Everything posted by lmdew
Replacing a 2.5 in a 99 Outback
lmdew replied to Rp23g7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMuch easier to leave the trans in the car! Make sure you keep the TC fully seated in the trans and push it away from the flex plate once all 4 bolts are removed. It will move back about an 1/8" You will have to jack the trans about an 1" and 1/2 to allow the flex plate to clear the cross member. Don't jack on the pan as it will dent.
lmdew replied to Rp23g7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, your flex plate will bolt right up. The biggest thing is to have a matching EGR. If your current engine has an EGR you need an EGR on the new engine. There are some work around's but since you bought the engine, I'm pretty sure you ensured they should match. Reseal the rear breather plate while the flywheel/flex plate are off with Gray RTV. A good used 95-98 2.2 engine would be a good option.
transmission pan swapability?
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing special about Subaru Pans. If they are the same shape and have the same number of bolts holding them on you are good to go. They are just sealed to the trans. It's something other than RTV but Gray RTV works well. NO Gasket.
Sooooo, my muffler fell off... again, '96 Impreza outback.
lmdew replied to 1996BlackBauer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave a nice rust free CO $25+ shipping from 80919
2009 Forester rebuild, or replace?
lmdew replied to BuellMule's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com check for a yard engine. Your son will still learn a bunch from the engine replacement. There are a bunch of USMB members that rebuild engines full time. I work on older stuff 96-99 Outbacks were I can find a good used 2.2 for $300 and drop it in with new seals, timing belt... for under $500.
97 ej22 beetle swop help
lmdew replied to otakuphill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll need the ERG or it will throw codes, if you other car had an EGR. Best bet on the wiring would be to go to the yard and pull off a good intake and take a look at the wires. Basically down the middle of the intake tied to the fuel tubes but it's very tight under there.
abs sensor question
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost likely. You can check and clean the sensor. Sometimes they are full of crud. Wire brush or sotchbrite the sensor and see if it changes.
Forester _ improving MPG
lmdew replied to sadarahu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWasn't trying to be rude. But traveling through IL often for work I just don't get the thought process of a lot of IL drivers.
Coil spring compressor rental or purchase?
lmdew replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr even an easier idea, watch for a good set of KYB Struts in a self server yard and pull the complete strut. $20 each is what I pay for them. Bolt them right in.
lmdew replied to sadarahu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't drive 85 in a 55 MPH speed limit like all the other IL folks. Forester's are not as fuel efficient as other models due the the higher frontal area.
belt or entire ac unit
lmdew replied to scoobydoo wagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, if you don't want it snip the belt. It's AC only. It is recommended to run the AC every month or so to keep the o-rings lubricated and system working. If you have not done that for years, it won't make any difference now. Not much of any MPG change as it's just rotating a belt when the AC is off. No load on the engine.
Baja motor swap - EJ25 EGR w/ non-EGR motor
lmdew replied to Muddawg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is what I did. Ran fine, no codes. I would 'think' you could put a hole in the intake - after the air filter - put in one of those plastic hose barbs w/a rubber grommet sized to fit the hole, and run a line to the EGR hard line that normally goes to the head
engine swap 2.5 to 2.2 need some advice
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe alignment pins are often corroded into the trans. I will require you to pry the engine and trans apart. Go easy, start with a thing screwdriver driven between the engine and trans. Work up to a pry bar. Some folks like to drive the pins forward, the passenger side will come out the drivers side will hit the engine block but you can move it half way out of the trans.
Tranny option
lmdew replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo the original one will work fine.
MY04 Liberty 2.5i Auto Radiator Leak
lmdew replied to ALib's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, replace the radiator is the best option. You could take it to a radiator shop, they may be able to stop the leak by crimping the metal clamp a little more and pressure testing it. There is a rubber gasket between the plastic tank and the core. I would think you could order a radiator online.
1997 Subaru - multiple overheats - new engine?
lmdew replied to ztrain727's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've pulled 20+ engines from the you pull yards. Look for: - Car hit hard, you know it was going down the road - Car is in other wise good shape, you know the owner took care of it - Oil, pull the pan plug, the cleaner the oil the better. Put you finger in the drain hole and check the bottom of the pan for metal inside - Engine turns over by hand and compression feels good on all cylinders - Pull a plug or two, good clean burning - Coolant looks good If it passes all those checks pull it. Before you install it: - Reseal the rear breather plate - New Plugs (NGK) and valve cover gaskets - Reseal the Oil Pump and locktite on the rear cover screws - New Subaru Cam and Crank Seals - New Timing belt kit - Make sure the thermostat is a Subaru one and the gasket is good
1997 Outback fog light wiring
lmdew replied to Ramone899's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHead to the yard and clip a good connector and then splice it in. Easy.
Coil spring broken
lmdew replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just tossed several rust free Colorado Springs. I have more $5 + shipping. Larry
part interchange
lmdew replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru are like lego's. Lot's of parts will bolt right on other Subaru's: Brakes Struts Seats A good used 96-99 Outback with the DOHC engine that the Head Gaskets have went out is a great platform and will last a long time.
lmdew replied to ztrain727's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrop in a good used 2.2, better and cheaper long lasting option.
1st time Subie buyer here
lmdew replied to janas19's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrop a used 2.2 into this one and for less than $2000 you can have a great car that will last for years. http://rockies.craigslist.org/cto/5828064499.html
lmdew replied to janas19's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet me know what you're looking for. I fix Subaru's for fun. 96-99 DOHC engines have Head Gasket issues. When I find one with a bad engine, I drop a 96-98 2.2 engine in it. Much better engine and only a small loss in power. Larry
Hood hindge bolt hole stripped
lmdew replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's easy to cross thread the hood bolts if the hinge is not lined up. Leave all the bolts lose and start them by hand. I'd pull the hood off and try the standard tap first. There is not much depth in there so take it easy.
New rear parking brake shoes - rotor won't fit
lmdew replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow worn were your old shoes? I have had new shoes that were two thick. Is the adjuster screwed all the way in? If your old shoes have over a 1/8" pad on them, I'd use them. Remember it's only a parking Brake.
2000 Subaru Legacy L IAT sensor
lmdew replied to Marius789's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIntake Air Temp sensor is right on the front face of the intake air box to the passenger side of the throttle body. Rock Auto.com Amazon.com www.heubergermotors.com/parts/index.htm 25% off if you order online. I use them cause they are close to me but they do ship.
