Everything posted by calebz
Parking & Tail Lights won't go off
calebz replied to Nayashewon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAmazingly enough, when a person buys a used car, often times the owners manual is missing.
Is Outback (2005) Trunk Area Wide Enough to Fit Golf Clubs??
calebz replied to mdevine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI sure as hell hope so.. I can get 4 sets in the back of my old school soob
calebz replied to Nayashewon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaking profit from info gleaned from the USMB is unacceptable... Unless you share
EA82t Deltacams question.
Yes, lots
got the wagon back from the body shop!
Nice scoop.. ya big copycat
ea82 heads all the same
If it is in fact a DL with a turbo motor, that would make it a real oddball.. might be worth picking up for oddities sake.
Loyale Transmission problems
First problem is probably synchros, although they are generally more notciable when decellerating. The second problem sounds very much like a classic noisy throwout bearing.
Another Accell super coil Dead
Mine did the superpuff nuber on the coil wire as well. Its from the coil leaking and the oil travelling up the coil wire. I actually had oil filling up the spot on the distributor cap where the coiil wire goes.
Weber question: DGEV vs. DGAV
Which end? how many ends of a carburator bolt to the car?
EA-81 CV joints..too weak!
Umm.. no Rick, it just sounds like 'axlemaster'
Will a 2L Legacy Turbo engine fit...
Search is your friend http://www.ultimatesubaru.org/forum/search.php
Digital Dashboard swap to analogue
A donor car, some wire cutter, electrical tape and FSM wiring diagrams for both cars.
87 RX Turbo Cyl 1 and 3 not firing
Yup.. I missed that step the first time I did it too. Thank god the board was here or I would probably never figured out why the car wouldn't go..
The above = A lot of modifications;)
anyone ever put XT seats in an Ea81?
Yeah, Impulse seats are really quite nice. Never thought of that
Rear disc brakes
Additionally, some 87 and 88 turbos came with an LSD. (mine is from an early 88)
Rear disc brakes
The rear in the wagon will be 3.70 Being a pushbutton 4wd trans, there is about a .001% chance of it having an LSD What your are describing in your brat is plain old 4wd bind. Happens when you try to turn in 4wd on dry pavement
how to get back to the old forum/archives?
Only if people used it. Which most won't.. then we will once again tell oeople to search.. then we will be called 'search nazis' and people will threaten to leave if it doesn't stop:rolleyes:
New Subaru Owner here.... `85
www.ozified.com
Who's Who Three (Roll call for lowered soobs)
Bump an old thread.. I want to know the answer to Rob's question too.
really odd smoking problem
Its the PCV SOA issued a recall for this problem in the 90+ loyales, but I have heard of some of the late 80s EA82 cars affected as well. I don't know the specifics of whats wronf, only that the PCV does weird stuff when accelerating and turning, like in an offramp/ onramp situation
why buy a subaru
calebz replied to subaru987's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree I get one or two of these a month.. I have been trying to be nice and answer, but I think this is the last one.
Whats the deal with pug lugs?
There is one type of steel 14 that takes special lugs as well, but they aren't terribly common.
vacuume "Vs" center diff
I just did the exact same conversion on my 87 turbo wagon.. its plug and play..
Can you run you’re A/C on a long climb? (turbo car)
No real way to tell without a better temp gauge. If it helps any, mine gets pretty warm on long pulls with the AC on as well.. probably doesn't help that I have an old rump roast single core radiator though.
