the yards about 2012 or earlier is all I see at the You Pull and Pays. I'm sure she can wait. Just trying to get her to follow through and figure out what this little damage has done to the value of her newer Subaru.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. Hers still works fine. The dent is small, but caused a crease. She could drive it that way forever, but the value of her 2018 Forester went down for sure. Another reason I like my 2000 OBS.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. 61K - Black is here color code. I've found them for 800 - 1200. We'll see what she wants to do.
- 2018 Forester Tailgate - Power Lift/Manual Lift?
Daughter has a 2018 Forester. Last week someone rolled into her at a stoplight. Tailate got creased. Replacement will be needed. www.Car-part.com has Tailgate - Power Lift/Manual Lift. Anyone know what the physical differences are? Could I make either one work. She said her's is manual, she believes. Thanks- Struts
lmdew replied to Sherman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you pull the rears and install them you have to jack them slightly to remove the pressure on the bolt as they come out and to get it aligned to start the bottom bolt. In the yard, I'd just take a couple sections of 2x4 that I could lever into place and most yards don't let you take jacks in.- Rear Hub 2010 + fit older Subaru?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. I was looking for a friend with a 2007 Forester. Should have put that in up front.- Rear Hub 2010 + fit older Subaru?
Looking for a friend who has a 2007 Subaru that need rear wheel bearings, I came across the replaceable unit, 2010+ Is it possible to get a newer unit and retro fit it to an earlier Subaru? If you went to the yard and pulled a 2010+ rear hub, could it be bolted in to an earlier Subaru? Thanks, Larry- Major oil leak has me stumped
lmdew replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, I did not see the 3.0 and was thinking 2.2 or 2.5.- Major oil leak has me stumped
lmdew replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOil Pump Rear Cover could be loose and it's RTV seal failed between the block and oil pump. Once you have the covers off and it all cleaned up you can put it back together with out the covers so you can run it an pin point the leak. I was think 2.2 or 2.5 motor. Sorry - 2018 Forester Tailgate - Power Lift/Manual Lift?
